 Post subject: WD SADLE G6 not Detecting / Loading modules
PostPosted: November 19th, 2014, 2:11
I have a WD SADLE G6 2 Tb and its not detecting or giving id or loading Modules.
SA Structure test in PC 3K gives following results.
help appreciated
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 6
Cyl Count............................... : 256
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 25.12E
ROM generation.......................... : 25.12E
Link table version...................... : 0B.36.
Consolidated ROM version................ : 00250012
ROM Modules:
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 377 653
SA Translator loading................... : Ok
Heads configuration..................... : by map
Heads number in use..................... : 6
Switched off heads...................... : No
Heads map............................... : 0,1,2,5,6,7
ROM Firmware version.................... : 00250012
Service area:
Permanent overlay....................... : Not loaded
SA dir reading (ID)..................... : Ok
SA Access............................... : NONE
Configuration reading................... : No SA copy avalabled
SA structure test
Module 0001............................. : Ok
Module 0035............................. : Ok
Module 3604............................. : Ok
Module 0110............................. : Ok
Module 0102............................. : Ok
Module 0103............................. : Ok
Module 0104............................. : Ok
Module 0105............................. : Ok
Module 0106............................. : Ok
Module 0108............................. : Ok
Module 0002............................. : Ok
Module 0017............................. : Ok
Module 001C............................. : Ok
Module 0014............................. : Ok
Module 0015............................. : Ok
Module 001E............................. : Ok
Module 002F............................. : Ok
Module 002A............................. : Ok
Module 0021............................. : Ok
Module 0023............................. : Ok
Module 0024............................. : Ok
Module (0011) read error Module ID 11 reading error Data request error - Device Error Detected: "FM ERR CHECKSUM"
Module 0011............................. : Error
Module 0019............................. : Ok
Module 0012............................. : Ok
Module 0050............................. : Ok
Module 0051............................. : Ok
Module (0052) read error Module ID 52 reading error Data request error - Device Error Detected: "FM ERR CHECKSUM"
Module 0052............................. : Error
Module (0053) read error Module ID 53 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module 0053............................. : Error
Module 0109............................. : Ok
Module 0061............................. : Ok
Module 0062............................. : Ok
Module 001F............................. : Ok
Module 006E............................. : Ok
Module 0116............................. : Ok
Module 0118............................. : Ok
Module AC55............................. : Ok
Module 4002............................. : Ok
Module 006D............................. : Ok
Module 0122............................. : Ok
Module 005C............................. : Ok
Module (0033) read error Module ID 33 reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 0033............................. : Error
Module (0031) read error Module ID 31 reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 0031............................. : Error
Module 000C............................. : Ok
Module 0034............................. : Ok
Module 0032............................. : Ok
Module 0036............................. : Ok
Module 0029............................. : Ok
Module 0040............................. : Ok
Module 0041............................. : Ok
Module 0042............................. : Ok
Module 0043............................. : Ok
Module 004E............................. : Ok
Module 0049............................. : Ok
Module 004A............................. : Ok
Module 004D............................. : Ok
Module 0003............................. : Ok
Module 0025............................. : Ok
Module 0026............................. : Ok
Module (0038) read error Module ID 38 reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 0038............................. : Error
Module 0039............................. : Ok
Module 0037............................. : Ok
Module 002D............................. : Ok
Module 002E............................. : Ok
Module (00B5) read error Module ID B5 reading error Data request error - Device Error Detected: "FM ERR CHECKSUM"
Module 00B5............................. : Error
Module (006B) read error Module ID 6B reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module 006B............................. : Error
Module (003A) read error Module ID 3A reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module 003A............................. : Error
[color=#FF0000][color=#FF0000][color=#FF0000]Module (0028) read error Module ID 28 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module 0028............................. : Error
Module (003B) read error Module ID 3B reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module 003B............................. : Error
Module (003C) read error Module ID 3C reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module 003C............................. : Error
Module (003D) read error Module ID 3D reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module 003D............................. : Error
Module (003E) read error Module ID 3E reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module 003E............................. : Error
Module (003F) read error Module ID 3F reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module 003F............................. : Error
Module (006F) read error Module ID 6F reading error Data request error - Device Error Detected: "DISK DAM ERROR"
[/color][/color][/color]
Module 006F............................. : Error
Module 0119............................. : Ok
Module 0068............................. : Ok
Module 0069............................. : Ok
Module 006A............................. : Ok
Module 0121............................. : Ok
Module 0128............................. : Ok
Module 0120............................. : Ok
Module (012D) read error Module ID 12D reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 012D............................. : Error
[color=#FF0000]Module (0004) read error Module ID 04 reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 0004............................. : Error
Module (0005) read error Module ID 05 reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 0005............................. : Error
[/color]
[color=#FF0000]Module (0115) read error Module ID 115 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module 0115............................. : Error
[color=#FF0000]Module (3700) read error Module ID 3700 reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 3700............................. : Error
[/color][/color]
Module 00DE............................. : Ok
Module 00B6............................. : Ok
Module 00D5............................. : Ok
Module 3411............................. : Ok
Module 00D1............................. : Ok
Module 00DB............................. : Ok
Module 00DF............................. : Ok
Module 00DD............................. : Ok
Module (3402) read error Module ID 3402 reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 3402............................. : Error
Module 00D7............................. : Ok
Module 00D2............................. : Ok
Module 3300............................. : Ok
Module 3301............................. : Ok
Module 3303............................. : Ok
Module 3500............................. : Ok
Module 00BB............................. : Ok
Module 3400............................. : Ok
Module 3407............................. : Ok
Module (3405) read error Module ID 3405 reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 3405............................. : Error
Module 00D9............................. : Ok
Module 00D4............................. : Ok
Module 00DC............................. : Ok
Module (00D0) read error Module ID D0 reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 00D0............................. : Error
Module 00D3............................. : Ok
Module 00F7............................. : Ok
Module 00BA............................. : Ok
Module 3406............................. : Ok
Module 00B9............................. : Ok
Module 00BC............................. : Ok
Module (3417) read error Module ID 3417 reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 3417............................. : Error
Module 00D8............................. : Ok
Module 00BD............................. : Ok
Module 00BE............................. : Ok
Module 3401............................. : Ok
Module 3302............................. : Ok
Module 3304............................. : Ok
Module 3501............................. : Ok
Module 3502............................. : Ok
Module 3416............................. : Ok
Module 3F01............................. : Ok
Module 00B8............................. : Ok
Module 00BF............................. : Ok
Module 00E6............................. : Ok
Module 00E7............................. : Ok
Module 34E7............................. : Ok
Module 00B7............................. : Ok
Module 00FA............................. : Ok
Module 00FC............................. : Ok
Module 00FD............................. : Ok
Module 00EE............................. : Ok
Module 3E00............................. : Ok
Module 3801............................. : Ok
Module 3C00............................. : Ok
Module (3415) read error Module ID 3415 reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 3415............................. : Error
Module 3418............................. : Ok
Module 3423............................. : Ok
Module 3422............................. : Ok
Module 3421............................. : Ok
Module 3428............................. : Ok
Module 3F00............................. : Ok
Module 00C4............................. : Ok
Module 00A2............................. : Ok
Module 00C5............................. : Ok
Module 00C3............................. : Ok
Module 00C8............................. : Ok
Module 2900............................. : Ok
Module 2901............................. : Ok
Module 2909............................. : Ok
Module 290A............................. : Ok
Module 0091............................. : Ok
Module 00AE............................. : Ok
Module 2903............................. : Ok
Module 00CC............................. : Ok
Module 00CA............................. : Ok
Module 0099............................. : Ok
Module 0098............................. : Ok
Module 00CF............................. : Ok
Module 00CE............................. : Ok
Module 0093............................. : Ok
Module 00C1............................. : Ok
Module 00C2............................. : Ok
Module 00C7............................. : Ok
Module 009E............................. : Ok
Module 00C6............................. : Ok
Module 00C9............................. : Ok
Module 0094............................. : Ok
Module 0096............................. : Ok
Module 0097............................. : Ok
Module 00AA............................. : Ok
Module 00A9............................. : Ok
Module 00AC............................. : Ok
Module 2904............................. : Ok
Module 2802............................. : Ok
Module 2A02............................. : Ok
Module 00A5............................. : Ok
Module 2FF0............................. : Ok
Module 280A............................. : Ok
Module 00A0............................. : Ok
Module 009A............................. : Ok
Module (009C) read error Module ID 9C reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module 009C............................. : Error
Module (00AF) read error Module ID AF reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module 00AF............................. : Error
Module 2000............................. : Ok
Module 2001............................. : Ok
Module 2002............................. : Ok
Module 2003............................. : Ok
Module 2004............................. : Ok
Module 2005............................. : Ok
Module 2006............................. : Ok
Module 2007............................. : Ok
Module 2020............................. : Ok
Module 2021............................. : Ok
Module 2022............................. : Ok
Module 2023............................. : Ok
Module 2024............................. : Ok
Module 2025............................. : Ok
Module 2026............................. : Ok
Module 2027............................. : Ok
Module 2030............................. : Ok
Module 2031............................. : Ok
Module (2032) read error Module ID 2032 reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 2032............................. : Error
Module 2033............................. : Ok
Module 2034............................. : Ok
Module 2035............................. : Ok
Module 2036............................. : Ok
Module 2037............................. : Ok
Module 2010............................. : Ok
Module 2011............................. : Ok
Module 2012............................. : Ok
Module 2013............................. : Ok
Module 2014............................. : Ok
Module (2015) read error Module ID 2015 reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 2015............................. : Error
Module 2016............................. : Ok
Module 2017............................. : Ok
Module 2040............................. : Ok
Module 2041............................. : Ok
Module 2042............................. : Ok
Module 2043............................. : Ok
Module 2044............................. : Ok
Module 2045............................. : Ok
Module 2046............................. : Ok
Module (2047) read error Module ID 2047 reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 2047............................. : Error
Module 2050............................. : Ok
Module 2051............................. : Ok
Module 2052............................. : Ok
Module 2053............................. : Ok
Module 2054............................. : Ok
Module 2055............................. : Ok
Module 2056............................. : Ok
Module 2057............................. : Ok
Module 2060............................. : Ok
Module 2061............................. : Ok
Module 2062............................. : Ok
Module 2063............................. : Ok
Module 2064............................. : Ok
Module 2065............................. : Ok
Module 2066............................. : Ok
Module 2067............................. : Ok
Module 2070............................. : Ok
Module 2071............................. : Ok
Module 2072............................. : Ok
Module 2073............................. : Ok
Module 2074............................. : Ok
Module 2075............................. : Ok
Module (2076) read error Module ID 2076 reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 2076............................. : Error
Module 2077............................. : Ok
Module (2F00) read error Module ID 2F00 reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 2F00............................. : Error
Module 8010............................. : Ok
Module 802C............................. : Ok
Module 8035............................. : Ok
Module 8038............................. : Ok
Module 803C............................. : Ok
Module 8016............................. : Ok
Module 801D............................. : Ok
Module 8044............................. : Ok
Module 8031............................. : Ok
Module 8062............................. : Ok
Module 8063............................. : Ok
Module 8041............................. : Ok
Module 8042............................. : Ok
Module 800E............................. : Ok
Module 802D............................. : Ok
Module 8019............................. : Ok
Module 802F............................. : Ok
Module 8034............................. : Ok
Module 802E............................. : Ok
Module 8032............................. : Ok
Module 8017............................. : Ok
Module 8002............................. : Ok
Module 800B............................. : Ok
Module 8005............................. : Ok
Module 8020............................. : Ok
Module 8046............................. : Ok
Module 8045............................. : Ok
Module 8027............................. : Ok
Module 8014............................. : Ok
Module 801C............................. : Ok
Module 8023............................. : Ok
Module 801F............................. : Ok
Module 803A............................. : Ok
Module 803E............................. : Ok
Module 8012............................. : Ok
Module 8026............................. : Ok
Module 802B............................. : Ok
Module 8029............................. : Ok
Module 802A............................. : Ok
Module 8037............................. : Ok
Module 803B............................. : Ok
Module 800F............................. : Ok
Module 800A............................. : Ok
Module 8025............................. : Ok
Module 8009............................. : Ok
Module 800C............................. : Ok
Module 8006............................. : Ok
Module 8018............................. : Ok
Module 800D............................. : Ok
Module 8008............................. : Ok
Module 8024............................. : Ok
Module 8015............................. : Ok
Module 8007............................. : Ok
Module 8065............................. : Ok
Module 801A............................. : Ok
Module 8030............................. : Ok
Module 801E............................. : Ok
Module 8001............................. : Ok
Module 8022............................. : Ok
Module 8064............................. : Ok
Module 8049............................. : Ok
Module 805D............................. : Ok
Module 805E............................. : Ok
Module 805F............................. : Ok
Module 8060............................. : Ok
Module 8061............................. : Ok
Module 8011............................. : Ok
Module 803F............................. : Ok
Module 8040............................. : Ok
Module 8033............................. : Ok
Module 8043............................. : Ok
Module 8000............................. : Ok
Module 8021............................. : Ok
Module 8FFC............................. : Ok
Module 8FFD............................. : Ok
Module 8FFE............................. : Ok
Module 8047............................. : Ok
Module 8048............................. : Ok
Module 8004............................. : Ok
Module 8003............................. : Ok
Module 8028............................. : Ok
Module 8039............................. : Ok
Module 803D............................. : Ok
Module 8036............................. : Ok
Module 801B............................. : Ok
Module 8013............................. : Ok
Module 804C............................. : Ok
Module 804D............................. : Ok
Module 804E............................. : Ok
Module 804F............................. : Ok
Module 804A............................. : Ok
Module 804B............................. : Ok
Module 8050............................. : Ok
Module 8051............................. : Ok
Module 8052............................. : Ok
Module 8053............................. : Ok
Module 8054............................. : Ok
Module 8055............................. : Ok
Module 8056............................. : Ok
Module 8057............................. : Ok
Module (8058) read error Module ID 8058 reading error Data request error - Device Error Detected: "DISK DAM ERROR"
Module 8058............................. : Error
Module 8059............................. : Ok
Module 805A............................. : Ok
Module 805B............................. : Ok
Module 805C............................. : Ok
Module 8066............................. : Ok
Module 8067............................. : Ok
Module 8068............................. : Ok
Module 8069............................. : Ok
Module 806A............................. : Ok
Module 806B............................. : Ok
Module 806C............................. : Ok
Module 806D............................. : Ok
Module 806E............................. : Ok
Module 1000............................. : Ok
Module 00B1............................. : Ok
Module 00B2............................. : Ok
Module 1001............................. : Ok
Module 1002............................. : Ok
Module 1009............................. : Ok
Module 100A............................. : Ok
Module 1003............................. : Ok
Module 100C............................. : Ok
Module 1005............................. : Ok
Module 1004............................. : Ok
Module 1007............................. : Ok
Module 100B............................. : Ok
Module 100D............................. : Ok
Module 100E............................. : Ok
Module 1008............................. : Ok
Module 806F............................. : Ok
Module 80FE............................. : Ok
Module 1500............................. : Ok
Module 1501............................. : Ok
Module 1502............................. : Ok
Module 1503............................. : Ok
Module 1101............................. : Ok
Module 1504............................. : Ok
Module 1505............................. : Ok
Module 1506............................. : Ok
Module 1507............................. : Ok
Module 150C............................. : Ok
Module 150D............................. : Ok
Module 150E............................. : Ok
Module 150F............................. : Ok
Module 1100............................. : Ok
Module 1121............................. : Ok
 Post subject: Re: WD SADLE G6 not Detecting / Loading modules
PostPosted: November 19th, 2014, 6:16
Some of the critical modules are bad. You need to repair them.
PostPosted: November 19th, 2014, 9:00
Agree :-)
Mod 11 for starters, but more importantly 31 & 33
Users browsing this forum: Bing [Bot], Google [Bot], servohunter and 76 guests
