ST9500423AS Problem.
September 7th, 2015, 13:05
As in topic the drive came with several bad sectors for data recovery.
Start cloning the drive then starting to click, power off and power on the same ( clicking ).
Any thoughts ?
Thanks in advance.
Re: ST9500423AS Problem.
September 7th, 2015, 13:17
unknown wrote:As in topic the drive came with several bad sectors for data recovery.
Any thoughts ?
Thanks in advance.
when u talk about seagate, always post the terminal log as ref. to the problem
:wink:
September 7th, 2015, 13:18
EarlySpinup Enabled
Rst 0x10M6
that's only what I get in Terminal.
When short points get this :
EarlySpinup Enabled
Rst 0x10M
ASCII Diag mode
F3 T>
LED:00000067 FAddr:00384F72
Thanks for reply
September 7th, 2015, 13:31
Heads have failed.
September 7th, 2015, 13:33
pcimage wrote:Heads have failed.
That's the last statement I wanted to see. :(
