 Post subject: ST3500413AS JC66 Init Ok but No Terminal access
PostPosted: December 12th, 2014, 7:58
This SEAGATE is funny
ST3500413AS JC66 which initializes perfectly, as if FW issue but does not give terminal access even after shorting Read Channel. DRD DSC okay.
Has any one faced this issue ever ?
 Post subject: Seagate ST3500413AS JC66 Init Ok, but No Terminal access
PostPosted: December 12th, 2014, 8:35
The drive won't give access to the terminal, as it can't read the SA.
That's either bad heads or SA problems or non-original PCB.
 Post subject: Re: ST3500413AS JC66 Init Ok but No Terminal access
PostPosted: December 12th, 2014, 12:03
Heads are Okay
PCB Seems native as the sr. no in ROM are matching
Any more suggestions
PostPosted: December 12th, 2014, 12:09
This drive definitely does not initialize perfectly. In fact, it doesn't initialize at all, based on what I see.
I'm with Dimitry...assuming that it is the original PCB, it is damaged heads or surface damage in the SA.
How did you determine the heads are OK?
 Post subject: Re: Seagate ST3500413AS JC66 Init Ok, but No Terminal access
PostPosted: December 12th, 2014, 13:54
ROb wrote:
Heads are Okay
And I'm with Luke. The first question is indeed, how do you know that heads are OK?
Also there will be no more suggestions, as all of them are above.
OK, OK. If another suggestion is absolutely indispensable, then I'll throw in one, with a probability of 1%, no more: PCB is damaged in a way that's nearly impossible to notice. To rule this idea out test the PCB with a 100% healthy drive.
PostPosted: December 12th, 2014, 14:02
I have one more suggestion...send the drive to a professional data recovery lab for an assessment.
PostPosted: December 12th, 2014, 17:03
Agree, if you think this drive "initialises perfectly" and are just assuming "heads are ok" then your diagnosis procedure is seriously flawed, with respect.
Outsource it to someone who knows what they're doing.
No offence, just telling it how it is :-)
PostPosted: December 15th, 2014, 7:21
Thank you all for the reply
The Patient heads are working fine on the Donor Drive and the Donor remains in the the same state as with the Original heads native heads.
I am assuming the ROM could be original for the reason as the Sr no is matching.
Any suggestions welcome.
PostPosted: December 15th, 2014, 9:21
Unless you accidentally posted the wrong picture, the SN in your picture is not a true SN. It is a generic code. Unlike other F3s, this model is one of those that does not seem to post the SN.
If the heads are good, then the problem is likely related to firmware corruption of some sort. Have ruled out the PCB already, just to ensure?
PostPosted: December 15th, 2014, 10:19
Please read the answers above carefully.
PostPosted: December 16th, 2014, 2:20
When i say SN means i am talking about the Sr No. in ROM
Pls check the attachment
So it looks like SA corruption. Any chances of retrieval ?
PostPosted: December 16th, 2014, 14:34
What does it sound like? What was the donor S/N and manufacturing & date location? What have you tried already? Lots of questions needing an answer before helping...
PostPosted: December 17th, 2014, 0:25
Sorry if i was not clear here
The above drive starts and sounds like it initialized or as sounds like FW issue.
i have taken following steps.
1) Changed PCB - Works fine on another disk perfectly
2) Changed heads - These heads work fine on another disk perfectly.
3) Attempts to gain terminal access with shorting terminals also failed
S No. S2A43E0Z
SITE CODE : SU
DATE CODE : 12313
PostPosted: December 17th, 2014, 9:20
S No. S2A43E0Z
SITE CODE : SU
DATE CODE : 12313
Huh, unlatching heads and all? All I can think of is that you send it to our lab, we can talk via P.M. if you want to.
