 Post subject: ST2000DM001 BUSY
PostPosted: February 1st, 2015, 19:37
ST2000DM001 w/sticktion and damaged head. Damaged head was on top platter, bent it away from platter and then removed heads.
Close inspection of platter revealed absolutely no damage or marks.
After head swap, put in a dock on a Windows machine. Drive initialized and filesystem came up.
Removed from dock, attached to DeepSpar for imaging but would not become ready. Put back in dock on Windows PC and was not recognized as before.
I have SD tools--on this also would not come ready, stayed busy.
Swapped heads back to donor and donor still is fine.
The only head stack compatibility specs I didn't match perfectly are the FW (CC43 on P, CC44 on D), and site (SU on P, WU on D...but both China).
I AM able to execute terminal commands. Power-on terminal output below. Thanks for any insight!
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
Trans.
Spin Up
RECOV Servo Op=0900 Resp=0005
RECOV Servo Op=0600 Resp=0005
RECOV Servo Op=0055 Resp=0005
RECOV Servo Op=0165 Resp=0005
RECOV Servo Op=0155 Resp=0005
RECOV Servo Op=0255 Resp=0005
MCMainPOR: Start:
User Data Base 00440910
Check MCMT Version:
RECOV Servo Op=0065 Resp=0005
RECOV Servo Op=0165 Resp=0005Factory Init
MCInitialize: Start: Host VBM Size (Bytes): 00000210 Metadata VBM Size (Bytes):
ClearMC: Start Full Starting LBA 0000DC80, Count 00432C90
RECOV Servo Op=0065 Resp=0005[0000000000001B90]v{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}q
LPC Disc Xfr: EXCEPTION: ProcessRWError: Status =00000002
Next Accessed LBA = 00001B90
Retry LBA = 00001B90
Retry Level = 00000000
Starting LBA of RW Request=0000001B90 Length=00086592
ProcessRWError -Write- at LBA 0000001B90 Sense Code=C4090081[000000001D273EAC]v{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}q
FAILED to spare00000903
Device Fault is set!
ClearMC: Completed, Last LBA 0000440910
MCInitialize: MC Cleared
MCInitialize: MCTBufferPtr->Header.MCTStateFlags = 0000000A
MCInitialize: MCTBufferPtr->Header.MCStateFlagsDisc = 00000001
MCInitialize: MCStateFlags = 00000001
Set MCMT Version Current
[MCMTWS] Tail/Head 0000 0000
MCInitialize: Init complete:
MCMainPOR: MCTStateFlags 00000022 MCStateFlags 00000041 Tms 000007D4
RECOV Servo Op=0055 Resp=0005 PASS
SP200: MSPMainPOR Start
Starting LBA of RW Request=0000000000 Length=000001B8
ProcessRWError -Read- at LBA 0000000000 Sense Code=43110081
ERC TO exceeded, orig value in us:FFFFFFFF
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000000
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000000
MSP Reconstruction: EXCEPTION: Read MSP Segment Error
Segment 0000 StartLBA 00000000 ErrorLBA 00000000
Error in MSP Header
Continue MSP Read, PreError Segment Cnt0000
Num Segments 006E[0000000000000000]v{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}q
ProcessRWError -Write- at LBA 0000000000 Sense Code=C4090081[000000001D273EAC]v{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}qv{00000008}q
FAILED to spare00004903
MSP ERROR: Init ScratchPad Disc
MSP MainPOR: 00003000 Tms 000007D4 00000A10 00001332
MSP ERROR: ScratchPad disabled
No HOST FIS-ReadyStatusFlags 0002A181
 Post subject: ST2000DM001 BUSY after a head swap
PostPosted: February 2nd, 2015, 22:09
That's SA problems.
As for why the drive stopped being identified, maybe the situation got worse because write adaptives didn't match. In that case heads read OK, but write junk. And single power on would be enough to kill part of an SA.
 Post subject: Re: ST2000DM001 BUSY
PostPosted: March 22nd, 2015, 9:48
I wish I had helpful information for you. Shortly after the post, my customer informed me that they did not want to proceed with the recovery and that they had found the data backed up somewhere else.
Good luck!
 Post subject: Data recovery in Azerbaijan, Baku
PostPosted: March 23rd, 2015, 4:20
zeydullak wrote:
Could you please let me know if you have fixed your drive? I have the same problem as you indicated above. I would be very glad if you share your solution with me.
Please note that OP isn't a home user.
The solution you're after is not DIY and targeted to recovering the data, not repairing the drive.
If you're looking to recover the data, we'll be glad to help. It isn't uncommon for us to work with drives from ex-USSR states, including Azerbaijan.
Users browsing this forum: Google [Bot] and 33 guests
