 Post subject: HDTD105XS3D1
PostPosted: September 15th, 2014, 16:24
Hello to all! :mrgreen:
this password locked. ... is DDI4
Help?
Нет ничего невозможного
 Post subject: Re: HDTD105XS3D1
PostPosted: September 16th, 2014, 8:52
Help?
Is native usb interface!
14109.pdf [230.86 KiB]
Downloaded 409 times
PostPosted: September 16th, 2014, 9:46
Do you have the password?
PostPosted: September 16th, 2014, 10:13
no have password..
PostPosted: September 16th, 2014, 14:59
sempre wrote:
no have password..
CONFIGURATION GENERAL INFORMATION:
Device type........................................................ : Fixed device and/or controller
Device interface................................................... : SATA (SATA Rev 2.6)
Rotation Rate...................................................... : 5400
Main data
Model.............................................................. : TOSHIBA MQ01UBF050
Serial number...................................................... : 7xxxxxxxx
Firmware........................................................... : AM001U
Current Logical Parameters
Cylinders.......................................................... : 16 383
Heads.............................................................. : 16
Sectors............................................................ : 63
Capacity........................................................... : 16 514 064 7,87 GB
Capacity available in LBA Mode..................................... : 268 435 455 128 GB
Capacity available in LBA 48 Mode.................................. : 976 773 168 465,76 GB
Capabilities
Standby timer values supported..................................... : [YES]
IORDY supported.................................................... : [YES]
IORDY disabled..................................................... : [YES]
LBA supported...................................................... : [YES]
DMA supported...................................................... : [YES]
PIO MODE
PIO MODE 3 Support................................................. : [YES]
PIO MODE 4 Support................................................. : [YES]
Available DMA Mode
Multiword DMA Mode 0............................................... : [YES]
Multiword DMA Mode 1............................................... : [YES]
Multiword DMA Mode 2............................................... : [YES]
Active UDMA/33 modes
Ultra DMA/33 Mode 0................................................ : [YES]
Ultra DMA/33 Mode 1................................................ : [YES]
Ultra DMA/33 Mode 2................................................ : [YES]
Ultra DMA/33 Mode 3................................................ : [YES]
Ultra DMA/33 Mode 4................................................ : [YES]
Ultra DMA/33 Mode 5................................................ : [YES] SELECT
Ultra DMA/33 Mode 6................................................ : [NO]
Timing
Minimal multiword DMA cycle time................................... : 120 ns
Recommended multiword DMA cycle tim,e............................... : 120 ns
Minimal multiword PIO cycle time w/o stream control................ : 120 ns
Minimal multiword PIO cycle time with IORDY........................ : 120 ns
Supported standards
ATA - 3............................................................ : [YES]
ATA - 4............................................................ : [YES]
ATA - 5............................................................ : [YES]
ATA - 6............................................................ : [YES]
Security system
password set....................................................... : [YES]
HDD Locked......................................................... : [YES]
HDD Frozen......................................................... : [NO]
wrong password count exceeded...................................... : [NO]
security erase support............................................. : [YES]
security level..................................................... : Maximum
POWER MANAGEMENT
Mandatory power manement........................................... : [YES] Enabled
Power up standby................................................... : [NO]
Advanced power manement............................................ : [YES] Enabled
Advanced power manement value...................................... : 128
Supported Command Sets
NOP................................................................ : Supported Enabled
READ BUFFER........................................................ : Supported Enabled
WRITE BUFFER....................................................... : Supported Enabled
Host Protected Area feature set.................................... : Supported Enabled
DEVICE RESET command............................................... : Not supported
SERVICE interrupt.................................................. : Not supported
Release interrupt.................................................. : Not supported
Look-ahead......................................................... : Supported Enabled
Write cache........................................................ : Supported Enabled
PACKET Command feature set......................................... : Not supported
Power Management feature set....................................... : Supported Enabled
Removable Media feature set........................................ : Not supported
Security Mode feature set.......................................... : Supported Enabled
SMART feature set.................................................. : Supported Enabled
FLUSH CACHE command................................................ : Supported Enabled
Device Configuration Overlay feature set........................... : Supported Enabled
AUTOMATIC Acoustic Management feature set.......................... : Not supported
SET MAX security extension......................................... : Supported
SET FEATURES subcommand required to spinup after power-up.......... : [NO]
Power-Up In Standby feature set.................................... : Not supported
Removable Media Status Notification feature set.................... : Not supported
DOWNLOAD MICROCODE................................................. : Supported Enabled
Device Sector Info
Multiple logical sectors per physical sector....................... : [YES]
Logical Sector Longer than 256 Words............................... : [NO]
Logical sectors per physical sector................................ : 8
Words per Logical Sector........................................... : 256 512 b
PostPosted: September 16th, 2014, 15:17
Did you ask the owner for the password?
PostPosted: September 16th, 2014, 15:20
have an idea here for you
can you post the image of the PCB here?
:wink:
PostPosted: September 16th, 2014, 15:41
yes he said he wore no password... :roll:
PostPosted: September 16th, 2014, 15:43
:wink:
not yet have a photo because not opened the case ... so I put here in open forum
PostPosted: September 16th, 2014, 17:02
:wink:
PostPosted: September 17th, 2014, 8:15
:wink:
new photo!!
PostPosted: September 17th, 2014, 14:22
AIUI, you can access the drive's security settings in terminal mode. If you don't know the location of the Tx/Rx pins, then you could experiment with the obvious candidates, or you could obtain a SATA board with the same MCU and locate the Tx/Rx pins on the MCU by working back from the known Tx/Rx jumper pins. Now locate these same MCU pins on your patient and trace them to your likely suspects.
:wink: :idea:
PostPosted: September 17th, 2014, 14:59
:wink: :idea:
Thanks!!
PostPosted: October 24th, 2014, 9:16
Solved!! :mrgreen:
data access 100%
Users browsing this forum: Majestic-12 [Bot] and 65 guests
