Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2, 3  Next
 Post subject: eeprom chip needs a repair
PostPosted: December 30th, 2014, 12:41
hi
I have an eeprom chip (6 x 8 mm) with a few legs broken, that i need it fixed.
in order to fix it, the ceramic coating has to be remove and solder new legs.
It doesn't have to be a cosmetic look, just fixed enough to extract the data on it
can someone guide me to the right direction ? an electronic engineer who can get the job done ? ...
 Post subject: Re: eeprom chip needs a repair
PostPosted: December 30th, 2014, 14:26
devde wrote:
hi
Sir ,
What HDD Is this or its some other device
PostPosted: December 30th, 2014, 15:27
Any skilled cellphone repairmen will solve that issue fast.
Can you post few pics or just eeprom model?
PostPosted: December 30th, 2014, 16:41
Clean up the connections, connect wires with Loctite 3863 under a microscope.
Read eeprom and program a new one.
Digitalsupport
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: December 30th, 2014, 18:45
Amarbir wrote:
Sir ,
st9250315as
PostPosted: December 30th, 2014, 18:46
model W25X40AL09
PostPosted: December 30th, 2014, 18:49
how, it's broken
PostPosted: December 30th, 2014, 18:50
Spildit wrote:
It's from an hard drive ?
If so you might be lucky and not even need to fix the chip....
it appears i'm not so lucky it's a seagate F3 architecture
PostPosted: December 30th, 2014, 20:37
Post some pictures.
Digitalsupport
PostPosted: December 30th, 2014, 21:02
digisupport wrote:
Post some pictures.
Digitalsupport
PostPosted: December 31st, 2014, 5:42
devde wrote:
digisupport wrote:
Post some pictures.
Digitalsupport
Boss ,
Useless Picture Do Something :(
PostPosted: December 31st, 2014, 5:48
Ouch - that one is in a bad shape :(
Still inspect under a microscope, find the broken connections.
Fix the chip on veroboard and connect thin wires under a microscope with Loctite 3863
Read out the chip if still possible.
Digitalsupport
PostPosted: December 31st, 2014, 5:50
Looks like the chip is dead anyway, look at the "bubbles" on top of it....looks like big internal damage.
Bosse
http://www.rescue-it.se
PostPosted: December 31st, 2014, 6:02
Bosse
Wrong ,
thats the down side with solder .I suggest you put this on a adapter as 7 legs out of four will be connected you will need to connect the eight leg to the adapter via a small copper wire .Please use simple adapter and not a zif type .This case is a piece of cake for me :mrgreen:
PostPosted: December 31st, 2014, 6:32
Amarbir wrote:
Bosse
Wrong ,
Thats right its a blob of solder. You think its a simple snap your fingers and job done but in my opinion the damage might be terminal. Consider how much heat might have been applied to even remove the ic as for sure it hadn't been done in any form of a controlled environment. And that is separate from the physical issues of damaged case, broken connections etc.
I would suggest to the op he appears to have some knowledge about the subject, f3 series architecture, adaptives, reading/writing roms etc. and all this considering it was his first post on Hddguru.
@op it would be helpful if you come clean and clearly describe what led you to this point (including what happened before the botched rom removal) rather than the short responses to the questions being asked. There are many people here who can help/advise and some are geographically close to your location.
PostPosted: December 31st, 2014, 7:02
Amarbir wrote:
Bosse
Wrong ,
Yes, I saw that now...but pretty bad pic. :D
PostPosted: December 31st, 2014, 9:39
Probably not enough heat was used, which is why the packaging broke. Was it pried off with a chisel or something? Hurts to just look at it (especially with that fuzzy picture).
PostPosted: December 31st, 2014, 10:54
@mr_spokk thats the down side, with a blob of solder
PostPosted: December 31st, 2014, 10:55
@Amarbir can you explain i don't understand
@dick thats what i'm asking "can someone guide me to the right direction ? an electronic engineer who can get the job done ? ..."
Users browsing this forum: Google [Bot] and 49 guests
