 Post subject: Seagate [0x000042F9]ZZZZMMMMMMMMMMMMMMMZZ message
PostPosted: May 11th, 2015, 21:57
Hi
I have the following problem:
Model:
ST1000DM003
Terminal message:
Boot 0x40M
Spin Up
TCC-0018[0x000042F9][0x000042F9]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWWWMMMMMM
Detailed description:
We received the PCB with broken seals (someone else tried to change PCB before)
It´s impossible to access terminal (CRTL+Z)
We already did ROM soldering to a DONOR PCB and the result is the same
If I use PATIENT PCB on a donor drive (fully working), same behaviour (same terminal message)
This makes me believe that the ROM is corrupted
Does anyone know if it´s possible to recover data from this case?
Thanks,
-BR-
 Post subject: Re: Seagate [0x000042F9]ZZZZMMMMMMMMMMMMMMMZZ message
PostPosted: May 11th, 2015, 23:04
Read/Write Retry Characters
'Z': TRACK_OFFSET_RETRY_CHAR
'M': MR_BIAS_RETRY_CHAR - MR bias tweak retry character
'd': CLEARANCE_RETRY_CHAR - Clearance value adjusted during recovery
'W': SLIDING_WINDOW_RETRY_CHAR
Problems with the head or surface. If ROM native.
S/N in ROM coincides with the label?
PostPosted: May 12th, 2015, 2:08
zZZzzzzZZZZzzzZzz
PostPosted: May 12th, 2015, 15:18
@Tomset
Yes, the ROM SN is the same as the HDA label one.
Thanks for sharing the letters information.
@parkorn16
Would you share how you fixed you case?
Sent you a PM.
-BR-
PostPosted: May 14th, 2015, 10:48
In my opinion from what you've said, that defenitely is a bad PCB, but not necessarily a bad ROM. Try a donor PCB first, and check the terminal - you may just get FAIL servo messages if trying with nonnative ROM, which is, well, "good".
PostPosted: May 14th, 2015, 13:31
Problem in pair Heads - Preamplifier
Users browsing this forum: No registered users and 103 guests
