 Post subject: Looking for loader (WD5000AAKB-00YSA0)
PostPosted: March 26th, 2015, 7:33
Hello Everyone!
I'm looking for WD5000AAKB-00YSA0 firmware. Microcode revision is 580076
Tornado 2 PPMR PATA.
The most important modules are:
01,11, and 12.
Please share if you have!
Thank you!
 Post subject: Re: Looking for loader (WD5000AAKB-00YSA0)
PostPosted: March 26th, 2015, 9:37
Did you look in forum files?
Next time please do.
http://files.hddguru.com/download/PC-30 ... nado%202R/
www.datarecoveryne.com
PostPosted: March 26th, 2015, 9:43
Thank you harddrivespecialist!
I'm looked the forum files, thank you, mostly the first i do (thanks for uploaders).
This is an AAKB PATA drive.
I tried the overlay with same microcode revision number of a WD3200AAJS SATA drive, but it's not compatible :-(
PostPosted: March 26th, 2015, 10:35
There is many other resources you might want to try.
PostPosted: March 26th, 2015, 13:50
:roll:
PostPosted: March 26th, 2015, 13:57
You have asked for specific firmware and was directed to it.
I simply don't know what else you need or if you have applied it correctly.
PostPosted: March 27th, 2015, 4:14
Thank you again.
With WD3200AAJS-00VWA0-12.01B02-00580076 overlay SeDiv says: "VSCE_OFF_TOO_LARGE"
With WD3200AAJB-00WGA0-00.02C01-00580076 overlay SeDiv says: "OVM_ERR_NOT_COMPATIBLE"
Have you another solution?
Now i know, the FW revision is 12.01C02
PostPosted: March 27th, 2015, 4:34
With WD5000AAJS-32YFA0-12.01C02-00580076 overlay SeDiv says: "VSCE_OFF_TOO_LARGE"
Users browsing this forum: No registered users and 46 guests
