 Post subject: ST31000524AS JC4A 7200.12
PostPosted: May 19th, 2015, 8:12
This drive is detected by BIOS, but very slow. Once computer boots, DMDE/Find and Mount will see it, and I was able to start imaging it.
Imaging was VERY slow, started last night at 11pm and stopped it today at 6pm for a total of 16GB of the image copied.. would have taken 62 days at that rate.
Terminal shows only:
Rst 0x20M
RW: Disc Ctlr Initialization Completed.
SATA Reset
Doesn't make any nasty sounds.
This drive was replaced by Dell under warranty. Owner needs to send it back probably tomorrow, or if I can do anything, maybe stall a smidge, but they aren't going to do any pro DR. I only wanted to take a look as it isn't the standard bell ringing for lunch sound, and it belongs to a colleague in Edu sector.
Can anyone suggest anything I might be able to try?
Thanks in advance
 Post subject: Re: ST31000524AS JC4A 7200.12
PostPosted: May 19th, 2015, 8:26
speed is same in reverse imaging as well ?
RAID/Server Recovery
PostPosted: May 19th, 2015, 8:41
cant get into terminal to do so. Remember Spildit, Im not a HDD Guy, so what you said is like telling someone when the car doesn't start to go check the engine :) ;)
I can work out how to stop reallocation from whats already posted on the forums I reckon.
edit: you wouldn't believe it, after posting I thought I would check terminal again and now get F3 prompt. doh!
PostPosted: May 19th, 2015, 8:49
Background processes. Need to edit SA.
PostPosted: May 19th, 2015, 9:09
ASCII Diag mode
F3 T>.
Current R/W User LBA 000000000000 LLL CHS 000000.0.0000 PLP CHS 000000.0.0000
R/W Status 1 R/W Error 00000080 Ready
PostPosted: May 19th, 2015, 9:22
ok, so just let them return it to dell them?
PostPosted: May 19th, 2015, 10:16
I disabled realloc and it started to image quickly, first 2 partitions were fine, but at LBA 23,804,065 got CRC error, and would not copy any data. Of course this is basically where the user 988GB Partition is. I guess that's that.
Thanks guys, pity I couldn't have given it to a pro, may not have been a hard one.
PostPosted: May 19th, 2015, 10:33
what about reverse imaging as chinopk mentioned above ?
PostPosted: May 19th, 2015, 19:47
Reverse imaging just had CRC error straight away.
From memory there is a 40 odd MB partition, a 12GB and the 988GB. seems the first 2 image ok, though I don't know why the CRC errors would be divided by partition.
PostPosted: May 19th, 2015, 20:05
988gb encrypted partition or protected
PostPosted: May 19th, 2015, 21:46
Interesting thought. I know the users wouldn't know anything about encryption, and this was out of a regular desktop. I am sure these are regular users running windows. I am not sure what encryption could be here, no evidence of it.
Users browsing this forum: Majestic-12 [Bot] and 151 guests
