 Post subject: Samsung ST1000LM024 Head Replacement Matching Specs
PostPosted: October 30th, 2014, 18:24
Bit confusing. I presume you need:-
Model
P/N
Site and DOM if possible
But are the three digits after the P/N required eg: HH-M101BMM/AVN
There are drives who's three digits are very close ie AV2 are these a match?
There are drives with no digits after the P/N, so are those a match?
Advice would be appreciated.
 Post subject: Re: Samsung ST1000LM024 Head Replacement Matching Specs
PostPosted: October 31st, 2014, 7:14
i think that if you match 3 frist characters from S/n is enaugth
PostPosted: October 31st, 2014, 9:03
This is a Samsung drive rebranded as Seagate...you must follow Samsung matching protocols.
PostPosted: October 31st, 2014, 18:24
The matching protocols I have (via Donor Drives) are a little unclear with how it relates to this drive
Full Model # - Yes I get that
Bar Code Side - whatever that means.
Firmware if possible?
PostPosted: October 31st, 2014, 18:36
Sorry Luke is on true.
PostPosted: November 5th, 2014, 11:22
These drives do not have the 5 digit code that is usually detailed under the bar code. So these are a little different. According to Donor Drives you need to match the three letters after the model number. So for this drive (with no firmware detailed) the matching criteria is ST1000LM024/AVN.
PostPosted: November 5th, 2014, 14:47
HH-M101BMM, plus same country plus same Seagate model will get you a good match.
Recuperacion De Datos Dominican Republic
PostPosted: November 6th, 2014, 4:40
Try match the PCB printed number and rev code
Users browsing this forum: Bing [Bot] and 53 guests
