 Post subject: Seagte model : 3250318AS , On power on 11 clicks
PostPosted: September 6th, 2014, 4:59
Hello Friends ,
FIRMWARE : CC38
See terminal log , what could be the problem ?
On power on 11 clicks & motor stops.
F3 T>
ASCII Diag mode
F3 T>/7
F3 7>X
ExecuteSpinRequest
HighPowerMode
Failed to load overlay 00000004
LED:000000CC FAddr:0028931
Rst 0x08M
ASCII Diag mode
F3 T>
No HOST FIS-ReadyStatusFlags 2002B001
ASCII Diag mode
F3 T>/2
F3 2>Z
HighPowerMode
Spin Down Complete
Elapsed Time 0.104 msecs
F3 2>U
HighPowerMode
ExecuteSpinRequest
DiagError 00006008
Spin Error
Elapsed Time 9.488 secs
R/W Status 2 R/W Error 84150180
F3 2>
HDA SN: 9VY7VPB9, RPM: 7201, Wedges: 120, Heads: 1, Lbas: 1D1C5970, PreampType: 00
00
PCBA SN: 0000C046E7W3, Controller: YETIST_3_*/4_0(649B)(3-12-3-3), Channel:
AGERE_COPPERHEAD_LITE, PowerAsic: MCKINLEY DESKTOP LITE Rev 94, BufferBytes:
800000
Package Version: PH0G2C.CCD3.FV0284., Package P/N: 100618794, Package Builder ID:
AT,
Package Build Date: 03/12/2010, Package Build Time: 15:06:05, Package CFW Version:
PH0G.CCD3.00247208.AT00,
Package SFW1 Version: C26C, Package SFW2 Version: ----, Package SFW3 Version:
----, Package SFW4 Version: ----
Controller FW Rev: 03121506, CustomerRel: CC38, Changelist: 00247208, ProdType:
PH0G.CCD3, Date: 03/12/2010, Time: 150605, UserId: 00236537
Servo FW Rev: C26C
RAP FW Implementation Key: 10, Format Rev: 0001, Contents Rev: A1 09 08 03
 Post subject: Re: Seagte model : 3250318AS , On power on 11 clicks
PostPosted: September 6th, 2014, 5:02
Hi ,
One more thing
PreampType: 00 00 , what does this indicate ?
Preamp Gone ?
Please advise .
Peter
PostPosted: September 9th, 2014, 2:51
Your drive needs clean room work, need heads swap.
PostPosted: September 9th, 2014, 23:26
Hello Friend Northwind ,
Thanks for the reply ,
For Donar hdd , I need to match Model , firmware & part no Right ??
Please confirm .
Regards,
Peter
PostPosted: September 10th, 2014, 6:16
You need to match model, part number and 3 first letters of s/n. But for Seagate, there is still chance even if you match that, heads would be incompatible. Most secure way is to look at sliders under microscope to ensure they are the same.
This is a single-headed Pharaoh if I remember right.
PostPosted: September 10th, 2014, 6:30
Looks like it ...
http://www.users.on.net/~fzabkar/HDD/PH-CC49.TXT
