 Post subject: WD500BPVT makes the click noise.
PostPosted: September 20th, 2014, 10:40
Hello
I have a hard drive of my client.
WD500BPVT makes the click noise. It detects as PC-3000 but does not show the model or size () but I can save ROM but can not see the sector.
in my opinion, the drive Head blocks.
WD5000BPVT
MDL: WD5000BPVT-60HXZT1
DCM: EHOTJHN
What is your advice?
thank you
Best regards
 Post subject: Re: WD500BPVT makes the click noise.
PostPosted: September 20th, 2014, 11:45
Try to do a ROM Headmap to disable heads and check wich one is bad.
You can also try to use a loader to check if it's really heads or FW problem.
ACELab partner
PostPosted: September 20th, 2014, 12:35
good advice PcLab
try to disable some heads to see if amy off them is badly
if you want i can help you via tv.
contact me
PostPosted: September 20th, 2014, 15:51
hvd wrote:
Hello
WD5000BPVT
DCM: EHOTJHN
thank you
Best regards
Heads are bad, requires cleanroom work and parts. We can almost certainly help.
Merci bien.
 Post subject: WD500BPVT with a clicking noise
PostPosted: September 20th, 2014, 21:20
Yes, that's bad heads, probably some surface damage.
But what this will give for the clicking hard drive?
If a drive clicks, it can't read servolabels, so heads are to be replaced.
Headmap and loaders are the instruments for non-clicking hard drives. A reasonable check here would be to test the PCB by replacing it with a surely working one (after a ROM transfer).
If nothing has changed after that, then do a head swap, which in its turn will allow to judge the surface condition.
PostPosted: September 21st, 2014, 6:31
Hello
I try to launch the Utility Start with Karnel
I try to - RAM head Map edition
Here log in Pc3000
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 3
Cyl Count............................... : 256
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 10.0TA
ROM generation.......................... : 10.0TA
Link table version...................... : 02.13.
Consolidated ROM version................ : 0010000T
ROM Modules:
Flash ROM dir reading................... : Ok
SA regions address...................... : by default
SA Translator loading................... : Ok
Heads number in use..................... : 3
Switched off heads...................... : No
Heads map............................... : 0,2,3
ROM Firmware version.................... : 0010000T
Code type to check...................... : TypeN
Code addr............................... : FFE00000
Code size............................... : 327681
Code reading............................ : Ok
Code pattern not found
Code type to check...................... : Type1
Code type to check...................... : Type2
Code type to check...................... : Type3
Code type to check...................... : Type4
LDR Byte................................ : 20
LDR Reg................................. : R4
Code offset............................. : 485A0
Map address............................. : 20017028
Data checking........................... : Ok
I agree with you photo of ROM head map editing
Thank
PostPosted: September 21st, 2014, 6:38
Hello
I try to launch the Utility Start with Normal Mode
Here Log:
Techno mode key
RAM:
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
ROM Modules:
Service area:
Permanent overlay....................... : Not loaded
SA dir reading (ID)..................... : SERVO ERROR CODE BASE SvirActSpeed
SA SPT Detect........................... : FAIL
SA dir reading (ABA/CHS)................ : Dir reading error ABA 281088 reading error Physical read error C/H/S: -256/1/1 - Device Error Detected: "SERVO ERROR CODE BASE SvirActSpeed"
SA Access............................... : NONE
Configuration reading................... : Module 02 not found
Thank
PostPosted: September 21st, 2014, 8:31
As you have already been told, the heads are bad.
I advise you to stop messing with this CLIENTS DRIVE and seek pro help for Cleanroom work.
Good luck :-)
PostPosted: September 21st, 2014, 14:33
hello
  As I am a beginner so I need your help .
I have every tool to remove the hard drive (Cleanroom and HDDSurgery WDC 2.5 "-3.5" Ramp Set)
I can not find the hard drive on the same google.
To change head drive. We must find the hard drive the same model, MDL, DCM ?
WD5000BPVT
DCM: EHOTJHN
Thank
Good luck :-)
PostPosted: September 21st, 2014, 14:53
hvd wrote:
hello
WD5000BPVT
DCM: EHOTJHN
Thank
Good luck :-)
As been told before, don't mess with a clients drive.
You can buy tools but not knowledge....
http://www.rescue-it.se
PostPosted: September 21st, 2014, 16:00
Headstack matching for Western Digital:
http://www.alexsoft.org/viewtopic.php?f=86&t=1036
PostPosted: September 21st, 2014, 17:44
Frank, with all respect....If that had been your drive how would you like it to be handled?
PostPosted: September 21st, 2014, 18:27
Information wants to be free.
If it were my drive, I would learn how to fix it myself, whatever the cost.
PostPosted: September 22nd, 2014, 1:45
And that is exactly what 99.99% of the common user is NOT able to do, and needs to rely on other with their important data.
PostPosted: September 22nd, 2014, 1:55
"Common users" do not have PC3000 or Cleanroom and HDDSurgery WDC 2.5 "-3.5" Ramp Set.
PostPosted: September 22nd, 2014, 2:56
That's true, but he also admitted he's a "beginner". Which is fair enough, everyone has to start somewhere, but I wouldn't want a "beginner" working on my drive with my precious data on it.
So on this occasion, I advised outsourcing to an experienced lab.
PostPosted: September 22nd, 2014, 4:07
Negative.
I can smell 'things went bad with this drive' from down here.
PostPosted: September 22nd, 2014, 6:29
Hello on those zephyr drive physical headmap is trycky, preamp revision too
Just hope that you didn't scratch the platters by power up / down several times the HDD.
Not a easy drive to start with, in fact all customers drive are not good to start with, better to practice on stock HDD that you will kill for knowledge and practice.
Anyways Good Luck
Récupération de Données
PostPosted: September 22nd, 2014, 14:04
hello
Yes I am a beginner but I have experience in repair of laptop graphics chipset.
I try removing the drive head on a good hard drive similar but not the same PN. I walk up the drive head, there is no problem. Hard drive fonctione correctly.
With the advice of Mr lcoughey .I ordered another hard drive that is the same model and P / N and the same month and year.
I'll try and I'll keep you running.
Thank
Users browsing this forum: No registered users and 99 guests
