 Post subject: ST9146802SS SAS 2,5" - Possible to rebuild translator?
PostPosted: June 17th, 2015, 5:35
Hello friends
here you a good question
The drive in subject
is reported as with a failure, it sounds good but the SAS card BIOS at boot reports it as with an error (in SAS card BIOS the model name is shown correctly)
But next e.g. in the Linux disk utility only the name is reported but no other details, expecially the capacity
I was wondering if it could be matter of translator.
As others ST drives, it has its TTL serial port connection port... (see attached picture) do you know if any terminal action is possible through that port?
Thank you
File comment: ST9146802SS board connectors
 Post subject: Re: ST9146802SS SAS 2,5" - Possible to rebuild translator?
PostPosted: June 18th, 2015, 5:15
Is posible, but especial and expensive tolls needed.
The best in this case is call to a local pro. If you want i know some goods pro peole in Itally
PostPosted: June 18th, 2015, 5:25
Thank you, but your one it is not a reply for the question :-)
The question is:
Did any of you have done any operation through terminal on those SAS drives?
We have PC3K but (and we have been right) we have never invested on the SCSI one, for the simple fact that SAS storages are usually monotired pretty fine by sysadmins and so it never happen in many years to receive storages with a double disk failure.
In this case, as well. But for some verifications it would be useful to restore the failed drive.
So, again, buying the SCSI one would have been a total lossy ROI.
PostPosted: June 18th, 2015, 7:37
What error sense does it present?
Not saying to do so, but have you already examined the internal condition? If so, what did you see?
PostPosted: June 18th, 2015, 15:17
There is no ASCII terminal.
 Post subject: SAS hard drive - Possible to rebuild translator?
PostPosted: June 18th, 2015, 19:40
Corsari wrote:
The drive in subject is reported as with a failure
If this drive shows zero capacity, then it's a translator failure.
According to the description, I'd give 8 or even 9 out of 10 to that assumption.
Serial port on server hard drive families does not support ASCII terminal, only ESLIP one (binary). And its functionality is different.
Users browsing this forum: No registered users and 92 guests
