Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: WDC WD3200BPVT-22JJ5T0 - disk automatically goes to sleep?
PostPosted: September 15th, 2014, 3:50
I test my new HDD with WinXP SP2 x86 and also WinXP SP x64. In both OS disk behaves in the same way. Go to sleep (parks head) after some seconds of inactivity. Because if the HDD is inactive for more than some seconds it needs to unpark its head, and that creates a very noticeable lag when launching applications or working with files because the process takes a few seconds to complete.
The systems are newly installed, SMART status GOOD.
On the internet I found similar opinions on this or similar model WD:
This means that it is probably a bug in the firmware.
I have also similar model WDC WD3200BEVT-22ZCT0 and this works well.
Firmware WDC WD3200BPVT-22JJ5T0 -> 01.01A01
Firmware WDC WD3200BEVT-22ZCT0 -> 11.01A11
I wonder if it would be helpful to update the firmware from version BEVT to BPVT?
 Post subject: Re: WDC WD3200BPVT-22JJ5T0 - disk automatically goes to slee
PostPosted: October 6th, 2014, 19:33
I doubt it has anything to do with drive firmware. Probably is a setting in your BIOS.
PostPosted: October 6th, 2014, 19:44
It could be an APM setting or the idle3 timer.
http://sourceforge.net/projects/apmtimer/
http://idle3-tools.sourceforge.net/
http://www.alexsoft.org/viewtopic.php?f=36&t=125&p=153
A possible workaround is quietHDD:
https://sites.google.com/site/quiethdd/
PostPosted: October 6th, 2014, 19:51
Could be. I'd still check BIOS first.
PostPosted: October 6th, 2014, 21:46
@hdd12, you could use SeDiv to retrieve the resources (ROM and SA firmware) for your two drives.
http://sediv2008.narod.ru/Easy3.9Passwo ... 567890.rar
http://sediv2008.narod.ru/Settings.rar
We could then compare the contents of MOD 02. That's where the timer values are stored.
PostPosted: October 8th, 2014, 1:07
OK, quiedHDD resolve problem :-)
"wdidle3" detect HDD, display and set Idle Timer but this does not affect the operation of the disk.
PostPosted: October 8th, 2014, 2:39
The APMtimer project should provide a nonvolatile solution to your APM problem. You would need to execute it from a Linux platform, though.
PostPosted: October 8th, 2014, 4:40
OK, but on http://sourceforge.net/projects/apmtimer/ writes that this tool is made for Western Digital 2.5 WD*PVX Hard Disks
Are you sure I can use this program with my drive BPVT?
I not understand how work this tools?
I know there is such a thing as PCI Configuration Space where various parameters are set PCI devices are on only until you cold start the computer.
AFAIK, PC BIOS e.g. AWARD can set some PCI config space of some PCI devices (e.g. write protect off for programming BIOS chip with AWDFLASH) - as a result, every time you start your computer (even cold) setting write protect off is set.
quietHDD set APM whenever boot OS WinXP
Where APMtimer store settings?
PostPosted: October 8th, 2014, 6:42
I test APMtimer. I have to say that it does not solve the problem :(
APMtimer works like wdidle3 - read, set and disable timer but this not affect the operation of the disk :( and heads still parking - of course in WinXP
root@debian:~# hdparm -I /dev/sda | grep "Advanced power"
   Advanced power management level: 96
root@debian:~# ./apmtimer -g /dev/sda
APM timer is disabled
Only quietHDD initiated over 'Run' registry key in WinXP resolve problem.
Maybe tools 'wdidle3' and 'apmtimer' work only on systems for which they were created - DOS and Linux?
PostPosted: October 15th, 2014, 10:10
They patch the firmware of your hard disk and it's persistent across OSes.
It appears that your APM is still at 0x96 despite having the timer removed. I only managed to test with a limited number of hard disks when I wrote the program. I still remember there is an additional 2 bytes after the timer (Franc if you still remember, initially I said 32 bits, and then later on I changed to 16 bits) that is related to spin-down, and if they're non 0x0000, APM goes to 0x96.
I do not have any WD3200B*VT to test with. My WD3200BEKT shows 0x00000000 in the APM location. My old WD5000BEVT made in 2010 does not have this setting while a WD5000BPVT made in 2012 also show 0x00000000. First 2 bytes are timer, last 2 bytes are spin-down.
It'd be very useful if you could dump out your Mod02 (you can mask your serial number) for us. And listen to your hard disk carefully to see how long it takes after the last access on the hard disk before you hear the minor click.
PostPosted: October 15th, 2014, 22:42
The closest I could find, http://files.hddguru.com/download/Non-P ... 4K%20ROYL/ shows only the timer present @ 0353h, 0xC8 == 200 ms
PostPosted: October 16th, 2014, 8:56
I dump (ModuleByID 0002.bin) of my disk. In offset 353 is BA value (186 DEC)
0002.zip [1002 Bytes]
Downloaded 1229 times
PostPosted: October 16th, 2014, 12:22
No, you shouldn't compare your offset with the one from a different hard disk. The one I gave is only applicable for that hard disk. From what I've learned, even hard disks with the exact same model could have different Mod contents and size.
Anyway, for your Mod 02, I can see that there is no APM timer nor spin down (03A8h-03ABh). Do you remember if there was any value before you patched it?
Your Idle3 has a value of 0x50 (offset 0388h) == 80 == 8.0 seconds. You might want to consider patching it with wdidle3.exe or idle3-tools and see if the intellipark feature gets disabled. And of course share with us if the APM goes to 0x80 after that.
Some corrections to my earlier comments :
1. 0x96 should be stated as 0x60 (96 decimal, not 96 hex). If you get 0x80 (== 128 decimal) then the intellipark feature should be disabled.
2. 200 ms should be stated as 20.0 seconds
PostPosted: October 16th, 2014, 19:17
When purchase the hard drive I changed the value of Idle Timer several times with wdidle3. The default value of Idle Timer was 3.000 s. I changed to 60s, disable and now set to 8s because this is the minimum that can be set using wdidle3:
wdidle3 /s8
Next i use APMtimer to disable APM timer:
root@debian:~# ./apmtimer -d /dev/sda
PostPosted: October 16th, 2014, 20:57
Yours seems pretty unique to have 3 seconds for idle3.
Can you help to observe how long it takes before the hard disk goes to sleep? Access the hard disk, listen and start counting (check your computer's clock) until it goes to sleep.
PostPosted: October 16th, 2014, 21:59
OK, but I have to turn off the first quietHDD. I use hdparm for Windows:
hdparm -i /dev/hda
  • while quietHDD working in tray, heads no parking:
    AdvancedPM=yes: disabled (255) WriteCache=enabled
  • exit quietHDD and restart Windows, heads still no parking:
  • power OFF PC and power ON after few minutes, heads parking after 8 or 20 sec. and APM is unknown:
    AdvancedPM=yes: unknown setting WriteCache=enabled
PostPosted: October 16th, 2014, 22:02
8 seconds should be due to idle3. So you need to disable it first and then repeat the test again. You need a power-cycle the hard disk (or computer) before these settings take effect.
Can you check the APM again after that, and if it's still unknown, try with Unix.
PostPosted: October 16th, 2014, 23:39
After disable Idle Timer with wdidle3, power OFF and power ON PC hdparm still display unknown APM:
Exactly the same shows hdparm in Windows and Debian - unknown setting
Heads parking about 20 sec. after idle time.
PostPosted: October 17th, 2014, 1:15
Thanks. I'll have to inspect your Mod 02 further to see what else can we do.
Do you recall the value of "apmtimer -g" before you made any changes? If we can undo that change, you should get back your APM value.
PostPosted: October 17th, 2014, 2:34
I do not remember, unfortunately, probably 127 or 128, I'm not sure. hdparm -i /dev/hda display the same value APM that set quietHDD but APMtimer set other APM value - right?
Users browsing this forum: No registered users and 58 guests
