 Post subject: Seagate Momentus 5400.6 - Spins but not recognized in BIOS?
PostPosted: June 12th, 2015, 7:25
Hi all,
A colleague came in with a portable hard disk that had stopped working. Naturally I opened it up and took the disk out, a Seagate Momentus 5400.6 250GB. I plugged it into a PC via SATA, and although it spins up nicely with no nasty noises (can't hear it seeking), it's not recognized in the BIOS. I'm thinking the likely culprit is the PCB, any thoughts?
Thanks,
Chris.
 Post subject: Re: Seagate Momentus 5400.6 - Spins but not recognized in BI
PostPosted: June 12th, 2015, 7:57
with the symptoms it is very unlikely a pcb problem.
could be FW, Bad Sector or weak heads.
terminal (TTL adapter) output will help further diagnose.
Data Recovery Pakistan
PostPosted: June 12th, 2015, 8:06
as MindMergepk, said probably FW, Heads or bad media, but TTL log needed for a better diagnostic.
Users browsing this forum: No registered users and 81 guests
