 Post subject: ST31000524AS JC45
PostPosted: November 29th, 2012, 20:22
Can someone kindly tell me if this drive has firmware blocked terminal access. I can get terminal output but no terminal input.
Rst 0x20M
RW: Disc Ctlr Initialization Completed.
No HOST FIS-ReadyStatusFlags 2002A1A5
Zero Alpha: zeroalpha.com.au
 Post subject: Re: ST31000524AS JC45
PostPosted: November 30th, 2012, 6:10
Is that 7200.11 or 7200.12 ?
PostPosted: December 2nd, 2012, 20:52
its .12
PostPosted: December 3rd, 2012, 5:42
Have you tried shorting the read channel ?
PostPosted: December 23rd, 2013, 21:09
were you able to solve this issue ... I have same exact problem ..
PostPosted: December 25th, 2013, 7:41
Rst 0x20M
Dear Friend Zero Alpha
Hi I Have Solution For Your Problem If You Are In Data Recovery Field And You Have Basic Setup Then Pm Me On My Skypee : smart.computech
I Will Resolve Your Issue.
Yours Friend
Jignesh Pankhania
PostPosted: November 29th, 2014, 13:52
which pin i have to short?
Please help!
i can upload the pic.
Users browsing this forum: YaCy [Bot] and 71 guests
