Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: Samsung HD154UI 12 clicks and dies
PostPosted: October 17th, 2014, 10:52
Hi to all!
I'd like to be here for good reasons, but unfortunately I'm not. My Samsung HD 154UI, where my family videos are stored just won't start.
Once I power up my computer, the HDD starts to spin up, very fast, and stays that way for about 4 second, then it starts to click, and gives always 12 clicks then it spins down and stays quiet, with no movement.
Can you help me pls?
 Post subject: Re: Samsung HD154UI 12 clicks and dies
PostPosted: October 17th, 2014, 10:56
can you see the terminal ?
i can bet some media damadge or heads ....
ZeBong
" Россия еще раз"
PostPosted: October 17th, 2014, 11:00
No,
The hdd is not recognized by my pc.
PostPosted: October 17th, 2014, 11:47
so is nothing that you can do there.
Send it to a Lab
ZeBong
" Россия еще раз"
PostPosted: October 18th, 2014, 7:26
Hi to all.
I won't give up so soon. I must correct my last statement. I don't have a PC3000 so I don't even know how to reach the terminal to obtain a log.
This happened yesterday, so I'm a totally noob here.
Based on the nfollowing video Can someone risk a diagnose, pls?
https://www.dropbox.com/s/11snlf72n00uok1/00139.MTS?dl=0
PostPosted: October 18th, 2014, 12:43
Quase de certeza danos nos pratos/cabeças...
Almost sure platter damage/heads...
ACELab partner
PostPosted: October 18th, 2014, 12:58
tHE MOST PROBALBLY IS BAD HEADS OR PLATERS DAMAGE.
iN CASE OF PLATTER DAMAGE YOUR DATA PROBALY LOSSEN.
iN CASE OF BAD HEADS YOU CAN NOT DOO NOTHING, IF YOUR DATA IS IMPORTANT CONTACT WITH A PRO.
PostPosted: October 18th, 2014, 17:03
pclab,
Can you recommend a affordable DR professional here in Portugal?
PostPosted: October 18th, 2014, 18:02
How to connect a terminal cable on a Samsung drive:
http://www.alexsoft.org/viewtopic.php?f=116&t=189
PostPosted: October 23rd, 2014, 15:01
I got this case. Completely dead. Platters all FUBAR.
ACELab partner
PostPosted: October 23rd, 2014, 15:25
Yep, total lost cause. Nothing can be done for that one.
PostPosted: October 24th, 2014, 5:39
Of course, situation is not good, but I see only upper surface is damaged. I think, it's need to make diagonstic for other platters, because we keep hope for some result untill all system heads/surfaces are damaged.
PostPosted: October 24th, 2014, 5:47
Yeah, but SA location is scratched too.
If possible, it will take alot of donors/$$$$
ACELab partner
PostPosted: October 24th, 2014, 5:52
We didn't see that :). System surface placed by 0, 1 and 2nd head (bottom part of platters stack). But I agree, case will be very hard (so can take several donors) or impossible.
PostPosted: February 23rd, 2015, 11:02
Hi! Martin,
Do you think you could try to recover something from this drive. I'm only seeking for 50 to 60GB of information from those 1500GB.
PostPosted: February 23rd, 2015, 13:13
To me this is FUBAR.
PostPosted: February 24th, 2015, 5:01
I know the situation looks very bad and I'm really f*cked about it. You guys don't imagine my family drama about this situation.
When it's lost, is lost, but until then the only thing I want is an expert who can take this as a real challenge, not just one more drive.
I would do it, if only I knew how and had the tools, because I would give it all, unfortunately I don't know how.
PostPosted: February 24th, 2015, 5:39
Even if you get to have the MC data from other surface, data is scattered where we don't know the status. (Oh, we all know how Sams work... :mrgreen:)
It requires in any case donors, time, it is always a partial recovery that CAN or CANNOT contain the desired data and it would cost €€€€€ .
So said...
PostPosted: February 24th, 2015, 6:09
Hi, BlackST,
I've already got 4 HD154UI hdd which I believe that can be used as donors, and all I want is 50 to 60Gb of those 1500GB (we are talking about 3 to 5%). A committed expert, partial recovery and a lot of faith is what I need.
PostPosted: February 24th, 2015, 17:22
In my experience of this type of damage, it's usually a similar story for the other surfaces not just the top (visible) surface.
IMHO unrecoverable. :-(
Users browsing this forum: No registered users and 88 guests
