 Post subject: Maxtor 7L300R0-BAH41G10 hot swap
PostPosted: February 19th, 2015, 7:58
does anyone know the proper procedure how to hot swap old Maxtor (Vulcan) drive?
Which mods do i have to write from patient to donor?
My firmware database:
 Post subject: Re: Maxtor 7L300R0-BAH41G10 hot swap
PostPosted: February 19th, 2015, 9:19
Please, tell me which mods do i have to write on donor for hot swap, thanks:
Enable combination ...
Module 00.......................... : 47F60002_00.rpm
Module 01.......................... : 47F80002_01.rpm
Module 03.......................... : 47FA0001_03.rpm
Module 04.......................... : 47FC0078_04.rpm
Module 05.......................... : 488A0001_05.rpm
Module 08.......................... : 488B0001_08.rpm
Module 09.......................... : 488D0001_09.rpm
Module 0A.......................... : 488E0001_0A.rpm
Module 0B.......................... : 488F0001_0B.rpm
Module 0C.......................... : 48900001_0C.rpm
Module 0D.......................... : 22DA0003_0D.rpm
Module 0E.......................... : 22DD0008_0E.rpm
Module 0F.......................... : 22E50001_0F.rpm
Module 10.......................... : 22E60002_10.rpm
Module 11.......................... : 22E90001_11.rpm
Module 12.......................... : 252608E8_12.rpm
Module 13.......................... : 22EB0008_13.rpm
Module 14.......................... : 24A6000B_14.rpm
Module 16.......................... : 24D20040_16.rpm
Module 18.......................... : 00290139_18.rpm
Module 18.......................... : 4A610139_18.rpm
Module 19.......................... : 01910001_19.rpm
Module 19.......................... : 4BC90001_19.rpm
Module 1A.......................... : 01920001_1A.rpm
Module 1A.......................... : 4BCA0001_1A.rpm
Module 1B.......................... : 02AB0032_1B.rpm
Module 1B.......................... : 4CE30032_1B.rpm
Module 1C.......................... : 01A60002_1C.rpm
Module 1C.......................... : 4BDE0002_1C.rpm
Module 1D.......................... : 02A90002_1D.rpm
Module 1D.......................... : 4CE10002_1D.rpm
Module 1E.......................... : 018E0002_1E.rpm
Module 1E.......................... : 4BC60002_1E.rpm
Module 1F.......................... : 00080001_1F.rpm
Module 1F.......................... : 4A400001_1F.rpm
Module 20.......................... : 02DD0002_20.rpm
Module 20.......................... : 4D150002_20.rpm
Module 21.......................... : 0162000B_21.rpm
Module 21.......................... : 4B9A000B_21.rpm
Module 22.......................... : 01A40001_22.rpm
Module 22.......................... : 4BDC0001_22.rpm
Module 24.......................... : 359A01B2_24.rpm
Module 25.......................... : 44DA0008_25.rpm
Module 27.......................... : 374C000C_27.rpm
Module 28.......................... : 375806C8_28.rpm
Module 29.......................... : 3E200020_29.rpm
Module 2A.......................... : 48910001_2A.rpm
Module 2B.......................... : 4892000C_2B.rpm
Module 2D.......................... : 489E000C_2D.rpm
Module 2F.......................... : 01930001_2F.rpm
Module 2F.......................... : 4BCB0001_2F.rpm
Module 30.......................... : 01940001_30.rpm
Module 30.......................... : 4BCC0001_30.rpm
Module 32.......................... : 01A50001_32.rpm
Module 32.......................... : 4BDD0001_32.rpm
Module 33.......................... : 1ADA0800_33.rpm
Module 34.......................... : 01A80100_34.rpm
Module 34.......................... : 4BE00100_34.rpm
Module 37.......................... : 00040001_37.rpm
Module 37.......................... : A66C0001_37.rpm
Module 38.......................... : 0A6800A0_38.rpm
Module 38.......................... : 54A000A0_38.rpm
Module 39.......................... : 09680100_39.rpm
Module 39.......................... : 53A00100_39.rpm
Module 3A.......................... : 44EA0028_3A.rpm
Module 3B.......................... : 44E20008_3B.rpm
Module 3C.......................... : 45120050_3C.rpm
Module 3D.......................... : 45620100_3D.rpm
Module 41.......................... : 01960002_41.rpm
Module 41.......................... : 4BCE0002_41.rpm
Module 42.......................... : 25230003_42.rpm
Module 43.......................... : 22E80001_43.rpm
Module 44.......................... : 01900001_44.rpm
Module 44.......................... : 4BC80001_44.rpm
Module 45.......................... : 0198000C_45.rpm
Module 45.......................... : 4BD0000C_45.rpm
Module 46.......................... : 24B1000B_46.rpm
Module 47.......................... : 24BC000B_47.rpm
Module 48.......................... : 02A80001_48.rpm
Module 48.......................... : 4CE00001_48.rpm
Module 49.......................... : 23A30020_49.rpm
Module 4A.......................... : 24A40002_4A.rpm
Module 4B.......................... : 3E400001_4B.rpm
Module 4C.......................... : 22EA0001_4C.rpm
Module 4D.......................... : 47FB0001_4D.rpm
Module 4E.......................... : 488C0001_4E.rpm
Module 4F.......................... : 0B080360_4F.rpm
Module 4F.......................... : 55400360_4F.rpm
Module 54.......................... : 3E410004_54.rpm
Module 55.......................... : 3E490002_55.rpm
Module 56.......................... : 22F300A0_56.rpm
Module 57.......................... : 3E4F000C_57.rpm
Module 58.......................... : 25120011_58.rpm
Module 59.......................... : 2E0E000C_59.rpm
Module 5A.......................... : 48740008_5A.rpm
Module 5B.......................... : 487C0002_5B.rpm
Module 5C.......................... : 487E000C_5C.rpm
Module 5D.......................... : 48AA0003_5D.rpm
Module 5E.......................... : 02F80111_5E.rpm
Module 5E.......................... : 4D300111_5E.rpm
Module 5F.......................... : 48AD0001_5F.rpm
Module 60.......................... : 3E4B0004_60.rpm
Module 61.......................... : 2E1A0001_61.rpm
Module 62.......................... : 2E1B0001_62.rpm
Module 63.......................... : 01950001_63.rpm
Module 63.......................... : 4BCD0001_63.rpm
Module 64.......................... : 02E00001_64.rpm
Module 64.......................... : 4D180001_64.rpm
Module 65.......................... : 02E10009_65.rpm
Module 65.......................... : 4D190009_65.rpm
Module 66.......................... : 02EA0009_66.rpm
Module 66.......................... : 4D220009_66.rpm
Module 67.......................... : 02F30005_67.rpm
Module 67.......................... : 4D2B0005_67.rpm
Module 68.......................... : 22DC0001_68.rpm
Module 69.......................... : 23930010_69.rpm
Module 6A.......................... : 24A30001_6A.rpm
Module 6B.......................... : 24C7000B_6B.rpm
Module 6E.......................... : 3F980004_6E.rpm
Module 70.......................... : 04090001_70.rpm
Module 70.......................... : 4E410001_70.rpm
Module 71.......................... : 040A0001_71.rpm
Module 71.......................... : 4E420001_71.rpm
Module 72.......................... : 040B0020_72.rpm
Module 72.......................... : 4E430020_72.rpm
Module 73.......................... : 042B0008_73.rpm
Module 73.......................... : 4E630008_73.rpm
Module 74.......................... : 48AE0001_74.rpm
Module 75.......................... : 48AF0001_75.rpm
Module 76.......................... : 48B00001_76.rpm
Module 77.......................... : 2E1C0001_77.rpm
Module 78.......................... : 00090020_78.rpm
Module 78.......................... : 4A410020_78.rpm
Module 79.......................... : 48B10001_79.rpm
Module 7A.......................... : A66C0001_7A.rpm
Module 7A.......................... : 4CD40001_7A.rpm
Module 7B.......................... : 04330008_7B.rpm
Module 7B.......................... : 4E6B0008_7B.rpm
Module 81.......................... : 23A30100_81.rpm
Module 82.......................... : 48B20002_82.rpm
Module 83.......................... : 48B60004_83.rpm
Module 84.......................... : 48BA0001_84.rpm
Module 85.......................... : 48BB0001_85.rpm
Module 86.......................... : 48BC000C_86.rpm
Module 87.......................... : 48C80001_87.rpm
Module 88.......................... : 48C90001_88.rpm
Module 89.......................... : 48CA000C_89.rpm
Module 8A.......................... : 48D60002_8A.rpm
Module 8B.......................... : 48D80002_8B.rpm
Module 8C.......................... : 2E1D0188_8C.rpm
Module 8D.......................... : 2FA50004_8D.rpm
Module 8E.......................... : 48DA0001_8E.rpm
Module 8F.......................... : 48DB0004_8F.rpm
Module 90.......................... : 2FA900A0_90.rpm
Module 92.......................... : 3E5B0048_92.rpm
Module 93.......................... : 043B0080_93.rpm
Module 93.......................... : 4E730080_93.rpm
Module 94.......................... : 053B0040_94.rpm
Module 94.......................... : 4F730040_94.rpm
Module 96.......................... : 130800A0_96.rpm
Module 96.......................... : 5D4000A0_96.rpm
Module 97.......................... : 12080100_97.rpm
Module 97.......................... : 5C400100_97.rpm
Module 98.......................... : 13A80360_98.rpm
Module 98.......................... : 5DE00360_98.rpm
Module 99.......................... : 057B0002_99.rpm
Module 99.......................... : 4FB30002_99.rpm
Module 9A.......................... : 057D0002_9A.rpm
Module 9A.......................... : 4FB50002_9A.rpm
Module 9B.......................... : 30490004_9B.rpm
Module 9C.......................... : 3EA30040_9C.rpm
Module 9D.......................... : 48DF0001_9D.rpm
Module 9E.......................... : 057F0002_9E.rpm
Module 9E.......................... : 4FB70002_9E.rpm
Module 9F.......................... : 48E00002_9F.rpm
Module A0.......................... : 3EE30064_A0.rpm
Module A1.......................... : 3F470003_A1.rpm
Module A2.......................... : 48E20002_A2.rpm
Module A5.......................... : 05810004_A5.rpm
Module A5.......................... : 4FB90004_A5.rpm
Module A6.......................... : 05850002_A6.rpm
Module A6.......................... : 4FBD0002_A6.rpm
Module A7.......................... : 1AA80032_A7.rpm
Module A9.......................... : 3F500048_A9.rpm
Module AA.......................... : 304D0004_AA.rpm
Module AB.......................... : 48E40008_AB.rpm
Module AC.......................... : 30510008_AC.rpm
Module AD.......................... : 3F9C0529_AD.rpm
Module AE.......................... : 30590011_AE.rpm
Module AF.......................... : 0587000E_AF.rpm
Module B0.......................... : 306A0004_B0.rpm
Module B1.......................... : 306E0008_B1.rpm
Module B2.......................... : 44C50015_B2.rpm
Module B3.......................... : Saving error
Module B4.......................... : Saving error
Module B6.......................... : 3076000E_B6.rpm
Module C0.......................... : 30840003_C0.rpm
Module C1.......................... : 48EC0003_C1.rpm
Module CB.......................... : 46620030_CB.rpm
Module CC.......................... : 30870008_CC.rpm
Module CF.......................... : 05950002_CF.rpm
Module FF.......................... : 00000008_FF.rpm
Module FF.......................... : A6680008_FF.rpm
Batch backup module................ : Complete
Users browsing this forum: Google [Bot] and 69 guests
