 Post subject: WD1600BEVS unstuck spindle. Now clicking.
PostPosted: April 10th, 2015, 7:11
I would appreciate your opinion about this case.
WD1600BEVS (160 Gb, 2,5'' hard drive)
- Had the spindle (slightly) jammed over the platters, with the typical bitonal siren
- Spindle could easily be unstuck and moved to the comb.
- Motor now spins
- Spindle makes 3 fast and sharp "click of death",
repeated about 5 times, then drive stop spinning
- In WDR Demo, status bullets lightens red or green (excepted the BSY one).
(I can tell which bullets are green and which ones are red if required.)
- The error register bullets lightens all to red.
I assume damaged head(s) is the most likely, but maybe could the problem come from something else (preamp, ...).
Thanks.
 Post subject: Re: WD1600BEVS unstuck spindle. Now clicking.
PostPosted: April 10th, 2015, 7:37
yes, bad heads for sure.
RAID/Server Recovery
PostPosted: April 10th, 2015, 8:19
Thanks.
Users browsing this forum: No registered users and 34 guests
