 Post subject: Changing head on a Seagate 2Tera but...
PostPosted: December 19th, 2014, 10:26
Hi !
on a Seagate Barracuda ST2000DM001 2TB 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive
I changed heads because a 'Very slow read sector'
No probleme for change the head but not, the hard drive is not recognised by bios on PC
On so, impossible to mount the only ext4 partition on It.
Maybe is necessary to make something after changing head ?
When I connect to the board i have ==>
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
TCC-0020[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-0020
RECOV Servo Op=0900 Resp=0005
RECOV Servo Op=0600 Resp=0005
RECOV Servo Op=0055 Resp=0005
RECOV Servo Op=0165 Resp=0005
RECOV Servo Op=0065 Resp=0005
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
Reconstruction: MCMT Reconstruction Start
  Max number of MC segments 0A61
Nonvolatile MCMT sequence number 008054E5
[RSRS] 0585
RECOV Servo Op=0355 Resp=0005
Reconstruction: Completed 1:
[MCMTWS]
MCMainPOR: MCTStateFlags 0000002A  MCStateFlags 00000041
MCMainPOR: Feature Enabled...
Starting LBA of RW Request=0000000000088078  Length=000001C8
ProcessRWError -Read-   at LBA 0000000000088079  Sense Code=43110081
Starting LBA of RW Request=000000000008807C  Length=000001C4
ProcessRWError -Read-   at LBA 000000000008807C  Sense Code=43110081
ProcessRWError -Read-   at LBA 000000000008807D  Sense Code=43110081
Starting LBA of RW Request=0000000000088080  Length=000001C0
ProcessRWError -Read-   at LBA 0000000000088080  Sense Code=C3160080
Starting LBA of RW Request=0000000000088084  Length=000001BC
ProcessRWError -Read-   at LBA 0000000000088088  Sense Code=43110081
Starting LBA of RW Request=000000000008808C  Length=000001B4
ProcessRWError -Read-   at LBA 000000000008808E  Sense Code=43110081
Starting LBA of RW Request=0000000000088090  Length=000001B0
ProcessRWError -Read-   at LBA 0000000000088090  Sense Code=C3160080
Starting LBA of RW Request=0000000000088094  Length=000001AC
ProcessRWError -Read-   at LBA 0000000000088094  Sense Code=C3160080
Starting LBA of RW Request=0000000000088098  Length=000001A8
ProcessRWError -Read-   at LBA 0000000000088098  Sense Code=43110081
Starting LBA of RW Request=000000000008809C  Length=000001A4
ProcessRWError -Read-   at LBA 000000000008809C  Sense Code=43110081
Starting LBA of RW Request=00000000000880A0  Length=000001A0
ProcessRWError -Read-   at LBA 00000000000880A0  Sense Code=43110081
Starting LBA of RW Request=00000000000880A4  Length=0000019C
ProcessRWError -Read-   at LBA 00000000000880A4  Sense Code=C3160080
Starting LBA of RW Request=00000000000880A8  Length=00000198
ProcessRWError -Read-   at LBA 00000000000880A8  Sense Code=43110081
ProcessRWError -Read-   at LBA 00000000000880AC  Sense Code=43110081
Starting LBA of RW Request=00000000000880B0  Length=00000190
ProcessRWError -Read-   at LBA 00000000000880B0  Sense Code=43110081
Starting LBA of RW Request=00000000000880B4  Length=0000018C
ProcessRWError -Read-   at LBA 00000000000880B5  Sense Code=43110081
Starting LBA of RW Request=00000000000880B8  Length=00000188
ProcessRWError -Read-   at LBA 00000000000880B8  Sense Code=43110081
Starting LBA of RW Request=00000000000880BC  Length=00000184
ProcessRWError -Read-   at LBA 00000000000880BF  Sense Code=C3160080
Starting LBA of RW Request=00000000000880C0  Length=00000180
ProcessRWError -Read-   at LBA 00000000000880C0  Sense Code=C3160080
ProcessRWError -Read-   at LBA 00000000000880C6  Sense Code=43110081
ProcessRWError -Read-   at LBA 00000000000880C7  Sense Code=43110081
Starting LBA of RW Request=00000000000880C8  Length=00000178
ProcessRWError -Read-   at LBA 00000000000880D6  Sense Code=43110081
ProcessRWError -Read-   at LBA 00000000000880D7  Sense Code=C3160080
ProcessRWError -Read-   at LBA 00000000000880D9  Sense Code=43110081
Starting LBA of RW Request=00000000000880DC  Length=00000164
ProcessRWError -Read-   at LBA 00000000000880DF  Sense Code=43110081
Starting LBA of RW Request=00000000000880E0  Length=00000160
ProcessRWError -Read-   at LBA 00000000000880E0  Sense Code=43110081
Starting LBA of RW Request=00000000000880E4  Length=0000015C
ProcessRWError -Read-   at LBA 00000000000880E4  Sense Code=43110081
Starting LBA of RW Request=00000000000880E8  Length=00000158
ProcessRWError -Read-   at LBA 00000000000880E8  Sense Code=43110081
Starting LBA of RW Request=00000000000880EC  Length=00000154
ProcessRWError -Read-   at LBA 00000000000880EC  Sense Code=43110081
Starting LBA of RW Request=00000000000880F0  Length=00000150
ProcessRWError -Read-   at LBA 00000000000880F0  Sense Code=43110081
ProcessRWError -Read-   at LBA 00000000000880F1  Sense Code=43110081
Starting LBA of RW Request=00000000000880F4  Length=0000014C
ProcessRWError -Read-   at LBA 00000000000880F4  Sense Code=43110081
Starting LBA of RW Request=00000000000880F8  Length=00000148
ProcessRWError -Read-   at LBA 00000000000880F8  Sense Code=43110081
Starting LBA of RW Request=00000000000880FC  Length=00000144
ProcessRWError -Read-   at LBA 00000000000880FC  Sense Code=C3160080
Starting LBA of RW Request=0000000000088100  Length=00000140
ProcessRWError -Read-   at LBA 0000000000088100  Sense Code=43110081
ProcessRWError -Read-   at LBA 0000000000088101  Sense Code=43110081
Starting LBA of RW Request=0000000000088104  Length=0000013C
ProcessRWError -Read-   at LBA 0000000000088106  Sense Code=43110081
Starting LBA of RW Request=0000000000088108  Length=00000138
ProcessRWError -Read-   at LBA 0000000000088108  Sense Code=43110081
Starting LBA of RW Request=000000000008810C  Length=00000134
ProcessRWError -Read-   at LBA 000000000008810C  Sense Code=43110081
Starting LBA of RW Request=0000000000088110  Length=00000130
ProcessRWError -Read-   at LBA 0000000000088114  Sense Code=43110081
ProcessRWError -Read-   at LBA 0000000000088115  Sense Code=43110081
Starting LBA of RW Request=0000000000088118  Length=00000128
ProcessRWError -Read-   at LBA 0000000000088118  Sense Code=43110081
Starting LBA of RW Request=000000000008811C  Length=00000124
ProcessRWError -Read-   at LBA 000000000008811C  Sense Code=43110081
Starting LBA of RW Request=0000000000088120  Length=00000120
ProcessRWError -Read-   at LBA 0000000000088120  Sense Code=43110081
Starting LBA of RW Request=0000000000088124  Length=0000011C
ProcessRWError -Read-   at LBA 0000000000088124  Sense Code=C3160080
Starting LBA of RW Request=0000000000088128  Length=00000118
ProcessRWError -Read-   at LBA 0000000000088128  Sense Code=43110081
Starting LBA of RW Request=000000000008812C  Length=00000114
ProcessRWError -Read-   at LBA 000000000008812C  Sense Code=C3160080
Starting LBA of RW Request=0000000000088130  Length=00000110
ProcessRWError -Read-   at LBA 0000000000088131  Sense Code=43110081
Starting LBA of RW Request=0000000000088134  Length=0000010C
ProcessRWError -Read-   at LBA 0000000000088134  Sense Code=43110081
Starting LBA of RW Request=0000000000088138  Length=00000108
ProcessRWError -Read-   at LBA 0000000000088138  Sense Code=C3160080
ProcessRWError -Read-   at LBA 0000000000088139  Sense Code=43110081
Starting LBA of RW Request=000000000008813C  Length=00000104
ProcessRWError -Read-   at LBA 000000000008813C  Sense Code=43110081
Starting LBA of RW Request=0000000000088140  Length=00000100
ProcessRWError -Read-   at LBA 0000000000088141  Sense Code=43110081
Starting LBA of RW Request=0000000000088144  Length=000000FC
ProcessRWError -Read-   at LBA 0000000000088147  Sense Code=43110081
Starting LBA of RW Request=0000000000088148  Length=000000F8
ProcessRWError -Read-   at LBA 0000000000088148  Sense Code=43110081
Starting LBA of RW Request=000000000008814C  Length=000000F4
ProcessRWError -Read-   at LBA 000000000008814C  Sense Code=43110081
Starting LBA of RW Request=0000000000088150  Length=000000F0
ProcessRWError -Read-   at LBA 0000000000088150  Sense Code=43110081
ProcessRWError -Read-   at LBA 0000000000088152  Sense Code=43110081
Starting LBA of RW Request=0000000000088154  Length=000000EC
ProcessRWError -Read-   at LBA 0000000000088154  Sense Code=43110081
Starting LBA of RW Request=0000000000088158  Length=000000E8
ProcessRWError -Read-   at LBA 0000000000088158  Sense Code=43110081
Starting LBA of RW Request=000000000008815C  Length=000000E4
ProcessRWError -Read-   at LBA 000000000008815C  Sense Code=43110081
Starting LBA of RW Request=0000000000088160  Length=000000E0
ProcessRWError -Read-   at LBA 0000000000088160  Sense Code=43110081
Starting LBA of RW Request=0000000000088164  Length=000000DC
ProcessRWError -Read-   at LBA 0000000000088164  Sense Code=43110081
Starting LBA of RW Request=0000000000088168  Length=000000D8
ProcessRWError -Read-   at LBA 0000000000088168  Sense Code=43110081
Starting LBA of RW Request=000000000008816C  Length=000000D4
ProcessRWError -Read-   at LBA 000000000008816C  Sense Code=43110081
Starting LBA of RW Request=0000000000088170  Length=000000D0
ProcessRWError -Read-   at LBA 0000000000088170  Sense Code=43110081
Starting LBA of RW Request=0000000000088174  Length=000000CC
ProcessRWError -Read-   at LBA 0000000000088174  Sense Code=43110081
ProcessRWError -Read-   at LBA 0000000000088186  Sense Code=43110081
Starting LBA of RW Request=0000000000088188  Length=000000B8
ProcessRWError -Read-   at LBA 0000000000088188  Sense Code=43110081
ProcessRWError -Read-   at LBA 0000000000088189  Sense Code=43110081
Starting LBA of RW Request=000000000008818C  Length=000000B4
ProcessRWError -Read-   at LBA 000000000008818C  Sense Code=43110081
Starting LBA of RW Request=0000000000088190  Length=000000B0
ProcessRWError -Read-   at LBA 0000000000088190  Sense Code=43110081
Starting LBA of RW Request=0000000000088194  Length=000000AC
ProcessRWError -Read-   at LBA 000000000008819B  Sense Code=43110081
Starting LBA of RW Request=000000000008819C  Length=000000A4
ProcessRWError -Read-   at LBA 000000000008819C  Sense Code=43110081
Starting LBA of RW Request=00000000000881A0  Length=000000A0
ProcessRWError -Read-   at LBA 00000000000881B2  Sense Code=43110081
Starting LBA of RW Request=00000000000881B4  Length=0000008C
ProcessRWError -Read-   at LBA 00000000000881B4  Sense Code=C3160080
Starting LBA of RW Request=00000000000881B8  Length=00000088
ProcessRWError -Read-   at LBA 00000000000881B8  Sense Code=C3160080
ProcessRWError -Read-   at LBA 00000000000881C9  Sense Code=C3160080
ProcessRWError -Read-   at LBA 00000000000881CA  Sense Code=43110081
Starting LBA of RW Request=00000000000881CC  Length=00000074
ProcessRWError -Read-   at LBA 00000000000881CC  Sense Code=C3160080
Starting LBA of RW Request=00000000000881D0  Length=00000070
ProcessRWError -Read-   at LBA 00000000000881D0  Sense Code=C3160080
Starting LBA of RW Request=00000000000881D4  Length=0000006C
ProcessRWError -Read-   at LBA 00000000000881D4  Sense Code=C3160080
Starting LBA of RW Request=00000000000881D8  Length=00000068
ProcessRWError -Read-   at LBA 00000000000881D8  Sense Code=C3160080
Starting LBA of RW Request=00000000000881DC  Length=00000064
ProcessRWError -Read-   at LBA 00000000000881DF  Sense Code=43110081
ProcessRWError -Read-   at LBA 00000000000881E0  Sense Code=43110081
ProcessRWError -Read-   at LBA 00000000000881E2  Sense Code=43110081
Starting LBA of RW Request=00000000000881E4  Length=0000005C
ProcessRWError -Read-   at LBA 00000000000881E4  Sense Code=43110081
Starting LBA of RW Request=00000000000881E8  Length=00000058
ProcessRWError -Read-   at LBA 00000000000881EC  Sense Code=43110081
Starting LBA of RW Request=00000000000881F0  Length=00000050
ProcessRWError -Read-   at LBA 00000000000881F0  Sense Code=43110081
Starting LBA of RW Request=00000000000881F4  Length=0000004C
ProcessRWError -Read-   at LBA 00000000000881F4  Sense Code=43110081
Starting LBA of RW Request=00000000000881F8  Length=00000048
ProcessRWError -Read-   at LBA 00000000000881F8  Sense Code=43110081
Starting LBA of RW Request=00000000000881FC  Length=00000044
ProcessRWError -Read-   at LBA 00000000000881FC  Sense Code=43110081
Starting LBA of RW Request=0000000000088200  Length=00000040
ProcessRWError -Read-   at LBA 0000000000088204  Sense Code=C3160080
Starting LBA of RW Request=0000000000088208  Length=00000038
ProcessRWError -Read-   at LBA 0000000000088209  Sense Code=C3160080
Starting LBA of RW Request=000000000008820C  Length=00000034
ProcessRWError -Read-   at LBA 0000000000088212  Sense Code=43110081
Starting LBA of RW Request=0000000000088214  Length=0000002C
ProcessRWError -Read-   at LBA 0000000000088216  Sense Code=43110081
Starting LBA of RW Request=0000000000088218  Length=00000028
ProcessRWError -Read-   at LBA 0000000000088218  Sense Code=43110081
Starting LBA of RW Request=000000000008821C  Length=00000024
ProcessRWError -Read-   at LBA 000000000008821C  Sense Code=43110081
Starting LBA of RW Request=0000000000088220  Length=00000020
ProcessRWError -Read-   at LBA 0000000000088222  Sense Code=43110081
Starting LBA of RW Request=0000000000088224  Length=0000001C
ProcessRWError -Read-   at LBA 0000000000088224  Sense Code=43110081
Starting LBA of RW Request=0000000000088228  Length=00000018
ProcessRWError -Read-   at LBA 0000000000088228  Sense Code=43110081
Starting LBA of RW Request=000000000008822C  Length=00000014
ProcessRWError -Read-   at LBA 000000000008822C  Sense Code=43110081
Starting LBA of RW Request=0000000000088230  Length=00000010
ProcessRWError -Read-   at LBA 0000000000088230  Sense Code=43110081
Starting LBA of RW Request=0000000000088234  Length=0000000C
ProcessRWError -Read-   at LBA 0000000000088237  Sense Code=C3160080
ASCII Diag mode
F3 T>/7
F3 7>X
RECOV Servo Op=0155 Resp=0005
Head 00 Resistance 011A
Head 01 Resistance 00FE
Head 02 Resistance 0130
Head 03 Resistance 017E
I missing something I supose.
I do also a SMART erase vith N1 command on level 2, and after reboot, N5 seem to be clean, but always no work.
I somebody have any idea, I take them.
Thanks a lot
 Post subject: Re: Changing head on a Seagate 2Tera but...
PostPosted: December 19th, 2014, 15:18
After a long period, Waiting, It's detect but, impossible to read it from different OS.
PostPosted: December 19th, 2014, 16:27
What data recovery tools do you have available to you to fix firmware issues? Also, what tools do you have for cloning failing hard drives?
The last thing you should be doing is trying to access the drive directly.
PostPosted: December 19th, 2014, 18:43
Trying to re-write the las firmware C4H (Not sure, it's re-writing...)
For Now, The harddrive is see under windows so... Trying to dump it with Easus Todo backup
For now it's working, It's slow but seems work.
60Giga saved around 4hours
Before I change Head, I get 15giga in... 7 days...
If this save, with windows toosl will be not good, I connect the drive directly to my linux serveur and use ddrescue for dump it.
I thinks on this hard drive they had Head issue AND firmware issue.
Thks Seagate -_-'
Users browsing this forum: No registered users and 76 guests
