 Post subject: Western Digital -> Compatiable USB To SATA Boards
PostPosted: January 8th, 2015, 7:32
Hello ,
Can We Have a Single thread with most of tested boards .The information here is so scattered and waste a lot of time .I will update the first thread once More Information is trickled out .I would also Like To Find SATA Replacement For The Under PCB .I Am Easily Tab Points and Use a SATA Connector But i am Inclined To Get a SATA Board .
Drive " WD5000BMVW-11AMCS2 " : USB " 2060-771761-001 Rev A" > SATA " ? "
 Post subject: Re: Western Digital -> Compatiable USB To SATA Boards
PostPosted: January 8th, 2015, 9:31
-> 771692
PostPosted: January 8th, 2015, 10:39
Kamen wrote:
-> 771692
Well,
I Got That Info .I Am Wanting To Find Out In This Format XXXX-771692-XXX Rev X .Here i Am Looking For All The X's .Would Appreciate If Others Could Upload Not Only The Info i Am Requesting But Other Compatible Once Too .I Will Update My First Post If i Have The Privileges By Dimitry Sir " I Can Ask Him Too " .
PostPosted: January 8th, 2015, 12:12
http://ts.acelaboratory.com/index.php?/ ... usb-drives
PostPosted: January 8th, 2015, 13:35
http://ts.acelaboratory.com/index.php?/Knowledgebase/Article/View/33/15/list-of-compatible-sata-pcb-for-25-usb-drives
Sir ,
I Have Seen This And also Your Reference To This Many Times in HDDguru .They are only concentrating on the XXXX-YYYYYY-XXX Rev X " Y Letters " Here .Does This Mean XXXX In The starting And XXX in The Ending plus The X After Rev Are Not Essential " I do Not Think So " Sometimes its a Totally Different MCU and Motor Controller .
Users browsing this forum: No registered users and 231 guests
