 Post subject: Western Digital WD1002FBYS Recovery Help
PostPosted: February 19th, 2015, 23:33
Hello all,
I am having a problem recovering data from this hard drive. The drive is visible in Bios, but I can not see it in either Diskpart, or Gparted.
It is not shown in the /dev folder.
It does seem to spool up normally, with no strange noises that would indicate physical failure.
I did , however, manage to get it to appear in Dmesg. Here is the log starting with what I think is the initialisation of the storage subsystem:
[    3.459370] libata version 3.00 loaded.
[    3.459662] pata_jmicron 0000:06:00.1: enabling device (0000 -> 0001)
[    3.460596] scsi0 : pata_jmicron
[    3.460715] scsi1 : pata_jmicron
[    3.460775] ata1: PATA max UDMA/100 cmd 0xdf00 ctl 0xde00 bmdma 0xdb00 irq 17
[    3.460777] ata2: PATA max UDMA/100 cmd 0xdd00 ctl 0xdc00 bmdma 0xdb08 irq 17
[    3.460799] pata_jmicron 0000:07:00.1: enabling device (0000 -> 0001)
[    3.460941] ahci 0000:06:00.0: version 3.0
[    3.461496] ehci-pci 0000:00:1a.7: cache line size of 64 is not supported
[    3.461503] ehci-pci 0000:00:1a.7: irq 18, io mem 0xf3ffe000
[    3.461592] scsi2 : pata_jmicron
[    3.461716] scsi3 : pata_jmicron
[    3.461785] ata3: PATA max UDMA/100 cmd 0xcf00 ctl 0xce00 bmdma 0xcb00 irq 18
[    3.461787] ata4: PATA max UDMA/100 cmd 0xcd00 ctl 0xcc00 bmdma 0xcb08 irq 18
[    3.472091] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[    3.472280] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.472283] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.472285] usb usb1: Product: EHCI Host Controller
[    3.472286] usb usb1: Manufacturer: Linux 3.16.0-4-686-pae ehci_hcd
[    3.472287] usb usb1: SerialNumber: 0000:00:1a.7
[    3.472437] hub 1-0:1.0: USB hub found
[    3.472497] hub 1-0:1.0: 6 ports detected
[    3.473060] ehci-pci 0000:00:1d.7: EHCI Host Controller
[    3.473065] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 2
[    3.473077] ehci-pci 0000:00:1d.7: debug port 1
[    3.476160] ahci 0000:06:00.0: AHCI 0001.0000 32 slots 2 ports 3 Gbps 0x3 impl SATA mode
[    3.476164] ahci 0000:06:00.0: flags: 64bit ncq pm led clo pmp pio slum part
[    3.476710] scsi4 : ahci
[    3.476930] scsi5 : ahci
[    3.476992] ata5: SATA max UDMA/133 abar m8192@0xf39fe000 port 0xf39fe100 irq 16
[    3.476992] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[    3.476997] ata6: SATA max UDMA/133 abar m8192@0xf39fe000 port 0xf39fe180 irq 16
[    3.477004] ehci-pci 0000:00:1d.7: irq 23, io mem 0xf3ffd000
[    3.477123] ahci 0000:07:00.0: AHCI 0001.0000 32 slots 2 ports 3 Gbps 0x3 impl SATA mode
[    3.477126] ahci 0000:07:00.0: flags: 64bit ncq pm led clo pmp pio slum part
[    3.477487] scsi6 : ahci
[    3.477802] scsi7 : ahci
[    3.477860] ata7: SATA max UDMA/133 abar m8192@0xf37fe000 port 0xf37fe100 irq 17
[    3.477866] ata8: SATA max UDMA/133 abar m8192@0xf37fe000 port 0xf37fe180 irq 17
[    3.488164] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    3.488206] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    3.488209] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.488210] usb usb2: Product: EHCI Host Controller
[    3.488212] usb usb2: Manufacturer: Linux 3.16.0-4-686-pae ehci_hcd
[    3.488213] usb usb2: SerialNumber: 0000:00:1d.7
[    3.488455] hub 2-0:1.0: USB hub found
[    3.488461] hub 2-0:1.0: 6 ports detected
[    3.488859] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[    3.488864] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[    3.488870] uhci_hcd 0000:00:1a.0: detected 2 ports
[    3.488892] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000ff00
[    3.489026] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    3.489029] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.489032] usb usb3: Product: UHCI Host Controller
[    3.489033] usb usb3: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd
[    3.489035] usb usb3: SerialNumber: 0000:00:1a.0
[    3.489257] hub 3-0:1.0: USB hub found
[    3.489276] hub 3-0:1.0: 2 ports detected
[    3.489628] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[    3.489635] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[    3.489643] uhci_hcd 0000:00:1a.1: detected 2 ports
[    3.489675] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000fe00
[    3.489868] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    3.489871] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.489872] usb usb4: Product: UHCI Host Controller
[    3.489874] usb usb4: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd
[    3.489875] usb usb4: SerialNumber: 0000:00:1a.1
[    3.490001] hub 4-0:1.0: USB hub found
[    3.490059] hub 4-0:1.0: 2 ports detected
[    3.490342] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[    3.490347] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
[    3.490353] uhci_hcd 0000:00:1a.2: detected 2 ports
[    3.490371] uhci_hcd 0000:00:1a.2: irq 19, io base 0x0000fd00
[    3.490472] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    3.490474] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.490476] usb usb5: Product: UHCI Host Controller
[    3.490477] usb usb5: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd
[    3.490479] usb usb5: SerialNumber: 0000:00:1a.2
[    3.490702] hub 5-0:1.0: USB hub found
[    3.490725] hub 5-0:1.0: 2 ports detected
[    3.491028] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    3.491033] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[    3.491038] uhci_hcd 0000:00:1d.0: detected 2 ports
[    3.491057] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000fc00
[    3.491219] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    3.491221] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.491223] usb usb6: Product: UHCI Host Controller
[    3.491224] usb usb6: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd
[    3.491225] usb usb6: SerialNumber: 0000:00:1d.0
[    3.491360] hub 6-0:1.0: USB hub found
[    3.491377] hub 6-0:1.0: 2 ports detected
[    3.491748] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    3.491756] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[    3.491768] uhci_hcd 0000:00:1d.1: detected 2 ports
[    3.491798] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000fb00
[    3.491975] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    3.491976] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.491978] usb usb7: Product: UHCI Host Controller
[    3.491979] usb usb7: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd
[    3.491981] usb usb7: SerialNumber: 0000:00:1d.1
[    3.492131] hub 7-0:1.0: USB hub found
[    3.492142] hub 7-0:1.0: 2 ports detected
[    3.492379] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    3.492385] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[    3.492392] uhci_hcd 0000:00:1d.2: detected 2 ports
[    3.492411] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000fa00
[    3.492583] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[    3.492584] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.492586] usb usb8: Product: UHCI Host Controller
[    3.492587] usb usb8: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd
[    3.492589] usb usb8: SerialNumber: 0000:00:1d.2
[    3.492697] hub 8-0:1.0: USB hub found
[    3.492754] hub 8-0:1.0: 2 ports detected
[    3.492930] ata_piix 0000:00:1f.2: version 2.13
[    3.493048] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[    3.494356] scsi8 : ata_piix
[    3.494531] scsi9 : ata_piix
[    3.494574] ata9: SATA max UDMA/133 cmd 0xf900 ctl 0xf800 bmdma 0xf500 irq 19
[    3.494582] ata10: SATA max UDMA/133 cmd 0xf700 ctl 0xf600 bmdma 0xf508 irq 19
[    3.494699] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[    3.495317] scsi10 : ata_piix
[    3.495483] scsi11 : ata_piix
[    3.495527] ata11: SATA max UDMA/133 cmd 0xf200 ctl 0xf100 bmdma 0xee00 irq 19
[    3.495530] ata12: SATA max UDMA/133 cmd 0xf000 ctl 0xef00 bmdma 0xee08 irq 19
[    3.516295] firewire_ohci 0000:0b:03.0: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x2
[    3.626253] ata3.00: ATA-7: Maxtor 6Y160P0, YAR41VW0, max UDMA/133
[    3.626257] ata3.00: 320173056 sectors, multi 0: LBA48
[    3.642227] ata3.00: configured for UDMA/100
[    3.787094] usb 1-5: new high-speed USB device number 2 using ehci-pci
[    3.787303] scsi 2:0:0:0: Direct-Access     ATA      Maxtor 6Y160P0   1VW0 PQ: 0 ANSI: 5
[    3.796346] ata5: SATA link down (SStatus 0 SControl 300)
[    3.796403] ata6: SATA link down (SStatus 0 SControl 300)
[    3.796405] ata8: SATA link down (SStatus 0 SControl 300)
[    3.796450] ata7: SATA link down (SStatus 0 SControl 300)
[    3.834843] ata11: SATA link down (SStatus 0 SControl 300)
[    3.922606] usb 1-5: New USB device found, idVendor=13fe, idProduct=4200
[    3.922611] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.922614] usb 1-5: Product: USB DISK 2.0
[    3.922616] usb 1-5: Manufacturer:
[    3.922619] usb 1-5: SerialNumber: 070A4A18AFAFA722
[    3.925661] usb-storage 1-5:1.0: USB Mass Storage device detected
[    3.925903] scsi12 : usb-storage 1-5:1.0
[    3.926006] usbcore: registered new interface driver usb-storage
[    3.964241] ata12: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    3.972716] ata12.00: ATA-7: WDC WD2500KS-00MJB0, 02.01C03, max UDMA/133
[    3.972720] ata12.00: 488397168 sectors, multi 16: LBA48
[    3.980602] ata12.00: configured for UDMA/133
[    4.004199] tsc: Refined TSC clocksource calibration: 2653.350 MHz
[    4.016365] firewire_core 0000:0b:03.0: created device fw0: GUID 696100006e566964, S400
[    4.272451] usb 7-1: new low-speed USB device number 2 using uhci_hcd
[    4.284430] ata9.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    4.284459] ata9.01: SATA link down (SStatus 0 SControl 300)
[    4.284473] ata9.01: link offline, clearing class 3 to NONE
[    4.284601] ata10.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    4.284616] ata10.01: SATA link down (SStatus 0 SControl 300)
[    4.292601] ata9.00: ATAPI: HL-DT-ST BD-RE  GGW-H20L, YL05, max UDMA/133
[    4.300333] ata10.00: ATA-8: WDC WD1002FBYS-02A6B0, 03.00C06, max UDMA/133
[    4.300337] ata10.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[    4.308662] ata9.00: configured for UDMA/133
[    4.309551] ata10.00: configured for UDMA/133
[    4.320353] scsi 8:0:0:0: CD-ROM            HL-DT-ST BD-RE  GGW-H20L  YL05 PQ: 0 ANSI: 5
[    4.330931] scsi 9:0:0:0: Direct-Access     ATA      WDC WD1002FBYS-0 0C06 PQ: 0 ANSI: 5
[    4.331319] scsi 11:0:0:0: Direct-Access     ATA      WDC WD2500KS-00M 1C03 PQ: 0 ANSI: 5
[    4.333249] sd 2:0:0:0: [sda] 320173056 512-byte logical blocks: (163 GB/152 GiB)
[    4.333323] sd 2:0:0:0: [sda] Write Protect is off
[    4.333335] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    4.333357] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.336670] sr0: scsi3-mmc drive: 125x/125x writer dvd-ram cd/rw xa/form2 cdda tray
[    4.336674] cdrom: Uniform CD-ROM driver Revision: 3.20
[    4.336869] sr 8:0:0:0: Attached scsi CD-ROM sr0
[    4.337133] sd 9:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[    4.337156] sd 9:0:0:0: [sdb] Write Protect is off
[    4.337158] sd 9:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    4.337169] sd 9:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.337215] sd 11:0:0:0: [sdc] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[    4.337346] sd 11:0:0:0: [sdc] Write Protect is off
[    4.337350] sd 11:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[    4.337395] sd 11:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.337635] sd 2:0:0:0: Attached scsi generic sg0 type 0
[    4.337741] sr 8:0:0:0: Attached scsi generic sg1 type 5
[    4.337809] sd 9:0:0:0: Attached scsi generic sg2 type 0
[    4.337872] sd 11:0:0:0: Attached scsi generic sg3 type 0
[    4.344471]  sdb: sdb1 sdb2
[    4.344892] sd 9:0:0:0: [sdb] Attached SCSI disk
[    4.357974]  sda: sda1 sda2 < sda5 >
[    4.358722] sd 2:0:0:0: [sda] Attached SCSI disk
[    4.366645]  sdc: sdc1 sdc2 < sdc5 >
[    4.368009] sd 11:0:0:0: [sdc] Attached SCSI disk
[    4.369535] random: nonblocking pool is initialized
[    4.447067] usb 7-1: New USB device found, idVendor=046d, idProduct=c501
[    4.447071] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.447074] usb 7-1: Product: USB Receiver
[    4.447077] usb 7-1: Manufacturer: Logitech
[    4.452208] hidraw: raw HID events driver (C) Jiri Kosina
[    4.470184] usbcore: registered new interface driver usbhid
[    4.470185] usbhid: USB HID core driver
[    4.470977] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1d.1/usb7/7-1/7-1:1.0/0003:046D:C501.0001/input/input2
[    4.471062] hid-generic 0003:046D:C501.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB Receiver] on usb-0000:00:1d.1-1/input0
[    4.816437] usb 8-2: new low-speed USB device number 2 using uhci_hcd
[    4.926287] scsi 12:0:0:0: Direct-Access              USB DISK 2.0     PMAP PQ: 0 ANSI: 6
[    4.926750] sd 12:0:0:0: Attached scsi generic sg4 type 0
[    4.927828] sd 12:0:0:0: [sdd] 15654912 512-byte logical blocks: (8.01 GB/7.46 GiB)
[    4.929804] sd 12:0:0:0: [sdd] Write Protect is off
[    4.929809] sd 12:0:0:0: [sdd] Mode Sense: 23 00 00 00
[    4.931672] sd 12:0:0:0: [sdd] No Caching mode page found
[    4.931764] sd 12:0:0:0: [sdd] Assuming drive cache: write through
[    4.940330]  sdd: sdd1
[    4.946812] sd 12:0:0:0: [sdd] Attached SCSI removable disk
[    4.994600] usb 8-2: New USB device found, idVendor=258a, idProduct=0001
[    4.994605] usb 8-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.994610] usb 8-2: Product: USB KEYBOARD
[    4.994612] usb 8-2: Manufacturer: SINO WEALTH
[    5.004689] Switched to clocksource tsc
[    5.012825] input: SINO WEALTH USB KEYBOARD as /devices/pci0000:00/0000:00:1d.2/usb8/8-2/8-2:1.0/0003:258A:0001.0002/input/input3
[    5.012879] hid-generic 0003:258A:0001.0002: input,hidraw1: USB HID v1.10 Keyboard [SINO WEALTH USB KEYBOARD] on usb-0000:00:1d.2-2/input0
[    5.052693] input: SINO WEALTH USB KEYBOARD as /devices/pci0000:00/0000:00:1d.2/usb8/8-2/8-2:1.1/0003:258A:0001.0003/input/input4
[    5.052782] hid-generic 0003:258A:0001.0003: input,hiddev0,hidraw2: USB HID v1.10 Device [SINO WEALTH USB KEYBOARD] on usb-0000:00:1d.2-2/input1
[   34.898208] ata10.00: exception Emask 0x0 SAct 0x0 SErr 0x800000 action 0x6 frozen
[   34.898323] ata10.00: SError: { LinkSeq }
[   34.898433] ata10.00: failed command: READ DMA
[   34.898539] ata10.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
         res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[   34.898663] ata10.00: status: { DRDY }
[   34.898771] ata10.00: hard resetting link
[   35.218168] ata10.01: hard resetting link
[   35.694343] ata10.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[   35.694364] ata10.01: SATA link down (SStatus 0 SControl 300)
[   35.710959] ata10.00: configured for UDMA/133
[   35.710965] ata10.00: device reported invalid CHS sector 0
[   35.710973] ata10: EH complete
[   65.830544] Atheros(R) L2 Ethernet Driver - version 2.2.3
[   65.830547] Copyright (c) 2007 Atheros Corporation.
[   65.835845] bnx2x: Broadcom NetXtreme II 5771x/578xx 10/20-Gigabit Ethernet Driver bnx2x 1.78.19-0 (2014/02/10)
[   65.844610] device-mapper: uevent: version 1.0.3
[   65.844663] device-mapper: ioctl: 4.27.0-ioctl (2013-10-30) initialised: dm-devel@redhat.com
[   66.007994] FAT-fs (sdd1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[   66.011892] ata10.00: exception Emask 0x0 SAct 0x0 SErr 0x800000 action 0x6 frozen
[   66.011979] ata10.00: SError: { LinkSeq }
[   66.012061] ata10.00: failed command: READ DMA
[   66.012144] ata10.00: cmd c8/00:08:70:2b:03/00:00:00:00:00/e0 tag 0 dma 4096 in
[   66.012261] ata10.00: status: { DRDY }
[   66.012342] ata10.00: hard resetting link
[   66.335958] ata10.01: hard resetting link
[   66.812144] ata10.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[   66.812163] ata10.01: SATA link down (SStatus 0 SControl 300)
[   66.829126] ata10.00: configured for UDMA/133
[   66.829133] ata10.00: device reported invalid CHS sector 0
[   66.829144] ata10: EH complete
[   81.978593] aufs: module is from the staging directory, the quality is unknown, you have been warned.
[   81.980974] aufs 3.16-20140908
[   81.992668] loop: module loaded
[   82.005965] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[   95.170768] systemd-udevd[767]: starting version 215
[   95.998082] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   96.261324] wmi: Mapper loaded
[   96.341102] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5
[   96.341146] ACPI: Power Button [PWRB]
[   96.341199] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6
[   96.341234] ACPI: Power Button [PWRF]
[   96.376994] ACPI Warning: SystemIO range 0x00000428-0x0000042f conflicts with OpRegion 0x00000429-0x00000429 (\PM2S) (20140424/utaddress-258)
[   96.377000] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   96.377007] ACPI Warning: SystemIO range 0x000004b0-0x000004bf conflicts with OpRegion 0x000004b8-0x000004bb (\GPO2) (20140424/utaddress-258)
[   96.377011] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   96.377013] ACPI Warning: SystemIO range 0x00000480-0x000004af conflicts with OpRegion 0x0000048c-0x0000048f (\GPO_) (20140424/utaddress-258)
[   96.377017] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   96.377019] lpc_ich: Resource conflict(s) found affecting gpio_ich
[   96.408133] i801_smbus 0000:00:1f.3: SMBus using PCI Interrupt
[   96.456022] input: PC Speaker as /devices/platform/pcspkr/input/input7
[   96.581865] EDAC MC: Ver: 3.0.0
[   96.785002] EDAC MC0: Giving out device to module i7core_edac.c controller i7 core #0: DEV 0000:ff:03.0 (POLLED)
[   96.785069] EDAC PCI0: Giving out device to module i7core_edac controller EDAC PCI controller: DEV 0000:ff:03.0 (POLLED)
[   96.785075] EDAC i7core: Driver loaded, 1 memory controller(s) found.
[   97.067193] snd_hda_intel 0000:00:1b.0: irq 47 for MSI/MSI-X
[   97.109792] [drm] Initialized drm 1.1.0 20060810
[   97.112552] sound hdaudioC1D2: autoconfig: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[   97.112556] sound hdaudioC1D2:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   97.112558] sound hdaudioC1D2:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[   97.112561] sound hdaudioC1D2:    mono: mono_out=0x0
[   97.112563] sound hdaudioC1D2:    dig-out=0x11/0x1e
[   97.112565] sound hdaudioC1D2:    inputs:
[   97.112567] sound hdaudioC1D2:      Front Mic=0x19
[   97.112570] sound hdaudioC1D2:      Rear Mic=0x18
[   97.112572] sound hdaudioC1D2:      Line=0x1a
[   97.112574] sound hdaudioC1D2:    dig-in=0x1f
[   97.129199] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card1/hdaudioC1D2/input9
[   97.129416] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input10
[   97.129470] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input11
[   97.129524] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card1/input12
[   97.129577] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card1/input13
[   97.129631] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card1/input14
[   97.129684] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card1/input15
[   97.129752] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card1/input16
[   97.129811] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card1/input17
[   97.458583] iTCO_vendor_support: vendor-support=0
[   97.552692] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[   97.552726] iTCO_wdt: Found a ICH10R TCO device (Version=2, TCOBASE=0x0460)
[   97.552854] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   97.564089] MXM: GUID detected in BIOS
[   97.564435] nouveau  [  DEVICE][0000:02:00.0] BOOT0  : 0x0a0180b1
[   97.564439] nouveau  [  DEVICE][0000:02:00.0] Chipset: G200 (NVA0)
[   97.564442] nouveau  [  DEVICE][0000:02:00.0] Family : NV50
[   97.564501] nouveau  [   VBIOS][0000:02:00.0] checking PRAMIN for image...
[   97.614513] kvm: disabled by bios
[   97.633058] nouveau  [   VBIOS][0000:02:00.0] ... appears to be valid
[   97.633062] nouveau  [   VBIOS][0000:02:00.0] using image from PRAMIN
[   97.633232] nouveau  [   VBIOS][0000:02:00.0] BIT signature found
[   97.633236] nouveau  [   VBIOS][0000:02:00.0] version 62.00.50.00.01
[   97.654250] nouveau 0000:02:00.0: irq 48 for MSI/MSI-X
[   97.654265] nouveau  [     PMC][0000:02:00.0] MSI interrupts enabled
[   97.654303] nouveau  [     PFB][0000:02:00.0] RAM type: GDDR3
[   97.654306] nouveau  [     PFB][0000:02:00.0] RAM size: 1024 MiB
[   97.654308] nouveau  [     PFB][0000:02:00.0]    ZCOMP: 4096 tags
[   97.657560] nouveau  [    VOLT][0000:02:00.0] GPU voltage: 1050000uv
[   97.669639] ppdev: user-space parallel port driver
[   97.817792] adt7475 4-002e: ADT7473 device, revision 1
[   97.827506] nouveau  [  PTHERM][0000:02:00.0] Found an adt7473 at address 0x2e (controlled by lm_sensors, temp offset +8 C)
[   97.827510] nouveau  [     I2C][0000:02:00.0] detected monitoring device: adt7473
[   97.827519] nouveau  [  PTHERM][0000:02:00.0] FAN control: none / external
[   97.827533] nouveau  [  PTHERM][0000:02:00.0] fan management: automatic
[   97.827536] nouveau  [  PTHERM][0000:02:00.0] internal sensor: yes
[   97.827547] nouveau  [     CLK][0000:02:00.0] 03: core 300 MHz shader 600 MHz memory 100 MHz
[   97.827552] nouveau  [     CLK][0000:02:00.0] 07: core 400 MHz shader 800 MHz memory 300 MHz
[   97.827556] nouveau  [     CLK][0000:02:00.0] 0f: core 648 MHz shader 1476 MHz memory 1242 MHz
[   97.827601] nouveau  [     CLK][0000:02:00.0] --: core 399 MHz shader 810 MHz memory 297 MHz
[   97.827822] [TTM] Zone  kernel: Available graphics memory: 418242 kiB
[   97.827825] [TTM] Zone highmem: Available graphics memory: 3106022 kiB
[   97.827826] [TTM] Initializing pool allocator
[   97.827834] [TTM] Initializing DMA pool allocator
[   97.827850] nouveau  [     DRM] VRAM: 1024 MiB
[   97.827852] nouveau  [     DRM] GART: 1048576 MiB
[   97.827857] nouveau  [     DRM] TMDS table version 2.0
[   97.827859] nouveau  [     DRM] DCB version 4.0
[   97.827862] nouveau  [     DRM] DCB outp 00: 04000320 00000028
[   97.827865] nouveau  [     DRM] DCB outp 01: 01000322 00020030
[   97.827868] nouveau  [     DRM] DCB outp 02: 02011310 00000028
[   97.827870] nouveau  [     DRM] DCB outp 03: 02011312 00020030
[   97.827873] nouveau  [     DRM] DCB conn 00: 00001030
[   97.827875] nouveau  [     DRM] DCB conn 01: 00002130
[   97.827878] nouveau  [     DRM] DCB conn 05: 00000360
[   97.867244] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   97.867246] [drm] Driver supports precise vblank timestamp query.
[   97.911575] nouveau  [     DRM] MM: using CRYPT for buffer copies
[   97.999538] nouveau  [     DRM] allocated 1280x1024 fb: 0x50000, bo f17a0000
[   97.999620] fbcon: nouveaufb (fb0) is primary device
[   98.068956] Console: switching to colour frame buffer device 160x64
[   98.070598] nouveau 0000:02:00.0: fb0: nouveaufb frame buffer device
[   98.070599] nouveau 0000:02:00.0: registered panic notifier
[   98.085982] [drm] Initialized nouveau 1.1.2 20120801 for 0000:02:00.0 on minor 0
[  126.947507] ata10.00: exception Emask 0x0 SAct 0x0 SErr 0x800000 action 0x6 frozen
[  126.947524] ata10.00: SError: { LinkSeq }
[  126.947533] ata10.00: failed command: READ DMA
[  126.947545] ata10.00: cmd c8/00:08:78:00:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[  126.947560] ata10.00: status: { DRDY }
[  126.947577] ata10.00: hard resetting link
[  127.267499] ata10.01: hard resetting link
[  127.743717] ata10.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[  127.743732] ata10.01: SATA link down (SStatus 0 SControl 300)
[  127.760765] ata10.00: configured for UDMA/133
[  127.760771] ata10.00: device reported invalid CHS sector 0
[  127.760781] ata10: EH complete
[  157.929438] ata10.00: limiting SATA link speed to 1.5 Gbps
[  157.929450] ata10.00: exception Emask 0x0 SAct 0x0 SErr 0x800000 action 0x6 frozen
[  157.929463] ata10.00: SError: { LinkSeq }
[  157.929471] ata10.00: failed command: READ DMA
[  157.929482] ata10.00: cmd c8/00:08:00:03:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[  157.929497] ata10.00: status: { DRDY }
[  157.929510] ata10.00: hard resetting link
[  160.145671] ata10.01: hard resetting link
[  160.480387] ata10.00: SATA link down (SStatus 1 SControl 310)
[  160.480414] ata10.01: SATA link down (SStatus 0 SControl 300)
[  165.478774] ata10.00: hard resetting link
[  167.695163] ata10.01: hard resetting link
[  168.029839] ata10.00: SATA link down (SStatus 1 SControl 310)
[  168.029866] ata10.01: SATA link down (SStatus 0 SControl 300)
[  173.028170] ata10.00: hard resetting link
[  175.244576] ata10.01: hard resetting link
[  175.579166] ata10.00: SATA link down (SStatus 1 SControl 310)
[  175.579183] ata10.01: SATA link down (SStatus 0 SControl 300)
[  175.579200] ata10.00: disabled
[  175.579209] ata10.00: device reported invalid CHS sector 0
[  175.579213] sd 9:0:0:0: [sdb]
[  175.579215] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[  175.579216] sd 9:0:0:0: [sdb]
[  175.579217] Sense Key : Aborted Command [current] [descriptor]
[  175.579219] Descriptor sense data with sense descriptors (in hex):
[  175.579220]         72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
[  175.579225]         00 00 00 00
[  175.579227] sd 9:0:0:0: [sdb]
[  175.579229] Add. Sense: No additional sense information
[  175.579230] sd 9:0:0:0: [sdb] CDB:
[  175.579231] Read(10): 28 00 00 00 03 00 00 00 08 00
[  175.579235] end_request: I/O error, dev sdb, sector 768
[  175.579243] Buffer I/O error on device sdb, logical block 96
[  175.579252] sd 9:0:0:0: rejecting I/O to offline device
[  175.579258] sd 9:0:0:0: killing request
[  175.579260] ata10: EH complete
[  175.579353] sd 9:0:0:0: rejecting I/O to offline device
[  175.579389] sd 9:0:0:0: rejecting I/O to offline device
[  175.579404] sd 9:0:0:0: rejecting I/O to offline device
[  175.579487] ata10.00: detaching (SCSI 9:0:0:0)
[  175.581037] sd 9:0:0:0: [sdb] Stopping disk
[  175.581060] sd 9:0:0:0: [sdb] START_STOP FAILED
[  175.581064] sd 9:0:0:0: [sdb]
[  175.581067] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[  179.298576] fuse init (API version 7.23)
[  179.558037] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[  179.620935] JFS: nTxBlock = 8192, nTxLock = 65536
[  219.000747] raid6: mmxx1     2368 MB/s
[  219.068738] raid6: mmxx2     3838 MB/s
[  219.136777] raid6: sse1x1    1990 MB/s
[  219.204729] raid6: sse1x2    2340 MB/s
[  219.272750] raid6: sse2x1    3976 MB/s
[  219.340759] raid6: sse2x2    4627 MB/s
[  219.340761] raid6: using algorithm sse2x2 (4627 MB/s)
[  219.340763] raid6: using ssse3x1 recovery algorithm
[  219.411338] xor: measuring software checksum speed
[  219.448771]    pIII_sse  : 10241.000 MB/sec
[  219.488776]    prefetch64-sse:  6643.000 MB/sec
[  219.488778] xor: using function: pIII_sse (10241.000 MB/sec)
[  219.611700] Btrfs loaded
[  220.422392] NILFS version 2 loaded
root@debian:~# [    4.337133] sd 9:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
bash: syntax error near unexpected token `('
root@debian:~# [    4.337156] sd 9:0:0:0: [sdb] Write Protect is off
bash: [: missing `]'
root@debian:~# [    4.337158] sd 9:0:0:0: [sdb] Mode Sense: 00 3a 00 00
root@debian:~# [    4.337169] sd 9:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA[    4.337133] sd 9:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
Sorry I included the entire log. I was unsure what would end up being important. There is an error down toward the bottom.
Thank you in advance for the help!
Cheers
 Post subject: Re: Western Digital WD1002FBYS Recovery Help
PostPosted: February 24th, 2015, 17:31
Could be many things. A bad head, firmware corruption/damage or simply bad sectors.
See what happens wirh MHDD.
Users browsing this forum: No registered users and 82 guests
