 Post subject: Need Resources for WD3200AAJS-07M0A0 with ROM: 05.FUE
PostPosted: April 22nd, 2015, 9:55
Hello Guys,
Can anyone provide me resources (SA Modules, Tracks, ROM, ROM Modules) for this drive. I checked the usual places but cannot locate them unfortunately.
Patient:
WD3200AAJS-07M0A0
ROM: 05.FUE
Head map: 0 1
DOM: 28 NOV 2010
DCM: HBRNHT2AHN
Repeat after me, NAS is not a backup, NAS is not a Backup
 Post subject: Re: Need Resources for WD3200AAJS-07M0A0 with ROM: 05.FUE
PostPosted: April 22nd, 2015, 10:26
Sorry, don't have that one :-(
PostPosted: April 22nd, 2015, 12:02
Its such a rare hard drive, I cannot find donor match neither resources for it.. :shock:
PostPosted: April 22nd, 2015, 12:22
are you sure about rom version ? i have 000500FA , 000500F9 , 000500FM in 9 resources in my DB
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: April 22nd, 2015, 12:35
guys thanks
>ROM Modules:
>ROM version............................. : 05.FUE
>ROM F/W version......................... : 000500FU
>Overlay F/W version..................... : 05.FUE
>Servo F/W version....................... : 04.0N
Can't I use close Version?
Closest one which I found is this:
WDC WD3200AAJS-07M0A0_01.03E01_WD-WCAV2A196491_000500FA_1311_170
MODEL : WD3200AAJS-07M0A0
SERIAL : WCAV2A196491
FW VER : 01.03E01
MCODE : 000500FA
SRV VER:
SPT : 1311
https://www.mediafire.com/?v6im9127wpv2o7k
PostPosted: April 23rd, 2015, 3:15
I send only ROM and ATA OVL
Mikippp
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 1
>Cyl Count............................... : 170
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 192 Kb
>ROM generation.......................... : 05.FUE
>Link table version...................... : 04.0N.
>Consolidated ROM version................ : 000500FU
>ROM Modules:
>Flash ROM dir reading................... : Ok
>SA regions address...................... : by default
>SA Translator loading................... : Ok
!SA defects assigned..................... : 1
>Heads configuration..................... : by map
>Heads number in use..................... : 1
>Switched off heads...................... : No
>Heads map............................... : 0
>ROM Firmware version.................... : 000500FU
File comment: 01.rpm 11.rpm 13.rpm ROM.bin
11.zip [365.72 KiB]
Downloaded 381 times
PostPosted: April 26th, 2015, 0:29
Thank you. Will try and let you know.
Users browsing this forum: No registered users and 207 guests
