 Post subject: DRQ Eror 0x0816 WD 320GB
PostPosted: April 9th, 2015, 8:43
Exclamation DRQ Eror 0x0816
Hi Guys, so first at all my name is David my lenguage is Spanish, so sorry for my grammar errors and stuff like that.
I got this problem
Can't write firmware to drive!
DRQ Error: 0x0816
I recently bought a Wester Digital 320 GB for my 360 is WD320BEVT 24A23T0 and the first thing that i do was flash the disk. Everything was okay, but i notice that the disk was so slow, TitanFall takes a lot of time to start the textures on, so i decided to delete all the disk so i doit with GParted.
When i start the hddhackr i restore the firmware and it says `okay` alright i reboot and the disk still saying ST so i decided to flash again and everything was okay, so i reboot again, so i decided to use another BIN, and then the errors comes out, and i can't flash anything.
I moved to GpartD again and Gpartd don't detect the HDD, and de HDDHACKR don't shows anything about the HDD now, i can't do anything,
EDIT: The disk in HDDHACKR comes out but don't have name, and when i use GParted the disk turn on and 2 sounds comes out, but when i select Gparted in the menu of the boot the disk turn off the fan is off so.. I use Sata Connection
:cry: :cry:
Thanks for see, regards.
David.​
 Post subject: Re: DRQ Eror 0x0816 WD 320GB
PostPosted: April 9th, 2015, 19:49
That's your problem. You now have an incompatible module 02 in the SA, or perhaps an incompatible 0D in ROM. Some drives have a backup copy of both modules in the SA (eg module 802F or 802E), but you would need to be able to access the SA in order to retrieve these copies.
PostPosted: April 9th, 2015, 21:59
agree with fzabkar that you have corrupt mod 0x02
and your HDD become ROM Model
so you need special tools to work with HDD SA
and re-write mod 0x02 backup if you have backup in Sa like mod
802E or 8032
there are steps to do that
and it's better if you are not technician to give your HDD to specialist in HDD Repair to do that for you
and for Slow problem you say
you can read this article here will help you
http://www.hpwlab.com/hdd/thread-101-1-1.html
PostPosted: April 13th, 2015, 18:13
Spildit,
http://www.hddoracle.com/viewtopic.php?f=86&t=141
I will try this. But i dont know, you can help me please?
Users browsing this forum: Bing [Bot] and 147 guests
