 Post subject: Increasing The Capacity Of A Hard Drive
PostPosted: September 16th, 2014, 17:49
I hope someone can tell me the best way to
program a hard drives way of writing data?
Or a software that can do it.
1. I would like to have my harddrive do an internal raid.
I wan to test the speed difference if any.
--Duplicate data on opposite sides of the disk to
have the disk to only have to spin half/quarter way to read any data.
2. Set the harddrive to write in set of data instead of 1/0. or a software to interpret it that way.
T possible be extended to multiple platters
with greater variations
000-111,0000-1111+ depending on the number of hard drives in raid or platter count.
example- 512gb hd 1 platter made into a 1tb hard dive or quartered for faster reads?
00-01 making the hard drive 256gb with 4 duplicate data sets?
Or 6tb 6 platter hd, made into a 24tb+ hard drive
or quartered/other for faster reads?
Also I would like to partition or just use a software
or whatever to try to do say 100+ partitions/or read areas/other set. 10 digit+ 0000000000-1111111111
Increasing the storage amount by up to 10X depending on how data is stored?
And if that is to much a software that assigns values like that to increase data storage amount by 100+fold or more.
Second Thing.
It would be nice if harddives were made like Cpus'
Not flash from what I have learned.
Cpu/Ram? access type with material from hardives deposited in the cpu die.
Layered like cpu's are.. Hdd size? Replace ram and hd?
Cheap intel CPU?$40?
1 for Hdd,
1for Cpu/Gpu or one of each?
1 for Ram if needed or wanted?
 Post subject: Re: Increasing The Capacity Of A Hard Drive
PostPosted: September 17th, 2014, 6:15
Updated:::
way to program a hard drives way of writing data?
I want to test the speed difference if any.
2. Set the harddrive to write in sets of data instead of 1/0.
0=00,1=01 top of platter certain partition?
0=01,1=11 bottom of platter different partition?
Or a have software to interpret the data that way.
Possibly to be extended to multiple platters with greater variations.
Using 000-111(9),,,,0000-1111(16)(+) depending on the number of hard drives in raid or platter count.
example- 512gb hd use 00-11 using 4 partitions/platter/other sets. Making a 512gb Hdd into a 1tb hard drive.
Also half/quarter the data location on the disk to increase read speed?
Creating with a 00-11 set a 256gb or 512gb hdd with 4 duplicates for reads instead of 128gb or 256gb duplicated.
Maybe 6tb 6 platter hd, made into a
12/ 24tb+/-? hard drive?
just use a software or whatever to try to do say 100+ partitions/or read areas/other set.
If that is to much for a direct hardware allocation possible a software that assigns values like that to increase data storage amount ?100+fold or more?
Other- Could the 00-11 be stacked?
I'm not sure if the hard drives do this already or not, but if a harddrive
was programed to place top neg=00, top pos=01
bottom pos=11,bot neg=11. Could you add another layer in software
to make code at a higher level splitting into 4 way coding?
Doubling or many more times the capacity of a drive?
Second Thing.
It would be nice if harddrives were
made like Cpus'
Layered cpu style.
Resulting Hdd size?
Replace ram and hd?
1 for Hdd,
1 for all controller,wifi,other?
Other Possibilities?
Use a cypher/other for the data? compression?
0000 0001 0011 0111
=0 =1 = 01 =11
1111 1000 1100 1110
=111 = 00 =101 =110
0101 1010 1001 0110 1101 1011 0100 0010
=10 =001 =010 =011 =110 =1011= 0100 =0010
Code or other in program to select and assign values depending on most present code combos in data?
01 10 0011 1101
0 1 11 10
Specify different types of Hdd sector cluster types?
example:0000-1111+/- to specify type of cluster any use?
0000=a 0001=b 0011=c 0111=d.........
Third variable in HDD non negative or positive--
Use a bit based way of assigning data a value. Even and odd numbers?
1 2 3 4 5 6 7 8 9 10 11 12 13
0=00 0=01 0=00 0=01.............................
1=10 1=11 1=10 1=11..............................
1 =10 if bit 3072 is 0 = 10 if 1= 1110
4096/4=1024, 4096-1024=3072(last quarter)
if 3926 =0 1110 if 1 =1110 0110(or any combo 1001 0110, 1110 1001)
As many more times as may work.
Cluster labeling?
if in an A cluster doubles to 1110 0001 1100 0110
If in a B cluster changes to 1100 0011 0011 0111
if in a C cluster changes to .......
if in a D cluster check specific cluster (cluster x-541)(or0000000001000) if 01 in (cluster x-541)-(4056)
code or double or change or other =..............
Or any other combo?
2bit base sets instead of 1bit.
1,2 3,4 5,6 7,8
11=1000 11=0001 11=0011 11=1100
00=1111 00=0000 00=1100 00=1011
10...............................
01...............................
4bit base sets instead of 2bit.
1243 5678 9101112 13141516
0000 0000 0000 0000
01010101 10101010 11110000 00001111
and on...It would seem that since data I'm pretty certain is in even numbered(8bit?) amounts that any amount of even sets should work.
2+ materials in Hdd , Option to create weaker and stronger fields?
4 types+ of bits= what?
1 neg=1/ 2 neg=01/ 3neg=??
1 pos=0/ 2 pos=10/ 3pos=??
Solid State Quantum Computing?
Use a hdd type cpu(cpu with hdd material in it) and use solid state bit holding in cpu for quantum computing?
quantum computer qubit--- pos and neg at once?
1=neg 2neg 3
1=pos 2pos 3
PostPosted: September 18th, 2014, 6:17
What... the... hell?
PostPosted: September 18th, 2014, 7:01
No disrespect at all, it is good you are thinking about things. But the hard disk manufacturers have spent decades already looking at every possible thing you could imagine to squeeze data onto the platters.
For example, look at some whitepapers about any aspect of a hard drive. I (started to read) read one that was pages and pages of math dedicated to measuring how different the velocities, turbulence and such was between hard disks with air, or hard disks with helium. It was actually mind blowing how much just that single thing was researched and the amount of physics and math that went into it. I would imagine the same effort to every single part of the HDD, including code for storing the data. No layperson is going to come up with anything that would revolutionise the storage, sorry to say.
PostPosted: September 18th, 2014, 11:16
The advice should be:
1. Take your pills
or
2.Stop the drugs you take...
PostPosted: September 18th, 2014, 13:09
Bet you have one of these :mrgreen:
http://www.rescue-it.se
PostPosted: September 19th, 2014, 7:29
1. Take your pills
or
:lol: :mrgreen:
PostPosted: September 19th, 2014, 11:35
:lol: This tread need to be move to "Fun stuff"
PostPosted: September 19th, 2014, 15:45
Oh man. That's so painful to read.
Re-inventing the wheel into a concert cylinder
PostPosted: September 19th, 2014, 18:20
:lol: :lol: :lol: :lol: :lol: :lol:
http://www.hpwlab.com
Users browsing this forum: Google [Bot] and 62 guests
