 Post subject: HN-M101ABB/EX2
PostPosted: November 12th, 2014, 8:39
Hello! :mrgreen:
IS RPM 0.
No donor...
Is donor pcb HN-M101MBB/EX2 compatible? Possible?
Is edit id pcb?
Thanks!
Нет ничего невозможного
 Post subject: Re: HN-M101ABB/EX2
PostPosted: November 12th, 2014, 10:17
RPM 0, as in it doesn't spin up?
PostPosted: November 12th, 2014, 12:26
Yes! :mrgreen:
PostPosted: November 12th, 2014, 17:04
Did you check the +5V supply at the rear of the PCB? AFAICT, there is a zero-ohm resistor, inductor, and TVS diode (?). I have seen several cases where the chip inductor is affected by a dry solder joint.
Did you also check the serial terminal output?
PostPosted: November 13th, 2014, 7:08
will check..
Thanks reply!!! :mrgreen:
