 Post subject: Loader for WD1001FALS-00J7BO MARS Ver. 009009W
PostPosted: January 7th, 2015, 4:14
Hello Gurus
Looking for Loader for WD1001FALS-00J7BO MARS (Marvell ROYL) Ver. 0009009W
Help Appreciated.
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 1
Cyl Count............................... : 170
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 09.9WN
ROM generation.......................... : 09.9WN
Link table version...................... : 00.A3.
Consolidated ROM version................ : 0009009W
ROM Modules:
Flash ROM dir reading................... : Ok
SA regions address...................... : by default
SA Translator loading................... : Ok
SA defects assigned..................... : 1
Heads number............................ : 6
Heads number in use..................... : 6
Switched off heads...................... : No
Heads map............................... : 2,3,4,5,6,7
ROM Firmware version.................... : 0009009W
Module 0x90 read error.................. : Module (0090) read error Module ID 90 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module sector read error................ : No SA copy avalabled
View module 90 information
Total heads............................. : 6
Used heads.............................. : 6
Mdl 47 version.......................... : EZ.0202
ROM Version version..................... : 0009009W (09.9W)
Mdl 11 Version.......................... : 0009009W (09.9W)
 Post subject: Re: Loader for WD1001FALS-00J7BO MARS Ver. 009009W
PostPosted: January 7th, 2015, 4:41
Hello ROb
good luck with DIR :arrow:
11.rar [145.66 KiB]
Downloaded 300 times
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
