 Post subject: SOS! SOS! SOS! Help me please!
PostPosted: January 25th, 2015, 9:35
Hi there folks,
i am in dire need of help like many user out here. i will narrate the issue in short and kindly advise me as what do i need to do.
I am into mainly coreboot development and replicant and openwrt development, if you folks are not aware of what coreboot and replicant and openwrt is? Then the answer will be its an open source replacement for computer firmware or bios/uefi firmware replacement and replicant will be the replacement for hardened android OS. I got a few laptops, 1 X60, 2 T60 and 1 T410 and 1 T420. Everything was going fine until i realised i need more space to build more applications from source code and sometime develop and contribute.
about 4 months back i had dire need of a bigger drive. Since i am trying to compile many projects in vm, so i needed additional space. So i got myself a second hand 500 gig seagate menentus 5400.6 HDD. The drive even though it is used was working fine till about 2-3 days back. When i realised my vm were getting painfully slow. So i decided to run a hdparm secure delete and start from scratch.
well, hdparm failed and spit some errors. errrrrrrr! fine, ran a scan, found out that it has developed shit load of bad sectors and worst problem smart somehow got tripped.
so get rid of bad sectors i tried a few things none worked. okay i realised i am in deep shit. and then i did a little research on the net and i read a few posts here in this forum and there and i read somethere, that if you upgrade the firmware then the bad sectors are wiped clean.
So without understanding the logic/concept and anything and everything and simple mindless reading i find myself i am in deep shit.
this is what i did. after i found smart is triggered and shit load of bad sectors? i decided to run badblock scan, wow, it hang my system, i did run this from a livecd (usb key). and when it failed? i did try the ultimate moronic approach, i upgraded the firmware. without even asking here first or further investigation. Now the drive sometime works fast and sometime slow. and suddenly it chokes and spits way too many errors. syslog cant keepup with the sector error spit. drive details :
Family : Seagate Momentus 5400.6 500 GB / ST9500325AS
Product No. : 9hh134-022
FW Rev: 0005HPM1
Os: Debian stable/jessie/sid
And i downloaded the lenovo firmware from the lenovo site and i upgraded the firmware using hdparm
hdparm --yes-i-know-what-i-am-doing --please-destroy-my-drive --fwdownload /mnt/pendrive/5421LV17.LOD /dev/sdb
and since then the trouble really started to fold 10 times.
now the drive is 100 times slower than 3-4 days back. and it spits error way too many that even syslog cant keep up with the errors and i cant even make a proper file system since ext2/3/4 literally aborts midway.
i followed the instructions i read here :
https://sites.google.com/site/seagatefix/Home
and
viewtopic.php?t=15155&start=
and
http://www.users.on.net/~fzabkar/dell_fw_cfg.txt
and
viewtopic.php?f=7&t=25132
and
viewtopic.php?f=11&t=11332&start=20
and
viewtopic.php?t=19976&start=
and
http://lifeofageekadmin.com/seagate-bar ... hdd-issue/
i am well versed with rs-232 and jtag and buspirate working. but this firmware is way beyond my scope or level.
can canyone help me out. or can anyone send me the original .lod file? so i can
hdparm --yes-i-know-what-i-am-doing --please-destroy-my-drive --fwdownload /mnt/firmware/original.LOD /dev/sdb
please?
its been 2 nights i am not being able to sleep, trying to fix this broken, broken, broken, mistake, lack of understanding and stupidity stupendous combo? please.
or can i upload the firmware via serial xmodem if its not a .lod file?
please can anyone send me the original file/combo?
thanks!
-paul
 Post subject: Re: SOS! SOS! SOS! Help me please!
PostPosted: January 25th, 2015, 11:14
adding more info:
hdparm shows me this :
/dev/sdc:
ATA device, with non-removable media
Model Number: ST9500325AS
Serial Number: XXXXXXXXX
Firmware Revision: 0021
Transport: Serial
Standards:
Used: unknown (minor revision code 0x0029)
Supported: 8 7 6 5
Likely used: 8
Configuration:
Logical max current
cylinders 16383 16383
heads 16 16
sectors/track 63 63
CHS current addressable sectors: 16514064
LBA user addressable sectors: 0
LBA48 user addressable sectors: 0
Logical Sector size: 512 bytes
Physical Sector size: 512 bytes
device size with M = 1024*1024: 8063 MBytes
device size with M = 1000*1000: 8455 MBytes (8 GB)
cache/buffer size = 8192 KBytes
Nominal Media Rotation Rate: 5400
Capabilities:
LBA, IORDY(can be disabled)
Queue depth: 32
Standby timer values: spec'd by Standard, no device specific minimum
R/W multiple sector transfer: Max = 16 Current = 16
Advanced power management level: 128
Recommended acoustic management value: 254, current value: 0
DMA: mdma0 mdma1 *mdma2 udma0 udma1 udma2 udma3 udma4 udma5
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=120ns IORDY flow control=120ns
Commands/features:
Enabled Supported:
* SMART feature set
Security Mode feature set
* Power Management feature set
* Write cache
* Look-ahead
* Host Protected Area feature set
* WRITE_BUFFER command
* READ_BUFFER command
* DOWNLOAD_MICROCODE
* Advanced Power Management feature set
SET_MAX security extension
* 48-bit Address feature set
* Device Configuration Overlay feature set
* Mandatory FLUSH_CACHE
* FLUSH_CACHE_EXT
* SMART error logging
* SMART self-test
* General Purpose Logging feature set
* 64-bit World wide name
* IDLE_IMMEDIATE with UNLOAD
* Write-Read-Verify feature set
* WRITE_UNCORRECTABLE_EXT command
* {READ,WRITE}_DMA_EXT_GPL commands
* Segmented DOWNLOAD_MICROCODE
* Gen1 signaling speed (1.5Gb/s)
* Gen2 signaling speed (3.0Gb/s)
* Native Command Queueing (NCQ)
* Phy event counters
Device-initiated interface power management
* Software settings preservation
* SMART Command Transport (SCT) feature set
* SCT Long Sector Access (AC1)
* SCT Error Recovery Control (AC3)
* SCT Features Control (AC4)
* SCT Data Tables (AC5)
unknown 206[12] (vendor specific)
Security:
Master password revision code = 65534
2min for SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: 5000c5004628b223
NAA : 5
IEEE OUI : 000c50
Unique ID : 04628b223
Checksum: correct
8 GB ................ what the heck!
security parameters are not shown ...... oh oh! deep trouble:
uuid : different i dont remember seeing this value
one and only good news :
# hdparm --yes-i-know-what-i-am-doing --please-destroy-my-drive --fwdownload /mnt/Downloads/misc/image/firmware43/FIRMWARE/SEAGATE/5421LV17.LOD /dev/sdc
/dev/sdc:
fwdownload: xfer_mode=3 min=1 max=1 size=512
............................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................. Done.
phew, which means i can still upload the firmware via hdparm.
now the beep sounds description :
one short beep for say .2 seconds and 11 beeps following it which is like .3 seconds (yes used a stop clock to record the info).
dmesg info :
max limit 60000 characters : next post got dmesg details
2 tb in dmesg and 8 gb in hdparm. WT(serious)F!
this wasnt the case till 10 hours back, i could cfdisk or fdisk and create partitions and now? i am as good as raped. help me!
helpppppppppppppppppp!
oh guru oh doctor, i gave all the symptoms now can someone help me? can i fix this issue by using a jtag? if so whats the jtag pin out for this device (typical openwrt syndrome : got jtag? xD)
thanks!
-paul
PostPosted: January 25th, 2015, 11:19
19088.513609] sd 11:0:0:0: Attached scsi generic sg3 type 0
[19088.514802] sd 11:0:0:0: [sdc] Very big device. Trying to use READ CAPACITY(16).
[19088.515665] sd 11:0:0:0: [sdc] Using 0xffffffff as device size
[19088.515676] sd 11:0:0:0: [sdc] 4294967296 512-byte logical blocks: (2.19 TB/2.00 TiB)
[19088.516542] sd 11:0:0:0: [sdc] Write Protect is off
[19088.516548] sd 11:0:0:0: [sdc] Mode Sense: 21 00 00 00
[19088.517391] sd 11:0:0:0: [sdc] No Caching mode page found
[19088.517397] sd 11:0:0:0: [sdc] Assuming drive cache: write through
[19088.518166] sd 11:0:0:0: [sdc] Very big device. Trying to use READ CAPACITY(16).
[19088.519100] sd 11:0:0:0: [sdc] Using 0xffffffff as device size
[19088.520880] sd 11:0:0:0: [sdc] No Caching mode page found
[19088.520886] sd 11:0:0:0: [sdc] Assuming drive cache: write through
[19088.522002] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.522009] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.522016] Info fld=0x0
[19088.522019] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.522026] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.522038] end_request: I/O error, dev sdc, sector 0
[19088.522043] quiet_error: 153 callbacks suppressed
[19088.522046] Buffer I/O error on device sdc, logical block 0
[19088.523122] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.523130] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.523136] Info fld=0x0
[19088.523139] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.523146] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.523157] end_request: I/O error, dev sdc, sector 0
[19088.523162] Buffer I/O error on device sdc, logical block 0
[19088.524255] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.524262] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.524268] Info fld=0x0
[19088.524270] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.524277] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.524289] end_request: I/O error, dev sdc, sector 0
[19088.524294] Buffer I/O error on device sdc, logical block 0
[19088.525366] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.525372] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.525377] Info fld=0x0
[19088.525380] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.525387] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.525398] end_request: I/O error, dev sdc, sector 0
[19088.525402] Buffer I/O error on device sdc, logical block 0
[19088.526487] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.526493] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.526498] Info fld=0x0
[19088.526501] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.526507] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.526518] end_request: I/O error, dev sdc, sector 0
[19088.526522] Buffer I/O error on device sdc, logical block 0
[19088.526533] ldm_validate_partition_table(): Disk read failed.
[19088.527638] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.527647] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.527655] Info fld=0x0
[19088.527659] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.527669] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.527686] end_request: I/O error, dev sdc, sector 0
[19088.527693] Buffer I/O error on device sdc, logical block 0
[19088.528745] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.528753] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.528761] Info fld=0x0
[19088.528766] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.528776] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.528793] end_request: I/O error, dev sdc, sector 0
[19088.528798] Buffer I/O error on device sdc, logical block 0
[19088.529860] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.529866] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.529872] Info fld=0x0
[19088.529875] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.529881] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.529892] end_request: I/O error, dev sdc, sector 0
[19088.529897] Buffer I/O error on device sdc, logical block 0
[19088.530993] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.530999] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.531004] Info fld=0x0
[19088.531007] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.531014] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.531025] end_request: I/O error, dev sdc, sector 0
[19088.531029] Buffer I/O error on device sdc, logical block 0
[19088.531044] Dev sdc: unable to read RDB block 0
[19088.532122] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.532128] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.532134] Info fld=0x0
[19088.532137] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.532143] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.532154] end_request: I/O error, dev sdc, sector 0
[19088.532159] Buffer I/O error on device sdc, logical block 0
[19088.533240] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.533249] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.533258] Info fld=0x0
[19088.533262] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.533272] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.533290] end_request: I/O error, dev sdc, sector 0
[19088.534384] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.534390] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.534396] Info fld=0x0
[19088.534399] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.534405] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 18 00 00 08 00
[19088.534417] end_request: I/O error, dev sdc, sector 24
[19088.535353] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.535362] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.535370] Info fld=0x0
[19088.535374] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.535384] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 18 00 00 08 00
[19088.535400] end_request: I/O error, dev sdc, sector 24
[19088.536487] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.536494] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.536499] Info fld=0x0
[19088.536502] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.536509] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.536520] end_request: I/O error, dev sdc, sector 0
[19088.536537] sdc: unable to read partition table
[19088.538139] sd 11:0:0:0: [sdc] Very big device. Trying to use READ CAPACITY(16).
[19088.539014] sd 11:0:0:0: [sdc] Using 0xffffffff as device size
[19088.541255] sd 11:0:0:0: [sdc] No Caching mode page found
[19088.541262] sd 11:0:0:0: [sdc] Assuming drive cache: write through
[19088.541270] sd 11:0:0:0: [sdc] Attached SCSI disk
[19088.552229] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.552238] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.552244] Info fld=0x0
[19088.552247] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.552255] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 ff ff ff 80 00 00 08 00
[19088.552267] end_request: I/O error, dev sdc, sector 4294967168
[19088.553691] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.553698] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.553705] Info fld=0x0
[19088.553708] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.553714] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 ff ff ff 80 00 00 08 00
[19088.553726] end_request: I/O error, dev sdc, sector 4294967168
[19088.555326] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.555335] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.555344] Info fld=0x0
[19088.555347] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.555358] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 ff ff ff f0 00 00 08 00
[19088.555375] end_request: I/O error, dev sdc, sector 4294967280
[19088.556836] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.556844] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.556851] Info fld=0x0
[19088.556854] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.556863] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 ff ff ff f0 00 00 08 00
[19088.556876] end_request: I/O error, dev sdc, sector 4294967280
[19088.558306] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.558313] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.558319] Info fld=0x0
[19088.558321] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.558328] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.558339] end_request: I/O error, dev sdc, sector 0
[19088.559830] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.559836] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.559842] Info fld=0x0
[19088.559844] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.559851] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.559862] end_request: I/O error, dev sdc, sector 0
[19088.561303] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.561309] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.561314] Info fld=0x0
[19088.561317] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.561324] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 08 00 00 08 00
[19088.561335] end_request: I/O error, dev sdc, sector 8
[19088.562821] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.562831] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.562840] Info fld=0x0
[19088.562843] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.562852] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 ff ff ff f8 00 00 01 00
[19088.562866] end_request: I/O error, dev sdc, sector 4294967288
[19088.564459] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.564466] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.564472] Info fld=0x0
[19088.564475] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.564482] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 ff ff ff f8 00 00 01 00
[19088.564493] end_request: I/O error, dev sdc, sector 4294967288
[19088.565927] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.565933] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.565940] Info fld=0x0
[19088.565942] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.565949] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 ff ff ff f8 00 00 01 00
[19088.565960] end_request: I/O error, dev sdc, sector 4294967288
[19088.567417] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.567423] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.567428] Info fld=0x0
[19088.567431] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.567438] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 ff ff ff f8 00 00 01 00
[19088.567449] end_request: I/O error, dev sdc, sector 4294967288
[19088.568951] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.568958] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.568964] Info fld=0x0
[19088.568967] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.568973] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 ff ff ff f8 00 00 01 00
[19088.568985] end_request: I/O error, dev sdc, sector 4294967288
[19088.570430] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.570436] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.570442] Info fld=0x0
[19088.570445] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.570451] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 ff ff ff f8 00 00 01 00
[19088.570462] end_request: I/O error, dev sdc, sector 4294967288
[19088.571939] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.571946] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.571951] Info fld=0x0
[19088.571954] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.571961] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 ff ff ff c0 00 00 08 00
[19088.571972] end_request: I/O error, dev sdc, sector 4294967232
[19088.573430] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.573437] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.573444] Info fld=0x0
[19088.573446] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.573453] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 ff ff ff f0 00 00 08 00
[19088.573465] end_request: I/O error, dev sdc, sector 4294967280
[19088.574937] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.574943] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.574949] Info fld=0x0
[19088.574952] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.574959] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 08 00 00 08 00
[19088.574970] end_request: I/O error, dev sdc, sector 8
[19088.576424] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.576431] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.576436] Info fld=0x0
[19088.576439] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.576446] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 08 00 00 08 00
[19088.576457] end_request: I/O error, dev sdc, sector 8
[19088.577905] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.577911] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.577916] Info fld=0x0
[19088.577919] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.577926] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 ff ff ff f8 00 00 01 00
[19088.577937] end_request: I/O error, dev sdc, sector 4294967288
[19088.579426] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.579433] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.579439] Info fld=0x0
[19088.579442] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.579448] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 ff ff ff f8 00 00 01 00
[19088.579460] end_request: I/O error, dev sdc, sector 4294967288
[19088.580923] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.580930] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.580935] Info fld=0x0
[19088.580938] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.580945] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 ff ff ff f8 00 00 01 00
[19088.580957] end_request: I/O error, dev sdc, sector 4294967288
[19088.582411] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.582417] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.582423] Info fld=0x0
[19088.582425] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.582432] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.582443] end_request: I/O error, dev sdc, sector 0
[19088.583886] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.583892] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.583898] Info fld=0x0
[19088.583900] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.583907] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.583918] end_request: I/O error, dev sdc, sector 0
[19088.585404] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.585410] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.585415] Info fld=0x0
[19088.585418] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.585425] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.585435] end_request: I/O error, dev sdc, sector 0
[19088.586932] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.586939] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.586945] Info fld=0x0
[19088.586948] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.586955] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.586966] end_request: I/O error, dev sdc, sector 0
[19088.588405] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.588412] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.588418] Info fld=0x0
[19088.588420] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.588427] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.588438] end_request: I/O error, dev sdc, sector 0
[19088.589881] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.589887] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.589893] Info fld=0x0
[19088.589896] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.589903] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.589914] end_request: I/O error, dev sdc, sector 0
[19088.591376] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.591383] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.591389] Info fld=0x0
[19088.591391] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.591398] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.591409] end_request: I/O error, dev sdc, sector 0
[19088.592910] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.592917] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.592922] Info fld=0x0
[19088.592925] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.592932] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 08 00 00 00 08 00
[19088.592943] end_request: I/O error, dev sdc, sector 2048
[19088.594388] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.594394] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.594400] Info fld=0x0
[19088.594402] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.594409] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.594420] end_request: I/O error, dev sdc, sector 0
[19088.595865] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.595871] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.595877] Info fld=0x0
[19088.595879] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.595886] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.595897] end_request: I/O error, dev sdc, sector 0
[19088.597384] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.597390] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.597395] Info fld=0x0
[19088.597398] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.597404] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.597415] end_request: I/O error, dev sdc, sector 0
[19088.598872] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.598879] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.598885] Info fld=0x0
[19088.598888] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.598895] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.598906] end_request: I/O error, dev sdc, sector 0
[19088.600375] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.600384] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.600391] Info fld=0x0
[19088.600394] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.600403] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.600417] end_request: I/O error, dev sdc, sector 0
[19088.601860] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.601867] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.601873] Info fld=0x0
[19088.601875] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.601882] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.601893] end_request: I/O error, dev sdc, sector 0
[19088.603368] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.603378] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.603386] Info fld=0x0
[19088.603391] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.603401] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.603418] end_request: I/O error, dev sdc, sector 0
[19088.604902] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.604909] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.604914] Info fld=0x0
[19088.604917] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.604924] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.604935] end_request: I/O error, dev sdc, sector 0
[19088.606385] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.606392] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.606398] Info fld=0x0
[19088.606400] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.606407] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.606418] end_request: I/O error, dev sdc, sector 0
[19088.607861] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.607870] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.607877] Info fld=0x0
[19088.607882] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.607891] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.607906] end_request: I/O error, dev sdc, sector 0
[19088.609347] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.609354] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.609360] Info fld=0x0
[19088.609362] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.609369] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.609380] end_request: I/O error, dev sdc, sector 0
[19088.610873] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.610882] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.610890] Info fld=0x0
[19088.610894] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.610903] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.610918] end_request: I/O error, dev sdc, sector 0
[19088.612341] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.612350] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.612358] Info fld=0x0
[19088.612362] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.612372] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.612389] end_request: I/O error, dev sdc, sector 0
[19088.613845] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.613854] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.613863] Info fld=0x0
[19088.613867] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.613876] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.613891] end_request: I/O error, dev sdc, sector 0
[19088.615338] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.615346] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.615354] Info fld=0x0
[19088.615357] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.615366] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 08 00 00 08 00
[19088.615380] end_request: I/O error, dev sdc, sector 8
[19088.616844] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.616852] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.616859] Info fld=0x0
[19088.616862] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.616870] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 08 00 00 08 00
[19088.616883] end_request: I/O error, dev sdc, sector 8
[19088.618373] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.618380] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.618386] Info fld=0x0
[19088.618389] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.618396] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 08 00 00 08 00
[19088.618407] end_request: I/O error, dev sdc, sector 8
[19088.619730] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.619740] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.619748] Info fld=0x0
[19088.619752] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.619762] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 08 00 00 08 00
[19088.619779] end_request: I/O error, dev sdc, sector 8
[19088.621233] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.621240] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.621245] Info fld=0x0
[19088.621248] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.621255] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 18 00 00 08 00
[19088.621266] end_request: I/O error, dev sdc, sector 24
[19088.622756] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.622763] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.622769] Info fld=0x0
[19088.622772] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.622778] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 18 00 00 08 00
[19088.622790] end_request: I/O error, dev sdc, sector 24
[19088.624334] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.624344] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.624351] Info fld=0x0
[19088.624355] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.624365] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 18 00 00 08 00
[19088.624381] end_request: I/O error, dev sdc, sector 24
[19088.625726] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.625733] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.625739] Info fld=0x0
[19088.625742] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.625749] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 18 00 00 08 00
[19088.625760] end_request: I/O error, dev sdc, sector 24
[19088.627206] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.627215] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.627223] Info fld=0x0
[19088.627227] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.627236] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[19088.627252] end_request: I/O error, dev sdc, sector 56
[19088.628720] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.628727] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.628733] Info fld=0x0
[19088.628735] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.628742] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[19088.628753] end_request: I/O error, dev sdc, sector 56
[19088.630213] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.630222] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.630230] Info fld=0x0
[19088.630234] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.630243] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[19088.630258] end_request: I/O error, dev sdc, sector 56
[19088.631675] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.631680] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.631683] Info fld=0x0
[19088.631685] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.631690] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[19088.631697] end_request: I/O error, dev sdc, sector 56
[19088.633065] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.633073] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.633079] Info fld=0x0
[19088.633082] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.633089] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[19088.633100] end_request: I/O error, dev sdc, sector 120
[19088.634573] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.634582] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.634590] Info fld=0x0
[19088.634594] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.634604] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[19088.634620] end_request: I/O error, dev sdc, sector 120
[19088.636072] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.636081] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.636090] Info fld=0x0
[19088.636094] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.636104] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[19088.636120] end_request: I/O error, dev sdc, sector 120
[19088.637565] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.637571] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.637577] Info fld=0x0
[19088.637579] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.637586] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[19088.637597] end_request: I/O error, dev sdc, sector 120
[19088.639050] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.639058] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.639066] Info fld=0x0
[19088.639070] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.639079] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.639096] end_request: I/O error, dev sdc, sector 0
[19088.641724] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.641730] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.641736] Info fld=0x0
[19088.641739] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.641746] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.641757] end_request: I/O error, dev sdc, sector 0
[19088.643184] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.643191] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.643197] Info fld=0x0
[19088.643200] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.643206] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 08 00 00 08 00
[19088.643218] end_request: I/O error, dev sdc, sector 8
[19088.644702] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.644708] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.644714] Info fld=0x0
[19088.644717] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.644724] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 08 00 00 08 00
[19088.644735] end_request: I/O error, dev sdc, sector 8
[19088.646154] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.646160] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.646166] Info fld=0x0
[19088.646168] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.646175] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 18 00 00 08 00
[19088.646186] end_request: I/O error, dev sdc, sector 24
[19088.647688] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.647697] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.647705] Info fld=0x0
[19088.647709] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.647719] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 18 00 00 08 00
[19088.647736] end_request: I/O error, dev sdc, sector 24
[19088.649181] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.649188] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.649193] Info fld=0x0
[19088.649196] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.649203] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[19088.649214] end_request: I/O error, dev sdc, sector 56
[19088.650561] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.650568] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.650574] Info fld=0x0
[19088.650576] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.650583] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[19088.650594] end_request: I/O error, dev sdc, sector 56
[19088.652021] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.652027] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.652033] Info fld=0x0
[19088.652036] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.652042] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[19088.652053] end_request: I/O error, dev sdc, sector 120
[19088.653555] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.653562] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.653568] Info fld=0x0
[19088.653571] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.653577] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[19088.653589] end_request: I/O error, dev sdc, sector 120
[19088.655014] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.655026] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.655038] Info fld=0x0
[19088.655043] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.655056] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.655080] end_request: I/O error, dev sdc, sector 0
[19088.656520] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.656526] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.656532] Info fld=0x0
[19088.656535] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.656542] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.656553] end_request: I/O error, dev sdc, sector 0
[19088.658049] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.658056] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.658061] Info fld=0x0
[19088.658064] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.658071] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.658082] end_request: I/O error, dev sdc, sector 0
[19088.659640] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.659646] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.659651] Info fld=0x0
[19088.659654] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.659660] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.659671] end_request: I/O error, dev sdc, sector 0
[19088.661132] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.661139] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.661144] Info fld=0x0
[19088.661147] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.661154] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.661165] end_request: I/O error, dev sdc, sector 0
[19088.662661] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.662667] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.662673] Info fld=0x0
[19088.662676] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.662682] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.662693] end_request: I/O error, dev sdc, sector 0
[19088.664156] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.664164] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.664173] Info fld=0x0
[19088.664177] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.664187] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 10 00 00 08 00
[19088.664204] end_request: I/O error, dev sdc, sector 16
[19088.665678] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.665685] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.665690] Info fld=0x0
[19088.665693] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.665699] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 80 00 00 08 00
[19088.665711] end_request: I/O error, dev sdc, sector 128
[19088.667135] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.667145] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.667153] Info fld=0x0
[19088.667158] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.667168] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 80 00 00 08 00
[19088.667186] end_request: I/O error, dev sdc, sector 128
[19088.668657] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.668663] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.668669] Info fld=0x0
[19088.668671] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.668678] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 80 00 00 08 00
[19088.668689] end_request: I/O error, dev sdc, sector 128
[19088.670145] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.670152] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.670158] Info fld=0x0
[19088.670160] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.670167] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 10 00 00 08 00
[19088.670178] end_request: I/O error, dev sdc, sector 16
[19088.671615] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.671624] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.671633] Info fld=0x0
[19088.671637] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.671644] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 80 00 00 08 00
[19088.671652] end_request: I/O error, dev sdc, sector 128
[19088.673113] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.673120] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.673125] Info fld=0x0
[19088.673128] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.673135] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[19088.673146] end_request: I/O error, dev sdc, sector 64
[19088.674526] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.674533] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.674539] Info fld=0x0
[19088.674542] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.674548] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[19088.674560] end_request: I/O error, dev sdc, sector 64
[19088.675991] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.675999] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.676005] Info fld=0x0
[19088.676009] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.676016] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[19088.676027] end_request: I/O error, dev sdc, sector 64
[19088.677503] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.677509] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.677515] Info fld=0x0
[19088.677518] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.677525] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[19088.677536] end_request: I/O error, dev sdc, sector 64
[19088.678979] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.678990] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.679002] Info fld=0x0
[19088.679006] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.679018] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[19088.679044] end_request: I/O error, dev sdc, sector 64
[19088.680471] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.680478] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.680484] Info fld=0x0
[19088.680487] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.680494] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[19088.680505] end_request: I/O error, dev sdc, sector 64
[19088.681972] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.681978] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.681983] Info fld=0x0
[19088.681986] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.681992] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[19088.682003] end_request: I/O error, dev sdc, sector 64
[19088.683471] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.683478] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.683484] Info fld=0x0
[19088.683487] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.683494] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[19088.683505] end_request: I/O error, dev sdc, sector 64
[19088.684964] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.684970] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.684976] Info fld=0x0
[19088.684979] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.684985] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[19088.684996] end_request: I/O error, dev sdc, sector 64
[19088.686461] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.686468] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.686473] Info fld=0x0
[19088.686476] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.686483] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[19088.686493] end_request: I/O error, dev sdc, sector 64
[19088.687955] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.687961] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.687967] Info fld=0x0
[19088.687969] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.687976] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 01 00 00 00 08 00
[19088.687987] end_request: I/O error, dev sdc, sector 256
[19088.689464] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.689471] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.689477] Info fld=0x0
[19088.689479] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.689486] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.689497] end_request: I/O error, dev sdc, sector 0
[19088.690860] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.690866] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.690872] Info fld=0x0
[19088.690874] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.690881] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.690906] end_request: I/O error, dev sdc, sector 0
[19088.692325] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.692332] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.692338] Info fld=0x0
[19088.692341] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.692348] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.692359] end_request: I/O error, dev sdc, sector 0
[19088.693823] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.693830] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.693836] Info fld=0x0
[19088.693838] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.693845] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.693856] end_request: I/O error, dev sdc, sector 0
[19088.695324] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.695330] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.695336] Info fld=0x0
[19088.695338] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.695345] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.695356] end_request: I/O error, dev sdc, sector 0
[19088.696855] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.696861] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.696867] Info fld=0x0
[19088.696869] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.696876] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 10 00 00 08 00
[19088.696887] end_request: I/O error, dev sdc, sector 16
[19088.698359] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.698365] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.698371] Info fld=0x0
[19088.698373] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.698380] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.698391] end_request: I/O error, dev sdc, sector 0
[19088.699842] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.699849] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.699855] Info fld=0x0
[19088.699857] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.699864] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.699875] end_request: I/O error, dev sdc, sector 0
[19088.701345] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.701352] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.701359] Info fld=0x0
[19088.701361] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.701368] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.701380] end_request: I/O error, dev sdc, sector 0
[19088.702831] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.702837] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.702842] Info fld=0x0
[19088.702845] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.702852] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.702862] end_request: I/O error, dev sdc, sector 0
[19088.706087] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.706095] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.706101] Info fld=0x0
[19088.706104] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.706110] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.706122] end_request: I/O error, dev sdc, sector 0
[19088.707448] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.707456] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.707464] Info fld=0x0
[19088.707468] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.707477] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.707491] end_request: I/O error, dev sdc, sector 0
[19088.708954] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.708961] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.708967] Info fld=0x0
[19088.708969] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.708976] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.708987] end_request: I/O error, dev sdc, sector 0
[19088.710439] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.710447] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.710455] Info fld=0x0
[19088.710459] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.710468] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.710483] end_request: I/O error, dev sdc, sector 0
[19088.711928] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.711938] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.711946] Info fld=0x0
[19088.711950] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.711960] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.711977] end_request: I/O error, dev sdc, sector 0
[19088.714316] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.714323] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.714329] Info fld=0x0
[19088.714331] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.714338] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.714349] end_request: I/O error, dev sdc, sector 0
[19088.716941] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.716948] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.716954] Info fld=0x0
[19088.716957] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.716964] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.716975] end_request: I/O error, dev sdc, sector 0
[19088.718406] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.718412] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.718418] Info fld=0x0
[19088.718420] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.718427] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.718437] end_request: I/O error, dev sdc, sector 0
[19088.721044] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.721054] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.721063] Info fld=0x0
[19088.721067] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.721076] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 80 00 00 08 00
[19088.721093] end_request: I/O error, dev sdc, sector 128
[19088.722438] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.722446] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.722453] Info fld=0x0
[19088.722457] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.722474] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 80 00 00 08 00
[19088.722486] end_request: I/O error, dev sdc, sector 128
[19088.725148] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.725155] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.725160] Info fld=0x0
[19088.725163] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.725170] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 10 00 00 08 00
[19088.725181] end_request: I/O error, dev sdc, sector 16
[19088.726644] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.726650] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.726656] Info fld=0x0
[19088.726658] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.726665] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.726676] end_request: I/O error, dev sdc, sector 0
[19088.728137] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.728143] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.728149] Info fld=0x0
[19088.728151] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.728158] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.728168] end_request: I/O error, dev sdc, sector 0
[19088.729667] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.729676] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.729685] Info fld=0x0
[19088.729689] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.729698] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 08 00 00 08 00
[19088.729714] end_request: I/O error, dev sdc, sector 8
[19088.731138] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.731144] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.731150] Info fld=0x0
[19088.731152] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.731159] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 10 00 00 08 00
[19088.731170] end_request: I/O error, dev sdc, sector 16
[19088.732667] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.732673] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.732679] Info fld=0x0
[19088.732681] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.732688] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.732700] end_request: I/O error, dev sdc, sector 0
[19088.734157] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.734164] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.734170] Info fld=0x0
[19088.734172] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.734179] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.734190] end_request: I/O error, dev sdc, sector 0
[19088.735627] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.735633] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.735639] Info fld=0x0
[19088.735642] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.735648] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.735659] end_request: I/O error, dev sdc, sector 0
[19088.737160] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.737167] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.737174] Info fld=0x0
[19088.737176] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.737183] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.737195] end_request: I/O error, dev sdc, sector 0
[19088.738650] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.738656] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.738662] Info fld=0x0
[19088.738665] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.738671] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.738682] end_request: I/O error, dev sdc, sector 0
[19088.740154] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.740164] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.740173] Info fld=0x0
[19088.740177] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.740187] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.740204] end_request: I/O error, dev sdc, sector 0
[19088.741670] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.741677] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.741682] Info fld=0x0
[19088.741685] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.741692] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 08 00 00 08 00
[19088.741703] end_request: I/O error, dev sdc, sector 8
[19088.743145] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.743152] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.743157] Info fld=0x0
[19088.743160] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.743167] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 80 00 00 08 00
[19088.743178] end_request: I/O error, dev sdc, sector 128
[19088.744643] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.744649] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.744655] Info fld=0x0
[19088.744658] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.744665] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.744676] end_request: I/O error, dev sdc, sector 0
[19088.746130] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.746136] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.746141] Info fld=0x0
[19088.746144] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.746151] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.746162] end_request: I/O error, dev sdc, sector 0
[19088.747642] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.747650] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.747655] Info fld=0x0
[19088.747658] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.747665] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 10 00 00 00 08 00
[19088.747676] end_request: I/O error, dev sdc, sector 4096
[19088.749137] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.749144] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.749150] Info fld=0x0
[19088.749152] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.749159] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[19088.749170] end_request: I/O error, dev sdc, sector 0
[19088.750495] sd 11:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[19088.750501] sd 11:0:0:0: [sdc] Sense Key : Illegal Request [current]
[19088.750507] Info fld=0x0
[19088.750509] sd 11:0:0:0: [sdc] Add. Sense: Logical block address out of range
[19088.750516] sd 11:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
dmesg info, had to strip away with a major chunk
holy shit 2 tb drive? ermmmmmmmm help help help help please SOS!
thanks!
-paul
 Post subject: Re: SOS! SOS! SOS! Help me please!
PostPosted: January 25th, 2015, 11:57
Hi
Well, you don't need the data, right?
So. move on and get a brand new drive.
When you get that Seagate in second hand, did you tested it? Probably it came already with problems.
ACELab partner
PostPosted: January 25th, 2015, 12:39
hello pclab,
thanks for your concern and reply that too on sunday!
i will answer your questions one by one.
do i need the data? absolutely not. this is more or less a drive where i run too many vm and i mostly use it to build firmware. and the main git server is elsewhere in the lan, so i push pull little from git on this HDD.
moving to new a new HDD? aah!
here is an update i replugged in the device, and my post 2 is still pending and waiting approval and what all i said there, is somehow getting automagically fixed.
viz. now smartctl shows me this.....
smartctl 5.41 2011-06-09 r3365 [x86_64-linux-3.2.0-4-amd64] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family: Seagate Momentus 5400.6
Device Model: ST9500325AS
Serial Number: XXXXXXXX
LU WWN Device Id: X XXXXXX XXXXXXXXXX
Firmware Version: 0021LVM1
User Capacity: 500,107,862,016 bytes [500 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Sun Jan 25 21:23:31 2015 IST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
See vendor-specific Attribute list for failed Attributes.
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x73) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 142) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x103b) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 094 094 034 Pre-fail Always - 150679552
3 Spin_Up_Time 0x0002 099 097 000 Old_age Always - 0
4 Start_Stop_Count 0x0033 100 100 020 Pre-fail Always - 483
5 Reallocated_Sector_Ct 0x0033 001 001 036 Pre-fail Always FAILING_NOW 2047
7 Seek_Error_Rate 0x000f 063 060 030 Pre-fail Always - 2015290
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 253007933472972
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0033 100 100 020 Pre-fail Always - 300
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0033 098 098 099 Pre-fail Always FAILING_NOW 2
187 Reported_Uncorrect 0x0032 100 098 000 Old_age Always - 8590065668
188 Command_Timeout 0x0032 086 086 000 Old_age Always - 12885098510
189 High_Fly_Writes 0x003a 070 057 000 Old_age Always - 505217054
190 Airflow_Temperature_Cel 0x0022 001 001 045 Old_age Always FAILING_NOW 36 (Min/Max 34/36)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 7
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 139
193 Load_Cycle_Count 0x0032 030 099 000 Old_age Always - 30
194 Temperature_Celsius 0x0022 054 053 000 Old_age Always - 12288 (0 18 8 251)
195 Hardware_ECC_Recovered 0x001a 056 044 000 Old_age Always - 63299340572277
196 Reallocated_Event_Count 0x0033 100 001 030 Pre-fail Always In_the_past 0
197 Current_Pending_Sector 0x0012 100 001 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 200 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 --- Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 48939 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 48939 occurred at disk power-on lifetime: 202 hours (8 days + 10 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
04 71 04 91 00 32 e0 Device Fault; Error: ABRT
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
a1 00 00 00 00 00 a0 00 00:36:39.461 IDENTIFY PACKET DEVICE
ec 00 00 00 00 00 a0 00 00:36:39.460 IDENTIFY DEVICE
00 00 00 00 00 00 00 ff 00:36:39.148 NOP [Abort queued commands]
a1 00 00 00 00 00 a0 00 00:36:34.141 IDENTIFY PACKET DEVICE
ec 00 00 00 00 00 a0 00 00:36:34.140 IDENTIFY DEVICE
Error 48938 occurred at disk power-on lifetime: 202 hours (8 days + 10 hours)
00 00 00 00 00 00 00 ff 00:36:33.828 NOP [Abort queued commands]
Error 48937 occurred at disk power-on lifetime: 202 hours (8 days + 10 hours)
a1 00 00 00 00 00 a0 00 00:36:33.789 IDENTIFY PACKET DEVICE
ec 00 00 00 00 00 a0 00 00:36:33.746 IDENTIFY DEVICE
Error 48936 occurred at disk power-on lifetime: 202 hours (8 days + 10 hours)
2f 00 01 10 00 00 a0 00 00:36:33.030 READ LOG EXT
Error 48935 occurred at disk power-on lifetime: 202 hours (8 days + 10 hours)
61 00 00 ff ff ff 4f 00 00:36:33.029 WRITE FPDMA QUEUED
61 00 00 ff ff ff 4f 00 00:36:29.868 WRITE FPDMA QUEUED
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short captive Completed without error 00% 78 -
# 2 Short captive Completed without error 00% 78 -
# 3 Short captive Completed without error 00% 77 -
# 4 Short captive Completed without error 00% 77 -
# 5 Short captive Completed without error 00% 74 -
# 6 Extended offline Interrupted (host reset) 00% 74 -
# 7 Short offline Completed without error 00% 74 -
# 8 Short offline Completed without error 00% 2 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
[root@development-box] [Sun Jan 25, 21:23:32] [20]
[/home/live-user ]
whoa i am not seeing the lba errors! sector errors are gone. i guess its recreating the g-list, hmmmmmmm may be. i am not a pro in this domain you guys are so you guys understand this situation in way much more detail than i do perhaps.
now in the previous post i mentioned totally 12 beeps? 1 shortest and 11 short beeps. and now its gone and i dont hear any beeps. having said that, now it even mkfs.ext4 also way faster w/o spitting error every second in dmesg and thus ddos my syslog!
# time { mkfs.ext4 -v /dev/sdc1 ;}
mke2fs 1.42.5 (29-Jul-2012)
fs_types for mke2fs.conf resolution: 'ext4'
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=0 blocks, Stripe width=0 blocks
7815168 inodes, 31250000 blocks
1562500 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=4294967296
954 block groups
32768 blocks per group, 32768 fragments per group
8192 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624, 11239424, 20480000, 23887872
Allocating group tables: done
Writing inode tables: done
Creating journal (32768 blocks): done
Writing superblocks and filesystem accounting information: done
real 4m47.616s
user 0m0.760s
sys 0m2.184s
# fdisk -l -G /dev/sdc
GNU Fdisk 1.2.4
Copyright (C) 1998 - 2006 Free Software Foundation, Inc.
This program is free software, covered by the GNU General Public License.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
Disk /dev/sdc: 500 GB, 500105249280 bytes
255 heads, 63 sectors/track, 60801 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/sdc1 1 15562 125001733 83 Linux
/dev/sdc2 15562 31124 125001765 83 Linux
/dev/sdc3 31124 46686 125001765 83 Linux
/dev/sdc4 46686 60801 113378737 83 Linux
[root@development-box] [Sun Jan 25, 21:40:51] [23]
[/home/live-user ]
and when i ran mkfs.ext4 it ran with a kill signal and aborted mkfs.ext4.
# time { mkfs.ext4 -v /dev/sdc1 && mkfs.ext4 -v /dev/sdc2 && mkfs.ext4 -v /dev/sdc3 && mkfs.ext4 -v /dev/sdc4; }
Filesystem label=
OS type: Linux
First data block=0
954 block groups
ext2fs_mkdir: Attempt to read block from filesystem resulted in short read while creating root dir
real 2m27.563s
user 0m0.304s
sys 0m1.620s
and the dmesg log again sparks up with block error
[23900.107422] lost page write due to I/O error on sdc1
[23900.107436] Buffer I/O error on device sdc1, logical block 30937652
[23900.107439] lost page write due to I/O error on sdc1
[23900.107448] Buffer I/O error on device sdc1, logical block 30937653
[23900.107451] lost page write due to I/O error on sdc1
[23900.107458] Buffer I/O error on device sdc1, logical block 30937654
[23900.107461] lost page write due to I/O error on sdc1
[23900.107468] Buffer I/O error on device sdc1, logical block 30937655
[23900.107471] lost page write due to I/O error on sdc1
[23900.114074] sd 13:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[23900.114082] sd 13:0:0:0: [sdc] Sense Key : Illegal Request [current]
[23900.114088] Info fld=0x0
[23900.114091] sd 13:0:0:0: [sdc] Add. Sense: Logical block address out of range
[23900.114097] sd 13:0:0:0: [sdc] CDB: Write(10): 2a 00 0e c0 92 9f 00 00 f0 00
[23900.114109] end_request: I/O error, dev sdc, sector 247501471
[23900.120829] sd 13:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[23900.120836] sd 13:0:0:0: [sdc] Sense Key : Illegal Request [current]
[23900.120842] Info fld=0x0
[23900.120845] sd 13:0:0:0: [sdc] Add. Sense: Logical block address out of range
[23900.120852] sd 13:0:0:0: [sdc] CDB: Write(10): 2a 00 0e c0 93 8f 00 00 f0 00
[23900.120863] end_request: I/O error, dev sdc, sector 247501711
[23900.127949] sd 13:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[23900.127956] sd 13:0:0:0: [sdc] Sense Key : Illegal Request [current]
and why not getting rid of it? well FOSS mentality, nothing is waste and lets squeeze the last tip out of the device till its fully non functional.
looks like its healing and then failing? what could be the reason?
did i test the drive when i got it in seconds from the store? yes i did. i did run all tests and smart test too. and it passed with flying colors. the thing is i swap this drive between many laptops either as sata or usb drive. and many times when i am doing openwrt and coreboot development work? and i do happen to screw up this is drive used on those machies that time.
so this is like a caretaker drive and being used for mostly testing and R&D. so i dont wish to throw it away, but fix it and use it till it chokes and finally RIP's.
what i am failing to understand is? what exactly happened? why it started to fail? why the smart tripped? because of R&D in the laptop with may be varying signals in different test laptops? i means voltage power and signals?
and how come a wrong set of commands issued in a complete out of sync fashion got the drive almost dead. and why did the drive stop beeping 1 shortest and 11 shorter beeps? and then recreated the tables. and then when i ran the mkfs.ext4 it started to fail again. what am i missing or failing to register/understand?
may be its too early to dump this drive i will test more and use it a little more. its the drive has reached a point of no return.
but yes if someone wishes to give me the original firmware pref in .lod format and also some help and tips as how to use with hdparm will be nice.
some testing is always nice. and if things work outnice i will write an article such that another user suffers and panics less.
thanks!
-paul
PostPosted: January 25th, 2015, 15:28
Agree with the above post, you need to buy a new drive, don't buy a second hand drive, buy a new one unless you can trust where it came from. I guess you were sold a cheep dead drive that does not work properly. All the messing around won't make it work sorry to say.
Shane
PostPosted: January 26th, 2015, 6:37
@pclab and @shaneward
combined reply since old posts are not accepted or approved for posting, no idea why. i dont know why those replies never got approved. anyway still.
anyway. i am able to fix the drive and it works better now.
@pclab
i didnt need the data, but i needed the drive. its my swap drive. i push it in sata or usb case and use it on various system, without affecting the current drive and setup and et al. so its important that i fix this drive. and after i randomly ran those ata commands over serial protocol. i can sense many things are getting fixed. as in a new glist also. wow. i never knew it could be done before but now i do. as a very long debian user i am able to understand the logic of fixing the drive with bare minimum tools (esply software).
move on and get a new drive? sure all other drives are brand new this is the only second hand drive. and it was working fine. till a power glitch screwed my t410 mobo and that time i was using this hdd to write some coreboot code. so may be it triggered smart. but after running those ata commands over serial protocol i am able to fix a lot of drive issues. and i will try to fix it more and use the drive till it chokes and gets dead. buying a new one is not an issue but using the old one and squeezing the *VERY* best out of the existing one is the motto of FOSS. use as much as you can.
and yes when i did buy this drive, i did test it in a very low level even in raw format using the linux raw kernel module and it passed all tests smart and everything, yes everything and the source is very reliable and genuine hence trusted. the smart trigger happened when i was writing the IRQ tables in coreboot and i screwed up something and it killed my mobo too. yes literally smoke came out and then a burning smell. since then this drive started to act ill.
and @shaneward
all my drives are new. they are working fine. i got this from a reliable source and hence. and also it works like how it should and i dont have any data to loose, because there are no data here. only a few vm's which helps me separate build environment for different os and platform and project, viz, coreboot, openwrt, debwrt, replicant, cyanogenmod and many more, not nonetheless HLFS (hardened linux from scratch) and its pretty handy too and a good real estate (500 gb), so i can plug it on using caddy, sata, usb even raid cards too. plus i am into development arena and nothing important is stored and i can happily store all info on my git server in lan. so all data is stored there. this is a work bench.
i will post the results soon and also how i did it, using what ata commands in a step by step process.
right now even with the lenovo firmware this HP drive is working excellent some chewy errors like smart that too temperature and et al.
anyway rest later.
thanks!
-paul
PostPosted: January 26th, 2015, 9:03
There are a few things I don't understand.. one being why you need THIS drive... seems any drive would be fine for the application.
I have dabbled in most of the projects you have mentioned. While I don't know the relevance of all the chatter about them, I would have thought a developer would not expect a drive that was literally hammered to be still trustworthy. I think people forget that inside these things are very intricate and delicate parts moving at extremely high speeds.. where the slightest deviance of specification can be catastrophic. metal parts at 7,200RPM... arms flying around all controlled by the firmware that is getting told complete hogwash by inexperienced user.. really.. have a think about what you are doing.
If it helps, think of a large web app where you left 1 single file incorrectly world writeable..
PostPosted: January 26th, 2015, 17:19
@Spildit
oh yea? you think you had all the fun yet? well, i hate to disagree. because this time i am logging all the minicom logs. and i am myself laughing my ass off. since i am copying the commands which i need to supply to the minicom prompt. muhahaha! what "NO KNOWLEDGE" work can do can be seen there.
w/o any shame i will upload it. i am a quick learner and i did learn quickly that i need not copy blindly the commands and mindlessly paste it. xD
please understand this, this is the first day here. as a matter of fact this is the first attempt. and i have never done this. and this is not rs-232 3v to some mips router or some arm development port or even null cable coreboot instance. i have some tcp/ip mode there atleast, here none ;-)
and i am not into data recovery already i have enough heeadache in live w.r.t. my profession. i dont need an extra headache. but my goal is to try and port some open source alternative to this.
having said that i will try to answer haque now
@haque
frankly i dont need this drive at all. its more or less dumb ass rebel attitude who is yet to learn the basics of these AT command environment. xD more or less fun and a good timepass and also learn and R&D. i have to admit i never visited this forum ever before. but as i am exploring this forum i am more and more amused entertained and wanting to learn more. the R&D method. yes i do know i can buy those expensive devices which professionals use it to earn their bread and butter but i intend to use it for pure R&D.
i can use any mode to go from point a to point b. but if i walk i get to see more and learn more and enjoy life more. and this is fun cum adventure. more or less like firewalking related to HDD more or less very specific to hdd. which i never spent a single second. and i always keep 3 drives each 1 terabytes for backup. one for main backup, and other as replicant of the main drive. incase i loose data or drive fails. i can still use the other 2 drives to carry on.
and like how you answered your own question those projects keeps me seriously busy all the time. and that gets me cake and champagne for life. but the whole issue started with one glitch.
i was trying to play with irq tables and acpi for the thinkpad t410 which i am trying port coreboot and make it work. and some screw up in the code blew the mobo out completely. that time this hdd was in that laptop. i keep editing the codes now and then. sometime it works and many times i need to redo everything from scratch. so after the mobo replacement, i didnt notice any flaw in the drive. and only recently it started to tremendously slow up.
as a developer normal instinct will be upgrade to newer firmware, for new features(bugs), but this time i was left in open sea. i quickly search for 0005HPM1 for the hp firmware and i find nothing. and i find the closest being lenovo. so i installed it and the trouble began.
i should have googled before i installed that firmware. since i normally download firmware and upload it via hdparm and walk back to my work i never bothered. but this time..... things went all wrong.
and i dont have a clue as of now. and this also did push my interest towards a open firmware kind of thing for hdd too. if we can run FOSS in router and modems and phones and finally most critically complex bios/uefi in server/desktops/laptops why not hdd?
so the hdd failure pushed me to this forum and all you folks are either pissed off and annoyed or i have resulted myself in being a laughing stock.
and like i said before i dont have the tools needed, just a serial connection, wd160 usb drive's header, cables that all. i didnt open the drive and i dont even know whats inside except i see a controller which i guess is arm arch. nothing more i know or did i do whatsoever as of now.
and i also understand your concern that those dangerously moving flying parts, just because debian states "if you break the OS, you get to keep the flying parts" wrt to sid doesnt mean i will do the same with HDD too. this is unchartered territory. and i must admit i dont anything at al. and any help is really appriciated. and secondly chmod 0777 /etc/shadow? muhahahaha! classic!
i will try not to entertain you folks with my stupidity. but i understood onething. unless i learn the basics i should not try to do this. and FOSS firmware and when you login you get a root shell? well, it will be a dream as of now. may be sometime in future.. who knows? ;-)
and coming to the current issue?
viewtopic.php?t=15155&start=#p99337 -> something same, and i am sure it a firmware issue, because i am using a lenovo firmware on a hp device. xD!
thanks!
-paul
PostPosted: January 26th, 2015, 18:35
uploading the logs. yes i am ashamed of this incredible cut copy paste stupidity, but i will follow the FOSS principle, well share the laughter with others too. and let others know how stupid i am also also what all stupid things i did.
thanks!
-paul
File comment: logs and also a scope for you all to laugh and also learn from my stupidity.
spildit-and-thers-you-may-please-lol-now-DOS.txt [316.13 KiB]
Downloaded 616 times
spildit-and-thers-you-may-please-lol-now.txt [313.62 KiB]
Downloaded 549 times
PostPosted: January 26th, 2015, 23:38
it isn't about laughing at someone that is clueless to HDD's.. I myself are not that knowledgeable in the terminal of a HDD.
Forget FOSS for HDD's, You underestimate the massive amount of development this would take and the tools required. Unless you disassembled each firmware and rewrote it with that as a base, then without the tools of a HDD manufacturer this would be impossible. Who is going to maintin it for each new Model or feature?
if you look at how relatively slow something like Sigrok is to support new devices, trying to do a similar thing, you should realise the fruitfulness of that dream.
as for spending so much time and expecting others to do the same.. I don't agree it has much value.
You may be trying to be conversational and add humour but sorry it comes across as arrogant and a little rude. sorry if this wasn't your intention.
How will you know and can be sure the drive is in optimal state for use again. Unless you can be sure, I class it as a ticking time bomb. I would never trust that disk again - especially after you have operated on it as you describe.
I cant see a future for this thread either.
PostPosted: January 27th, 2015, 18:50
Folks,
I have removed the last two posts, please keep things civil.
Dmitry
Users browsing this forum: No registered users and 82 guests
