Looking for loader/mod 11 version 3006G Firebird
November 5th, 2014, 8:47
anyone has this?
thank you
Re: Looking for loader/mod 11 version 3006G Firebird
November 5th, 2014, 9:52
Here it is....
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 4
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1420
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM version............................. : 03.6GB
>ROM generation.......................... : 03.6HB
>Link table version...................... : TP.46.
>Consolidated ROM version................ : 0003006G
>ROM Modules:
>Flash ROM dir reading................... : Ok (Active)
>Flash ROM dir reading (Ext)............. : Ok
>Modules directory address............... : 70 342
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 4
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,3
>ROM Firmware version.................... : 00030052
>Service area:
>Permanent overlay....................... : Loaded
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
11.rar
(383.31 KiB) Downloaded 394 times
November 5th, 2014, 9:53
Try firmware finder with Ultratec UK or datarecoverydonors.com - firmware section.
November 6th, 2014, 5:55
thanks pcimage
