 Post subject: ST32000641AS corrupt
PostPosted: November 24th, 2014, 9:14
I want to see if I can recover files from a 2TB HDD. This HDD keeps asking for permission when I click a folder. When I get to the folder I see I have all the files but they all have a file size of 0 bytes. Also going to recycle bin I get a request to empty the bin for which I don't on account that I might delete recoverable data. Is there a method to fixing this HDD without having to use those recovering data apps?
Here is some info that might help:
ST32000641AS
Manufacturer Seagate
Form Factor 3.5"
Heads 16
Cylinders 243,201
Tracks 62,016,255
Sectors 3,907,024,065
SATA type SATA-III 6.0Gb/s
Device type Fixed
ATA Standard ATA8-ACS
Serial Number 9WM42XKX
Firmware Version Number CC13
LBA Size 48-bit LBA
Power On Count 924 times
Power On Time 132.1 days
Speed 7200 RPM
Features S.M.A.R.T., NCQ
Max. Transfer Mode SATA III 6.0Gb/s
Used Transfer Mode SATA III 6.0Gb/s
Interface USB (SATA)
Capacity 1863 GB
Real size 2,000,398,934,016 bytes
RAID Type None
S.M.A.R.T
Partition 0
Partition ID Disk #7, Partition #0
Disk Letter K:
File System NTFS
Volume Serial Number FC23DE53
Size 1863 GB
Used Space 101 GB (5%)
Free Space 1761 GB (95%)
Users browsing this forum: No registered users and 91 guests
