 Post subject: Samsung HD502HJ - demaged ROM finding donor PCB
PostPosted: October 13th, 2014, 9:37
Hello!
I've got a 500GB Samsung HD502HJ with burned transil 6V8A,
(visually transil looks ok, but was shorted - tested by multimeter).
I have changed broken transil and tried to run HDD - nothing happened - no spin,
so I swapped ROM to donor PCB, also nothing happened.
In my opinion the ROM is dead.
Is there any possibility to find donor PCB with the same content of ROM?
 Post subject: Re: Samsung HD502HJ - demaged ROM finding donor PCB
PostPosted: October 13th, 2014, 15:11
Did you check the zero-ohm resistor on the original PCB?
http://www.users.on.net/~fzabkar/HDD/HD103SJ_TVS_2.jpg
Do you have any way of reading the ROM? Perhaps it was damaged during the transfer.
PostPosted: October 14th, 2014, 5:57
zero - ohm resistor is OK - conducts.
ROM was transferred under temp. control on BGA rework station.
ROM from donor PCB was soldered back, donor drive is still alive.
I will try to read ROM in some programmer.
PostPosted: October 14th, 2014, 15:42
Does the donor PCB with donor ROM spin up the patient HDD?
Can you get a terminal log?
PostPosted: October 18th, 2014, 9:50
Yes it does, patient HDD spin up with donor PCB + donor ROM.
PostPosted: October 18th, 2014, 18:05
How to connect a terminal cable on a Samsung drive:
http://www.alexsoft.org/viewtopic.php?f=116&t=189
PostPosted: November 22nd, 2014, 8:28
Problem solved
I found donor with compatible ROM - only PCB swap.
Users browsing this forum: No registered users and 67 guests
