 Post subject: External HDD after a fall.
PostPosted: June 17th, 2015, 10:19
Hi! I'm new on this forum and I want to apologize for my bad english.
My external HDD fell from desk and now it does this:
https://www.youtube.com/watch?v=M8m7e_a7xRk
Is there a chance for fixing it with home methods?
 Post subject: Re: External HDD after a fall.
PostPosted: June 17th, 2015, 12:01
If the drive was not killed by beeing dropped from the table, you killed it by opening the drive. Sorry to say but a DR recovery now will be very expensive if possible at all. Never ever open a drive outside a clean room if you need your data.
And no, a DIY on dropped drives is not possible because heads are damaged and you will nearly always have media damage. For a recovery from physical damaged drives you need the right tools and there is clean room work involved.
030 Datenrettung Berlin GmbH (Germany)
HDD, SSD, NAS, RAID Datenrettung - 030-datenrettung.de
PostPosted: June 18th, 2015, 5:13
Bad news to you!!
this is the worst situation for your data, Fallen and opened in bad condition.
You must speak with local pro, but little posibilities
PostPosted: June 18th, 2015, 7:25
Thank you for your answer. I have opened it becouse I thought that head is stuck. I did such things before and drives worked.
Besides, data aren't that important to spend money to recover them. DIY was the only way, so I tried :)
Users browsing this forum: No registered users and 248 guests
