WD3200AAJS-00YZCA0 too slow
January 26th, 2015, 10:34
Hello guys,
I have twoo HDD WD3200AAJS-00YZCA0, are identical, with a transfer rate very slow (less 5mb/sec). No physical error detected.
Please help. Firmware needed?
Re: WD3200AAJS-00YZCA0 too slow
January 26th, 2015, 10:45
What data recovery tools do you have at your disposal for assessment and hard drive repair?
What are you using to clone the drive with?
What is the original source of the problem? (ie, were the drives dropped before you got them?)
January 27th, 2015, 17:24
All data are accesible in windows. the drives no any shock, dropped or physical damage. The HDD regenerator scan and don´t mark bad sectors or delays, but the speed is very slow (more 18 hours to complete test) No have idea for why
A friend suggest the internal write cache is disabled and reprogram firmware solved this.
Of course, i preferred a do-it-yourself sollution :)
