 Post subject: Current pending/Uncorrectable sector count on all drives...
PostPosted: September 25th, 2014, 10:30
I seem to be having problems with all my drives in a single computer.
I noticed last week since I was getting read errors trying to move files from those drives.
After running crystaldiskinfo I found out that my 3tb usb drive(3rd one in log below) had 73 current pending and uncorrectable sector count.
Tried chkdsk but it didn't fix the problem.
I resigned myself to replacing the drive, but before that, I did a full format(took about 30 hours).
After the format all errors were gone and the drive has been behaving just fine since then.(about 3 days)
Since then my 3 other drives on the system have been getting the same kind of errors too, they we're perfectly fine a week ago.
I have 2 listed below, the 3rd one is undergoing a full format and I have a feeling It'll be just fine after the format.
I'm having a hard time believing that all four drive witch were all bought at different times would all be failing at the same time.
I use that computer as a server, the drive contain media files(movies, tv show) and basically serves 2 HTPCs in the house.
I encode video with it too almost 24/7 for the last 4-5 months and sometimes it's used for light web browsing.
The 2 HTPCs and the server are networked using an ASUS GX-D1081 gigabit switch
I was suspecting a faulty RAM stick, I ran memtest and it ran just fine through a full pass.
What other avenues should I explore to fix my problem.
There seems like something else is going on here besides my drive all failing.
I was thinking maybe switching out the PSU next.
Any other ideas?
Thanks for taking the time to read this.
CrystalDiskInfo 6.2.1 Shizuku Edition (C) 2008-2014 hiyohiyo
                                Crystal Dew World : http://crystalmark.info/
    OS : Windows 7 Ultimate SP1 [6.1 Build 7601] (x64)
  Date : 2014/09/25 9:45:24
-- Controller Map ----------------------------------------------------------
+ Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller [ATA]
   - ATA WDC WD20EARX-008 SCSI Disk Device
   - ATA ST2000DL003-9VT1 SCSI Disk Device
   - HL-DT-ST DVDRAM GSA-H62N SCSI CdRom Device
-- Disk List ---------------------------------------------------------------
(1) WDC WD20EARX-008FB0 : 2000.3 GB [0/0/0, pd1] - wd
(2) ST2000DL003-9VT166 : 2000.3 GB [1/0/0, pd1] - st
(3) ST3000DM001-9YN166 : 3000.5 GB [2/X/X, sa1] (V=0BC2, P=3320) - st
           Model : WDC WD20EARX-008FB0
        Firmware : 51.0AB51
   Serial Number : WD-WCAZAJ856859
       Disk Size : 2000.3 GB (8.4/137.4/2000.3/2000.3)
     Buffer Size : Unknown
     Queue Depth : 32
    # of Sectors : 3907029168
   Rotation Rate : Unknown
       Interface : Serial ATA
   Major Version : ATA8-ACS
   Minor Version : ----
   Transfer Mode : SATA/600 | SATA/600
  Power On Hours : 14380 hours
  Power On Count : 57 count
     Temperature : 36 C (96 F)
   Health Status : Caution
        Features : S.M.A.R.T., 48bit LBA, NCQ
       APM Level : ----
       AAM Level : ----
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 200 200 _51 000000000000 Read Error Rate
03 189 184 _21 000000001584 Spin-Up Time
04 100 100 __0 000000000039 Start/Stop Count
05 200 200 140 000000000000 Reallocated Sectors Count
07 200 200 __0 000000000000 Seek Error Rate
09 _81 _81 __0 00000000382C Power-On Hours
0A 100 253 __0 000000000000 Spin Retry Count
0B 100 253 __0 000000000000 Recalibration Retries
0C 100 100 __0 000000000039 Power Cycle Count
C0 200 200 __0 00000000001E Power-off Retract Count
C1 __1 __1 __0 0000000AFE3E Load/Unload Cycle Count
C2 114 106 __0 000000000024 Temperature
C4 200 200 __0 000000000000 Reallocation Event Count
C5 200 200 __0 000000000001 Current Pending Sector Count
C6 200 200 __0 000000000001 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
C8 200 200 __0 000000000002 Write Error Rate
-- IDENTIFY_DEVICE ---------------------------------------------------------
        0    1    2    3    4    5    6    7    8    9
000: 427A 3FFF C837 0010 0000 0000 003F 0000 0000 0000  Bz?..7.......?......
010: 2020 2020 2057 442D 5743 415A 414A 3835 3638 3539       WD-WCAZAJ856859
020: 0000 0000 0000 3531 2E30 4142 3531 5744 4320 5744  ......51.0AB51WDC WD
030: 3230 4541 5258 2D30 3038 4642 3020 2020 2020 2020  20EARX-008FB0
040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 2F00                ..../.
050: 4001 0000 0000 0007 3FFF 0010 003F FC10 00FB 0110  @.......?....?......
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0000  ...........x.x.x.x..
070: 0000 0000 0000 0000 0000 001F 970E 0006 0044 0040  .................D.@
080: 01FE 0000 746B 7D61 4123 7469 BC41 4123 207F 009B  ....tk}aA#ti.AA# ...
090: 009B 0000 FFFE 0000 0000 0000 0000 0000 0000 0000  ....................
100: 88B0 E8E0 0000 0000 0000 0000 6003 0000 5001 4EE2  ............`...P.N.
110: B255 F04A 0000 0000 0000 0000 0000 0000 0000 401C  .U.J..............@.
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 0000  @................)..
130: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
140: 0000 0000 0004 0000 0000 0000 0000 0000 0000 0000  ....................
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
200: 0000 0000 0000 0000 0000 0000 30B5 0000 0000 4000  ............0.....@.
210: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
220: 0000 0000 103E 0000 0000 0000 0000 0000 0000 0000  .....>..............
230: 0000 0000 0000 0000 0001 1000 0000 0000 0000 0000  ....................
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
250: 0000 0000 0000 0000 0000 FFA5                      ............
-- SMART_READ_DATA ---------------------------------------------------------
     +0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 10 00 01 2F 00 C8 C8 00 00 00 00 00 00 00 03 27  .../...........'
010: 00 BD B8 84 15 00 00 00 00 00 04 32 00 64 64 39  ...........2.dd9
020: 00 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00  .......3........
030: 00 00 07 2E 00 C8 C8 00 00 00 00 00 00 00 09 32  ...............2
040: 00 51 51 2C 38 00 00 00 00 00 0A 32 00 64 FD 00  .QQ,8......2.d..
050: 00 00 00 00 00 00 0B 32 00 64 FD 00 00 00 00 00  .......2.d......
060: 00 00 0C 32 00 64 64 39 00 00 00 00 00 00 C0 32  ...2.dd9.......2
070: 00 C8 C8 1E 00 00 00 00 00 00 C1 32 00 01 01 3E  ...........2...>
080: FE 0A 00 00 00 00 C2 22 00 72 6A 24 00 00 00 00  .......".rj$....
090: 00 00 C4 32 00 C8 C8 00 00 00 00 00 00 00 C5 32  ...2...........2
0A0: 00 C8 C8 01 00 00 00 00 00 00 C6 30 00 C8 C8 01  ...........0....
0B0: 00 00 00 00 00 00 C7 32 00 C8 C8 00 00 00 00 00  .......2........
0C0: 00 00 C8 08 00 C8 C8 02 00 00 00 00 00 00 00 00  ................
0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
160: 00 00 00 00 00 00 00 00 00 00 82 00 10 77 01 7B  .............w.{
170: 03 00 01 00 02 FF 05 48 01 00 00 00 00 00 00 00  .......H........
180: 00 00 01 05 00 00 00 00 00 00 00 00 00 00 00 00  ................
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5C  ...............\
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 10 00 01 33 C8 C8 C8 C8 C8 00 00 00 00 00 03 15  ...3............
010: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00  ................
020: 00 00 00 00 00 00 05 8C 00 00 00 00 00 00 00 00  ................
030: 00 00 07 00 C8 C8 C8 C8 C8 00 00 00 00 00 09 00  ................
040: 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00  ................
050: 00 00 00 00 00 00 0B 00 00 00 00 00 00 00 00 00  ................
060: 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 C0 00  ................
070: 00 00 00 00 00 00 00 00 00 00 C1 00 00 00 00 00  ................
080: 00 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00  ................
090: 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 C5 00  ................
0A0: 00 00 00 00 00 00 00 00 00 00 C6 00 00 00 01 00  ................
0B0: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00  ................
0C0: 00 00 C8 00 C8 C8 C8 C8 C8 00 00 00 00 00 00 00  ................
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04  ................
           Model : ST2000DL003-9VT166
        Firmware : CC32
   Serial Number : 6YD0G63A
     Queue Depth : 32
   Rotation Rate : 5900 RPM
   Minor Version : ATA8-ACS version 4
  Power On Hours : 32948 hours
  Power On Count : 231 count
     Temperature : 42 C (107 F)
        Features : S.M.A.R.T., AAM, 48bit LBA, NCQ
       APM Level : ----
       AAM Level : FE00h [ON]
01 111 _87 __6 00000273F208 Read Error Rate
03 _93 _92 __0 000000000000 Spin-Up Time
04 100 100 _20 000000000257 Start/Stop Count
05 100 100 _36 000000000000 Reallocated Sectors Count
07 _78 _60 _30 000004E781D6 Seek Error Rate
09 _63 _63 __0 0000000080B4 Power-On Hours
0A 100 100 _97 000000000000 Spin Retry Count
0C 100 100 _20 0000000000E7 Power Cycle Count
B7 100 100 __0 000000000000 Vendor Specific
B8 100 100 _99 000000000000 End-to-End Error
BB __1 __1 __0 00000000013D Reported Uncorrectable Errors
BC 100 _99 __0 00000000000F Command Timeout
BD _99 _99 __0 000000000001 High Fly Writes
BE _58 _52 _45 00002F29002A Airflow Temperature
BF 100 100 __0 000000000000 G-Sense Error Rate
C0 100 100 __0 000000000095 Power-off Retract Count
C1 100 100 __0 00000000025B Load/Unload Cycle Count
C2 _42 _48 __0 00120000002A Temperature
C3 _29 __6 __0 00000273F208 Hardware ECC recovered
C5 100 100 __0 000000000018 Current Pending Sector Count
C6 100 100 __0 000000000018 Uncorrectable Sector Count
C7 200 200 __0 000000000002 UltraDMA CRC Error Count
F0 100 253 __0 02D7000053DD Head Flying Hours
F1 100 253 __0 0000DBB35186 Total Host Writes
F2 100 253 __0 0000982127DF Total Host Reads
        0    1    2    3    4    5    6    7    8    9
000: 0C5A 3FFF C837 0010 0000 0000 003F 0000 0000 0000  .Z?..7.......?......
010: 2020 2020 2020 2020 2020 2020 3659 4430 4736 3341              6YD0G63A
020: 0000 0000 0004 4343 3332 2020 2020 5354 3230 3030  ......CC32    ST2000
030: 444C 3030 332D 3956 5431 3636 2020 2020 2020 2020  DL003-9VT166
040: 2020 2020 2020 2020 2020 2020 2020 8010 4000 2F00                ..@./.
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0110  @.......?....?......
070: 0000 0000 0000 0000 0000 001F 850E 0006 0048 0040  .................H.@
080: 01F0 0029 346B 7F01 4163 3469 BE01 4163 207F 00A0  ...)4k..Ac4i..Ac ...
090: 00A0 0000 FFFE 0000 FE00 0000 0000 0000 0000 0000  ....................
100: 88B0 E8E0 0000 0000 0000 0000 0000 0000 5000 C500  ................P...
110: 370B 3187 0000 0000 0000 0000 0000 0000 0000 401E  7.1...............@.
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 88B0  @................)..
130: E8E0 88B0 E8E0 2020 0002 0140 0100 5000 3C06 3C0A  ......  ...@..P.<.<.
140: 0000 003C 0000 0008 0000 0000 007F 0280 0000 0000  ...<................
150: 0008 0000 0000 0000 0000 0000 0000 0000 4F00 8980  ................O...
200: 0000 0000 0000 0000 0000 0000 30B7 0000 0000 0000  ............0.......
210: 0000 0000 0000 0000 0000 0000 0000 170C 0000 0000  ....................
220: 0000 0000 1020 0000 0000 0000 0000 0000 0000 0000  ..... ..............
230: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
250: 0000 0000 0000 0000 0000 84A5                      ............
000: 0A 00 01 0F 00 6F 57 08 F2 73 02 00 00 00 03 03  .....oW..s......
010: 00 5D 5C 00 00 00 00 00 00 00 04 32 00 64 64 57  .]\........2.ddW
020: 02 00 00 00 00 00 05 33 00 64 64 00 00 00 00 00  .......3.dd.....
030: 00 00 07 0F 00 4E 3C D6 81 E7 04 00 00 00 09 32  .....N<........2
040: 00 3F 3F B4 80 00 00 00 00 00 0A 13 00 64 64 00  .??..........dd.
050: 00 00 00 00 00 00 0C 32 00 64 64 E7 00 00 00 00  .......2.dd.....
060: 00 00 B7 32 00 64 64 00 00 00 00 00 00 00 B8 32  ...2.dd........2
070: 00 64 64 00 00 00 00 00 00 00 BB 32 00 01 01 3D  .dd........2...=
080: 01 00 00 00 00 00 BC 32 00 64 63 0F 00 00 00 00  .......2.dc.....
090: 00 00 BD 3A 00 63 63 01 00 00 00 00 00 00 BE 22  ...:.cc........"
0A0: 00 3A 34 2A 00 29 2F 00 00 00 BF 32 00 64 64 00  .:4*.)/....2.dd.
0B0: 00 00 00 00 00 00 C0 32 00 64 64 95 00 00 00 00  .......2.dd.....
0C0: 00 00 C1 32 00 64 64 5B 02 00 00 00 00 00 C2 22  ...2.dd[......."
0D0: 00 2A 30 2A 00 00 00 12 00 00 C3 1A 00 1D 06 08  .*0*............
0E0: F2 73 02 00 00 00 C5 12 00 64 64 18 00 00 00 00  .s.......dd.....
0F0: 00 00 C6 10 00 64 64 18 00 00 00 00 00 00 C7 3E  .....dd........>
100: 00 C8 C8 02 00 00 00 00 00 00 F0 00 00 64 FD DD  .............d..
110: 53 00 00 D7 02 1A F1 00 00 64 FD 86 51 B3 DB 00  S........d..Q...
120: 00 00 F2 00 00 64 FD DF 27 21 98 00 00 00 00 00  .....d..'!......
160: 00 00 00 00 00 00 00 00 00 00 82 00 64 02 00 7B  ............d..{
170: 03 00 01 00 01 FF 02 4E 01 00 00 00 00 00 00 00  .......N........
180: 00 00 00 00 00 00 00 00 03 07 07 07 07 07 07 07  ................
190: 07 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00  ................
1A0: 00 00 00 00 00 00 00 00 F5 08 41 BD E6 6B 00 00  ..........A..k..
1B0: 00 00 00 00 01 00 FE 48 86 51 B3 DB C5 B5 02 00  .......H.Q......
1C0: DF 27 21 98 BF 39 02 00 00 00 00 00 7B 1A 7A 0A  .'!..9......{.z.
1D0: 00 00 00 04 00 00 00 00 BD 0D 00 00 4A 00 06 00  ............J...
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 34  ...............4
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 42  ...............B
000: 01 00 01 06 00 00 00 00 00 00 00 00 00 00 03 00  ................
010: 00 00 00 00 00 00 00 00 00 00 04 14 00 00 00 00  ................
020: 00 00 00 00 00 00 05 24 00 00 00 00 00 00 00 00  .......$........
030: 00 00 07 1E 00 00 00 00 00 00 00 00 00 00 09 00  ................
040: 00 00 00 00 00 00 00 00 00 00 0A 61 00 00 00 00  ...........a....
050: 00 00 00 00 00 00 0C 14 00 00 00 00 00 00 00 00  ................
060: 00 00 B7 00 00 00 00 00 00 00 00 00 00 00 B8 63  ...............c
070: 00 00 00 00 00 00 00 00 00 00 BB 00 00 00 00 00  ................
080: 00 00 00 00 00 00 BC 00 00 00 00 00 00 00 00 00  ................
090: 00 00 BD 00 00 00 00 00 00 00 00 00 00 00 BE 2D  ...............-
0A0: 00 00 00 00 00 00 00 00 00 00 BF 00 00 00 00 00  ................
0B0: 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00  ................
0C0: 00 00 C1 00 00 00 00 00 00 00 00 00 00 00 C2 00  ................
0D0: 00 00 00 00 00 00 00 00 00 00 C3 00 00 00 00 00  ................
0E0: 00 00 00 00 00 00 C5 00 00 00 00 00 00 00 00 00  ................
0F0: 00 00 C6 00 00 00 00 00 00 00 00 00 00 00 C7 00  ................
100: 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00  ................
110: 00 00 00 00 00 00 F1 00 00 00 00 00 00 00 00 00  ................
120: 00 00 F2 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20  ...............
       Enclosure : Seagate Expansion Desk USB Device (V=0BC2, P=3320, sa1) - st
           Model : ST3000DM001-9YN166
        Firmware : CC9F
   Serial Number : Z1F1GBHW
       Disk Size : 3000.5 GB (8.4/137.4/3000.5/3000.5)
     Queue Depth : 32
    # of Sectors : 5860533168
   Rotation Rate : 7200 RPM
       Interface : USB (Serial ATA)
   Transfer Mode : SATA/300 | SATA/600
  Power On Hours : 12113 hours
  Power On Count : 69 count
     Temperature : 47 C (116 F)
   Health Status : Good
        Features : S.M.A.R.T., APM, 48bit LBA, NCQ
       APM Level : 8080h [ON]
       AAM Level : ----
01 114 _91 __6 000004967FE0 Read Error Rate
04 100 100 _20 000000000069 Start/Stop Count
07 _65 _60 _30 0000003022F3 Seek Error Rate
09 _87 _87 __0 000000002F51 Power-On Hours
0C 100 100 _20 000000000045 Power Cycle Count
BB __1 __1 __0 0000000000C6 Reported Uncorrectable Errors
BC 100 _99 __0 000100010001 Command Timeout
BD _98 _98 __0 000000000002 High Fly Writes
BE _53 _32 _45 0676342A002F Airflow Temperature
C0 100 100 __0 000000000031 Power-off Retract Count
C1 _99 _99 __0 000000000A6E Load/Unload Cycle Count
C2 _47 _68 __0 00120000002F Temperature
C5 100 100 __0 000000000000 Current Pending Sector Count
C6 100 100 __0 000000000000 Uncorrectable Sector Count
F0 100 253 __0 DDDD00000490 Head Flying Hours
F1 100 253 __0 007D7D355669 Total Host Writes
F2 100 253 __0 002DE0BCD2D4 Total Host Reads
        0    1    2    3    4    5    6    7    8    9
010: 2020 2020 2020 2020 2020 2020 5A31 4631 4742 4857              Z1F1GBHW
020: 0000 0000 0004 4343 3946 2020 2020 5354 3330 3030  ......CC9F    ST3000
030: 444D 3030 312D 3959 4E31 3636 2020 2020 2020 2020  DM001-9YN166
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0010  @.......?....?......
070: 0000 0000 0000 0000 0000 001F 850E 0004 004C 0040  .................L.@
080: 01F0 0029 346B 7D09 4123 3469 BC09 4123 407F 00A0  ...)4k}.A#4i..A#@...
090: 00A0 8080 FFFE 0000 D000 0000 0000 0000 0000 0000  ....................
100: A3B0 5D50 0001 0000 0000 0000 6003 0000 5000 C500  ..]P........`...P...
110: 4EBB B92D 0000 0000 0000 0000 0000 0000 0000 401E  N..-..............@.
120: 401C 0000 0000 0000 0000 0000 0000 0000 0021 A3B0  @................!..
130: 5D50 A3B0 5D50 2020 0002 0140 0100 5000 3C06 3C0A  ]P..]P  ...@..P.<.<.
150: 0008 0000 0000 0000 0000 0000 0000 0000 5800 88E0  ................X...
200: 0000 0000 0000 0000 0000 0000 3081 0000 0000 4000  ............0.....@.
210: 0000 0000 0000 0000 0000 0000 0000 1C20 0000 0000  ............... ....
250: 0000 0000 0000 0000 0000 DCA5                      ............
000: 0A 00 01 0F 00 72 5B E0 7F 96 04 00 00 00 03 03  .....r[.........
010: 00 5D 5C 00 00 00 00 00 00 00 04 32 00 64 64 69  .]\........2.ddi
020: 00 00 00 00 00 00 05 33 00 64 64 00 00 00 00 00  .......3.dd.....
030: 00 00 07 0F 00 41 3C F3 22 30 00 00 00 00 09 32  .....A<."0.....2
040: 00 57 57 51 2F 00 00 00 00 00 0A 13 00 64 64 00  .WWQ/........dd.
050: 00 00 00 00 00 00 0C 32 00 64 64 45 00 00 00 00  .......2.ddE....
070: 00 64 64 00 00 00 00 00 00 00 BB 32 00 01 01 C6  .dd........2....
080: 00 00 00 00 00 00 BC 32 00 64 63 01 00 01 00 01  .......2.dc.....
090: 00 00 BD 3A 00 62 62 02 00 00 00 00 00 00 BE 22  ...:.bb........"
0A0: 00 35 20 2F 00 2A 34 76 06 00 BF 32 00 64 64 00  .5 /.*4v...2.dd.
0B0: 00 00 00 00 00 00 C0 32 00 64 64 31 00 00 00 00  .......2.dd1....
0C0: 00 00 C1 32 00 63 63 6E 0A 00 00 00 00 00 C2 22  ...2.ccn......."
0D0: 00 2F 44 2F 00 00 00 12 00 00 C5 12 00 64 64 00  ./D/.........dd.
0E0: 00 00 00 00 00 00 C6 10 00 64 64 00 00 00 00 00  .........dd.....
0F0: 00 00 C7 3E 00 C8 C8 00 00 00 00 00 00 00 F0 00  ...>............
100: 00 64 FD 90 04 00 00 DD DD 26 F1 00 00 64 FD 69  .d.......&...d.i
110: 56 35 7D 7D 00 00 F2 00 00 64 FD D4 D2 BC E0 2D  V5}}.....d.....-
160: 00 00 00 00 00 00 00 00 00 00 00 00 48 02 00 73  ............H..s
180: 00 00 00 00 78 01 00 00 01 08 08 06 08 08 08 08  ....x...........
190: 05 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00  ................
1A0: 00 00 00 00 00 00 0A 00 4B 7B 66 BC A9 27 00 00  ........K{f..'..
1B0: 00 00 00 00 01 00 17 00 69 56 35 7D 7D 00 00 00  ........iV5}}...
1C0: D4 D2 BC E0 2D 00 00 00 00 00 00 00 00 00 00 00  ....-...........
1D0: 00 00 00 03 00 00 00 00 4C 00 00 00 01 00 00 00  ........L.......
1E0: 00 00 00 00 90 3F 03 00 00 00 00 00 00 00 00 03  .....?..........
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 94  ................
0D0: 00 00 00 00 00 00 00 00 00 00 C5 00 00 00 00 00  ................
0E0: 00 00 00 00 00 00 C6 00 00 00 00 00 00 00 00 00  ................
0F0: 00 00 C7 00 00 00 00 00 00 00 00 00 00 00 F0 00  ................
100: 00 00 00 00 00 00 00 00 00 00 F1 00 00 00 00 00  ................
110: 00 00 00 00 00 00 F2 00 00 00 00 00 00 00 00 00  ................
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E3  ................
Users browsing this forum: No registered users and 38 guests
