 Post subject: Seagate ST2000DM001 PCB reset
PostPosted: May 13th, 2015, 8:34
Hi, I have a Seagate ST2000DM001 (PN: 1CH164-510, FW: CC27) not visible in BIOS / system, and I need to perform some fixes on DFL-FRP device.
Actually, I need to do BSY reset by connecting pins on the PCB, so I can write ROM and modules. Yesterday I did reset SMART, fixed translator, saved ROM and modules and then get partition and save some data. After few minutes, it stopped responding just like before. Does someone has a PCB PIN RESET image to share here? Or maybe pin layout of chip LST B69002VO, so I can find it by myself and post it here? Thanks
 Post subject: Re: Seagate ST2000DM001 PCB reset
PostPosted: May 13th, 2015, 9:27
First - show terminal output and tell about type of error in ATA registers
PostPosted: May 13th, 2015, 11:16
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
TCC:0025
(P) SATA Reset
Disk responds to commands via COM port.
PostPosted: May 13th, 2015, 15:27
Well,
You only need to do this only if its responding to terminal .
PostPosted: May 14th, 2015, 6:20
Alex381 wrote:
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
TCC:0025
(P) SATA Reset
Send V4 on T-level and show reply
PostPosted: May 14th, 2015, 7:48
^z
ASCII Diag mode
F3 T>V4
V4
Reassigned Sectors List Enabled
Entries: 0034, Alts: 0001, Removed: 4013,
Pending: 0010 Host Pending: 0080 Idx LBA PBA LLLCHS of LBA Wdg PLPCHS of PBA SFI Hours Msecs Status BBM Mask
0000 000000000141 00001D2B0035 000000.0.0170 122 05966B.2.0058 060473 00000 026D52 00002210 11111111
0001 000000001ED1 000000001F00 000010.0.0000 008 000010.0.0000 007C39 00000 007DB2 00000021 00000000
0002 000000001ED7 000000001F06 000010.0.0006 00C 000010.0.0006 00C599 00000 01EFF0 00000021 00000000
0003 000000001EDD 000000001F0C 000010.0.000C 011 000010.0.000C 010F48 00000 01E585 00000021 00000000
0004 000000001EE3 000000001F12 000010.0.0012 016 000010.0.0012 0158F7 00000 01DB12 00000021 00000000
0005 000000001EE9 000000001F18 000010.0.0018 01A 000010.0.0018 01A257 00000 01D096 00000021 00000000
0006 000000001EEF 000000001F1E 000010.0.001E 01F 000010.0.001E 01EC06 00000 01C62B 00000021 00000000
0007 000000001EF5 000000001F24 000010.0.0024 024 000010.0.0024 0235B5 00000 01BBC0 00000021 00000000
0008 000000001EFB 000000001F2A 000010.0.002A 029 000010.0.002A 027F64 00000 01B144 00000021 00000000
0009 000000001F01 000000001F30 000010.0.0030 02D 000010.0.0030 02C8C4 00000 01A6C9 00000021 00000000
000A 000000001F07 000000001F36 000010.0.0036 032 000010.0.0036 031273 00000 019C55 00000021 00000000
000B 000000001F0D 000000001F3C 000010.0.003C 037 000010.0.003C 035C22 00000 0191EA 00000021 00000000
000C 000000001F13 000000001F42 000010.0.0042 03C 000010.0.0042 03A5D1 00000 01877F 00000021 00000000
000D 000000001F19 000000001F48 000010.0.0048 040 000010.0.0048 03EF31 00000 017D1C 00000021 00000000
000E 000000001F1F 000000001F4E 000010.0.004E 045 000010.0.004E 0438E0 00000 017298 00000021 00000000
000F 000000001F25 000000001F54 000010.0.0054 04A 000010.0.0054 048290 00000 01682D 00000021 00000000
0010 000000001F2B 000000001F5A 000010.0.005A 04F 000010.0.005A 04CC3F 00000 014F81 00000021 00000000
0011 000000001F31 000000001F60 000010.0.0060 053 000010.0.0060 05159F 00000 01451E 00000021 00000000
0012 000000001F37 000000001F66 000010.0.0066 058 000010.0.0066 055F4E 00000 013AB3 00000021 00000000
0013 000000001F3D 000000001F6C 000010.0.006C 05D 000010.0.006C 05A8FD 00000 013051 00000021 00000000
0014 000000001F43 000000001F72 000010.0.0072 062 000010.0.0072 05F2AC 00000 0125D5 00000021 00000000
0015 000000001F49 000000001F78 000010.0.0078 066 000010.0.0078 063C0C 00000 011B6A 00000021 00000000
0016 000000001F4F 000000001F7E 000010.0.007E 06B 000010.0.007E 0685BB 00000 011107 00000021 00000000
0017 000000001F55 000000001F84 000010.0.0084 070 000010.0.0084 06CF6A 00000 01068B 00000021 00000000
0018 000000001F5B 000000001F8A 000010.0.008A 075 000010.0.008A 071919 00000 00FC20 00000021 00000000
0019 000000001F61 000000001F90 000010.0.0090 079 000010.0.0090 076265 00000 00F1BE 00000021 00000000
001A 000000001F67 000000001F96 000010.0.0096 07E 000010.0.0096 07AC14 00000 00E752 00000021 00000000
001B 000000001F6D 000000001F9C 000010.0.009C 083 000010.0.009C 07F5C3 00000 00DCF0 00000021 00000000
001C 000000001F73 000000001FA2 000010.0.00A2 088 000010.0.00A2 083F72 00000 00D274 00000021 00000000
001D 000000001F79 000000001FA8 000010.0.00A8 08C 000010.0.00A8 0888D2 00000 00C809 00000021 00000000
001E 000000001F7F 000000001FAE 000010.0.00AE 091 000010.0.00AE 08D281 00000 00BDA6 00000021 00000000
001F 000000001F85 000000001FB4 000010.0.00B4 096 000010.0.00B4 091C30 00000 00B333 00000021 00000000
0020 000000001F8B 000000001FBA 000010.0.00BA 09A 000010.0.00BA 096590 00000 00A8C8 00000021 00000000
0021 000000001F91 000000001FC0 000010.0.00C0 09F 000010.0.00C0 09AF3F 00000 009E65 00000021 00000000
0022 000000001F97 000000001FC6 000010.0.00C6 0A4 000010.0.00C6 09F8EE 00000 009402 00000021 00000000
0023 000000001F9D 000000001FCC 000010.0.00CC 0A9 000010.0.00CC 0A429D 00000 0088D7 00000021 00000000
0024 0000000884C1 00000008891D 000134.0.0001 0E0 000134.0.0001 0DA14F 00000 08BD17 00000001 00000000
0025 0000000884C2 00000008891E 000134.0.0002 0E1 000134.0.0002 0DADA4 00000 08C820 00000001 00000000
0026 0000000884C3 00000008891F 000134.0.0003 0E2 000134.0.0003 0DB9F9 00000 08DC3F 00000001 00000000
0027 0000000884C4 000000088920 000134.0.0004 0E3 000134.0.0004 0DC64E 00000 08EBC6 00000001 00000000
0028 0000000884C5 000000088921 000134.0.0005 0E3 000134.0.0005 0DD254 00000 08F7D2 00000001 00000000
0029 0000000884C6 000000088922 000134.0.0006 0E4 000134.0.0006 0DDEA9 00000 0903CE 00000001 00000000
002A 0000000884C7 000000088923 000134.0.0007 0E5 000134.0.0007 0DEAFE 00000 090FC1 00000001 00000000
002B 0000000884C8 000000088924 000134.0.0008 0E6 000134.0.0008 0DF753 00000 091BC4 00000001 00000000
002C 0000000884C9 000000088925 000134.0.0009 0E7 000134.0.0009 0E03A8 00000 0927B7 00000001 00000000
002D 0000000884CA 000000088926 000134.0.000A 0E7 000134.0.000A 0E0FAE 00000 0933B2 00000001 00000000
002E 0000000884CB 000000088927 000134.0.000B 0E8 000134.0.000B 0E1C03 00000 094238 00000001 00000000
002F 0000000884CC 000000088928 000134.0.000C 0E9 000134.0.000C 0E2858 00000 094E2B 00000001 00000000
0030 0000000884CD 000000088929 000134.0.000D 0EA 000134.0.000D 0E34AD 00000 095A26 00000001 00000000
0031 0000000884CE 00000008892A 000134.0.000E 0EB 000134.0.000E 0E4102 00000 09BAF6 00000001 00000000
0032 0000000884CF 00000008892B 000134.0.000F 0EB 000134.0.000F 0E4D08 00000 0A20A8 00000001 00000000
0033 0000000884D0 00000008892C 000134.0.0010 0EC 000134.0.0010 0E595D 00000 0BFC9B 00000001 00000000
F3 T>
Disk spins up, try to initialize few times and stops. I can not see disk size and other parameters. Any idea?
PostPosted: May 14th, 2015, 13:39
Push ctrl+x and show output.
Is it possible to take a look remotely?
PostPosted: May 14th, 2015, 13:55
F3 T>^x
ATA  15 Cmds
Ts(ms)     dT(ms)   Op Cnt  LBA
         0 99999999 00 0000 000000000000
         0        0 00 0000 000000000000
RW  32 Cmds
Ts(ms)     dT(ms)   xT(ms)  Type Option Mode  St EC       Info
     95524 99999999      287 02  011102 000480 2 43110081 XFR RD USR PBA B 000000001F12 L 000000000001 BO 24002234 BES 022DE80.022E29F.022DE80
     95811      287     2279 01  011101 000000 2 C4090082 XFR_ALT RD USR LBA B 000000001EE3 L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
     95812        1     2278 02  011102 000480 2 C4090082 XFR RD USR PBA B 000000001F12 L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
     98090     2278        0 18  000088 000000 1 00000080 MRK_PND MRK B 000000001EE3 L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80 Valid 1
     98091        1        0 02  011101 000000 2 40000087 XFR RD USR LBA B 000000001EDD L 000000000006 BO 24000E74 VL 249C.0690
     98091        0      287 01  011101 000000 2 C4090082 XFR_ALT RD USR LBA B 000000001EDD L 000000000001 BO 24002234 BES 022DE80.022E29F.022DE80
     98091        0      287 02  011102 000480 2 C4090082 XFR RD USR PBA B 000000001F0C L 000000000001 BO 24002234 BES 022DE80.022E29F.022DE80
     98378      287     2246 01  011101 000000 2 C4090082 XFR_ALT RD USR LBA B 000000001EDD L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
     98378        0     2246 02  011102 000480 2 C4090082 XFR RD USR PBA B 000000001F0C L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
    100624     2246        0 18  000088 000000 1 00000080 MRK_PND MRK B 000000001EDD L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80 Valid 1
    100624        0        1 02  011101 000000 2 40000087 XFR RD USR LBA B 000000001ED7 L 000000000006 BO 24000E74 VL 249C.0690
    100625        1      287 01  011101 000000 2 43110081 XFR_ALT RD USR LBA B 000000001ED7 L 000000000001 BO 24002234 BES 022DE80.022E29F.022DE80
    100625        0      287 02  011102 000480 2 43110081 XFR RD USR PBA B 000000001F06 L 000000000001 BO 24002234 BES 022DE80.022E29F.022DE80
    100912      287     2254 01  011101 000000 2 C4090082 XFR_ALT RD USR LBA B 000000001ED7 L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
    100912        0     2254 02  011102 000480 2 C4090082 XFR RD USR PBA B 000000001F06 L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
    103166     2254        0 18  000088 000000 1 00000080 MRK_PND MRK B 000000001ED7 L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80 Valid 1
    103167        1       30 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000003C298 L 000000000308 BO 000000 BES 03B3600.03BF7FF.03B3600
    103197       30       25 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000009EDDA L 000000000308 BO 000000 BES 03B3600.03BF7FF.03B3600
    103223       26        4 02  028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
    103227        4        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 000000097E38 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
    103238       11       24 02  011101 000000 2 40000087 XFR RD USR LBA B 000000000000 L 0000000001C0 BO 24000E74 VL 2C9C.0E00
    103262       24       25 01  011101 000000 1 00000080 XFR_ALT RD USR LBA B 000000000141 L 000000000001 BO 24003674 VL 36A4.0E00
    103263        1       24 02  011102 000480 1 00000080 XFR RD USR PBA B 00001D2B0035 L 000000000001 BO 24003674 VL 36A4.0E00
    103287       24       19 02  011101 000000 1 00000080 XFR RD USR LBA B 000000000142 L 00000000007E BO 24003674 VL 36AC.0E00
    103413      126      657 02  028101 000000 2 40000087 XFR WR USR LBA B 000000000000 L 0000000001C0 BO 24000E74 VL 3C9C.0E00
    104071      658       24 01  028101 000000 1 00000080 XFR_ALT WR USR LBA B 000000000141 L 000000000001 BO 24003674 VL 46A4.0E00
    104071        0       24 02  028102 000480 1 00000080 XFR WR USR PBA B 00001D2B0035 L 000000000001 BO 24003674 VL 46A4.0E00
    104095       24       61 02  028101 000000 0 C4090081 XFR WR USR LBA B 000000000142 L 00000000007E BO 24003674 VL 46AC.0E00
    104157       62       19 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000000373D5 L 000000000001 BO 000000 BES 00650DD.006511C.00650DD
    104176       19        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000000373D5 L 000000000001 BO 000000 BES 00650DD.006511C.00650DD
    104185        9        9 02  028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
    104194        9        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 000000097E38 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
You can take a look, sending you ID&pass.
Users browsing this forum: No registered users and 140 guests
