INVALID Cert Disk Code - ROM Resident Revision Required: AGM
September 22nd, 2014, 17:33
Hi, gurus:
I have been a litle ausent by staff problems but I'm
back now asking for help:
I have an HDD
Barracuda 7200.9 ST3500641AS 500GB HDD FW: 3.AGK
whit the terminal output:
4096k x 32 SDRAM
TONKA4D - 1_Disk 03-15-07_20 S-76: 16
Head Mask FFFF - Switch to full int.
spin Ready
(P) SATA Reset
$$$ Switch to full int.
AM reacquired
Not Interface Age!
INVALID Cert Disk Code - Revised Resident ROM Required: AGM6L0
Command Inactive - No VALID Cert Code Detected
T>
When input commands the same answer:
Any idea what it mean?
September 23rd, 2014, 16:45
vliriano wrote:I have an HDD Barracuda 7200.9 ST3500641AS 500GB HDD ...
Surface defects in the SA or damaged servolabels, probably due to the ageing. Also heads may be degraded.
And something wrong with the adaptives too (not good if as a result of previous incorrect data recovery attempts).
Not a walk in the park, I'd say.
Re: INVALID Cert Disk Code - ROM Resident Revision Required:
September 24th, 2014, 6:04
As Dmitri said you previously, hard case.
Problably bad headsm or bad media or FW problems, or all together.
is a hard case, no for DIY. if data important contact with a local pro.
