 Post subject: Samsung HS25YJZ - need PATA PCB
PostPosted: June 16th, 2015, 5:45
Samsung HS25YJZ 1.8" drive
I looking for compatible PATA PCB (with same MCU). Friends, can you check your resources?
 Post subject: Re: Samsung HS25YJZ - need PATA PCB
PostPosted: June 16th, 2015, 9:15
I don't think there is an equivalent ATA based PCB model for this family, only ZIF based.
PostPosted: June 16th, 2015, 10:07
ZIF will be ok too.
PostPosted: June 16th, 2015, 12:49
MichaƂ I have only seen 88i8822D on these :(
File comment: Sammy_pcb
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: June 16th, 2015, 13:13
I guess that your 88i8038 includes USB IF
I have used a HS12UHE ZIF PCB with 88i22D on a HS120JY USB drive ( do not remember MCU on the USB version )
But it worked fine
PostPosted: June 16th, 2015, 15:16
Have a hard time getting a sense of what the compatible ZIF PCB would be for the USB version with no physical drives available and very limited resources online.
There are some similar drives that are MicroSATA interface, so maybe something to explore.
What is the green etch PCB code just out of curiosity?
Edit: whoops, forgot about the zoom feature on pic..
PostPosted: June 16th, 2015, 15:37
Here is the other side of PCB. I think other version of MCU will not work. But maybe someone have different experience?
PCB has independent USB controller. I can't find datasheet for it (JM20335).
PostPosted: June 16th, 2015, 15:45
http://www.hardmaster.info/eng/articles/04-09-2012.html
PostPosted: June 16th, 2015, 16:12
Thanks jermy! It would be very useful if I can't find compatible PATA PCB with nonUSB interface.
PostPosted: June 16th, 2015, 18:16
you afraid of soldering 28 wires ? ;)
in your line of work (flash) it's a regular daily basis doesn't it ?
PostPosted: June 16th, 2015, 18:53
No :) In fact I solder it already :D Now working on problem.
And yes, in monolith it is regular daily job ;)
PostPosted: June 16th, 2015, 18:55
i wish you 100% recover
PostPosted: June 16th, 2015, 19:34
Did you do the simple stuff first? For example, there is a PolyZen and 3 switchmode regulators. Should take less than 5 minutes for a competent tech to check those.
PostPosted: June 17th, 2015, 2:31
@fzabkar: it is not electronic problem. This drive has problem with SA and maybe with degradation of surface. We can't work with SA via USB.
Users browsing this forum: Google [Bot] and 288 guests
