 Post subject: ST500DM002 P\N 1BD142-302
PostPosted: June 15th, 2015, 8:57
I have ST500DM002 hdd.....hdd spins normally, no clicking noise....after shorting pin points it shows the following error in terminal.....after that it shows 3.86 GB......
FAIL Servo Op=0055 Resp=0007
ResponseFrame 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000A
RECOV Servo Op=0155 Resp=0005x[0x0000B319][0x0000B319]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZ[0x0000B31A][0x0000B31A]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWYWYWWMMMMMM
FAIL Servo Op=0155 Resp=0007
RECOV Servo Op=0055 Resp=0005x[0x00030FCD][0x00030FCD]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWYWYWWMMMMMM
so please reply how to access the hard disk data......
Any help appreciated.....
 Post subject: Re: ST500DM002 P\N 1BD142-302
PostPosted: June 15th, 2015, 12:09
What was wrong with the drive before you started to "short pin points" ?
I gues that "shorting pin points" = "Read channel"
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: June 15th, 2015, 12:27
Heads Issue, no DIY
PostPosted: June 15th, 2015, 12:51
Agree with head issue, if not "something" is shorted during this terminal output :)
PostPosted: June 15th, 2015, 14:06
"FAIL Servo" = Bad Heads or media damage
Or possibly both with Seagate.
PostPosted: June 16th, 2015, 1:01
This is my log for ST500DM002 with 704 Rev: C PCB
Problem:
HDD Not Detected
No Strange Sound
When connected with terminal (STCom Tool 2013-5-10 English) Nothing Display in Log Window.
When Shorting READ CHANNELs I got Terminal Log as below
Boot 0x10M
Spin Up[0x00000000][0x00000000]ZZZZMMMMMMMMM[0x00000001][0x00000001]ZZZZMMMMMMMMMMMMMMM[0x00000002][0x0000000
ZZZZMMMMMMMMMMMMMMMZZZZZZZZZ[0x00000003][0x00000003]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMM
MMMMMMMMMMMMMMMMMMMMMMMMMMMMdddd[0x0000B67C][0x0000BA10]
Trans.
Rst 0x10M
MC Internal LPC Process
Spin Up
PASS
Starting LBA of RW Request=001320E2 Length=0000014C
ProcessRWError -Read- at LBA 001320E2 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001320E6 Length=00000148
ProcessRWError -Read- at LBA 001320E6 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001320EA Length=00000144
ProcessRWError -Read- at LBA 001320EA Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001320EE Length=00000140
ProcessRWError -Read- at LBA 001320EE Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001320F2 Length=0000013C
ProcessRWError -Read- at LBA 001320F2 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001320F6 Length=00000138
ProcessRWError -Read- at LBA 001320F6 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001320FA Length=00000134
ProcessRWError -Read- at LBA 001320FA Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001320FE Length=00000130
ProcessRWError -Read- at LBA 001320FE Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132102 Length=0000012C
ProcessRWError -Read- at LBA 00132102 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132106 Length=00000128
ProcessRWError -Read- at LBA 00132106 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013210A Length=00000124
ProcessRWError -Read- at LBA 0013210A Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013210E Length=00000120
ProcessRWError -Read- at LBA 0013210E Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132112 Length=0000011C
ProcessRWError -Read- at LBA 00132112 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132116 Length=00000118
ProcessRWError -Read- at LBA 00132116 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013211A Length=00000114
ProcessRWError -Read- at LBA 0013211A Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013211E Length=00000110
ProcessRWError -Read- at LBA 0013211E (Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132122 Length=0000010C
ProcessRWError -Read- at LBA 00132122 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132126 Length=00000108
ProcessRWError -Read- at LBA 00132126 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013212A Length=00000104
ProcessRWError -Read- at LBA 0013212A Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013212E Length=00000100
ProcessRWError -Read- at LBA 0013212E Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132132 Length=000000FC
ProcessRWError -Read- at LBA 00132132 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132136 Length=000000F8
ProcessRWError -Read- at LBA 00132136 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013213A Length=000000F4
ProcessRWError -Read- at LBA 0013213A Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013213E Length=000000F0
ProcessRWError -Read- at LBA 0013213E Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132142 Length=000000EC
ProcessRWError -Read- at LBA 00132142 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132146 Length=000000E8
ProcessRWError -Read- ( at LBA 00132146 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013214A Length=000000E4
ProcessRWError -Read- at LBA 0013214A Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013214E Length=000000E0
ProcessRWError -Read- at LBA 0013214E Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132152 Length=000000DC
ProcessRWError -Read- at LBA 00132152 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132156 Length=000000D8
ProcessRWError -Read- at LBA 00132156 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013215A Length=000000D4
ProcessRWError -Read- at LBA 0013215A Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013215E Length=000000D0
ProcessRWError -Read- at LBA 0013215E Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132162 Length=000000CC
ProcessRWError -Read- at LBA 00132162 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132166 Length=000000C8
ProcessRWError -Read- at LBA 00132166 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013216A Length=000000C4
ProcessRWError -Read-0 at LBA 0013216A Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013216E Length=000000C0
ProcessRWError -Read- at LBA 0013216E Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132172 Length=000000BC
ProcessRWError -Read- at LBA 00132172 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132176 Length=000000B8
ProcessRWError -Read- at LBA 00132176 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013217A Length=000000B4
ProcessRWError -Read- at LBA 0013217A Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013217E Length=000000B0
ProcessRWError -Read- at LBA 0013217E Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132182 0Length=000000AC
ProcessRWError -Read- at LBA 00132182 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132186 Length=000000A8
ProcessRWError -Read- at LBA 00132186 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013218A Length=000000A4
ProcessRWError -Read- at LBA 0013218A Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013218E Length=000000A0
ProcessRWError -Read- at LBA 0013218E Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132192 Length=0000009C
ProcessRWError -Read- at LBA 00132192 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132196 Length=00000098
ProcessRWError -Read- at LBA 00132196 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013219A Length=00000094
ProcessRWError -Read- at LBA 0013219A Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=0013219E Length=00000090
ProcessRWError -Read- at LBA 0013219E Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321A2 Length=0000008C
ProcessRWError -Read- at LBA 001321A2 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321A6 Length=00000088
ProcessRWError -Read- at LBA 001321A6 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321AA Length=00000084
ProcessRWError -Read- at LBA 001321AA Sense Code=C4090082
RTL exceeded
Starting LBA of0RW Request=001321AE Length=00000080
ProcessRWError -Read- at LBA 001321AE Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321B2 Length=0000007C
ProcessRWError -Read- at LBA 001321B2 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321B6 Length=00000078
ProcessRWError -Read- at LBA 001321B6 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321BA Length=00000074
ProcessRWError -Read- at LBA 001321BA Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321BE Length=00000070
ProcessRWError -Read- at LBA 001321BE Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321C2 Length=0000006C
ProcessRWError -Read- at LBA 001321C2 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321C6 Length=00000068
ProcessRWError -Read- at LBA 001321C6 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321CA Length=00000064
ProcessRWError -Read- at LBA 001321CA Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321CE Length=00000060
ProcessRWError -Read- at LBA 001321CE Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321D2 Length=0000005C
ProcessRWError -Read- at LBA 001321D2 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321D6 Length=00000058
ProcessRWError -Read- at LBA 001321D6 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321DA Length=00000054
ProcessRWError -Read- at LBA 001321DA Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321DE Length=00000050
ProcessRWError -Read- at LBA 001321DE Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321E2 Length=0000004C
ProcessRWError -Read- at LBA 001321E2 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321E6 Length=00000048
ProcessRWError -Read- at LBA 001321E6 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321EA Length=00000044
ProcessRWError -Read- at LBA 001321EA Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=001321EE Length=00000040
ProcessRWError -Read- at LBA 001321EE Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321F2 Length=0000003C
ProcessRWError -Read- at LBA 001321F2 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321F6 Length=00000038
ProcessRWError -Read- at LBA 001321F6 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=001321FA Length=00000034
ProcessRWError -Read- at LBA 001321FA Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=001321FE Length=00000030
ProcessRWError -Read- at LBA 001321FE Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132202 Length=0000002C
ProcessRWError -Read- at LBA 00132202 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132206 Length=00000028
ProcessRWError -Read- at LBA 00132206 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013220A Length=00000024
ProcessRWError -Read- at LBA 0013220A Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013220E Length=00000020
ProcessRWError -Read- at LBA 0013220E Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132212 Length=0000001C
ProcessRWError -Read- at LBA 00132212 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132216 Length=00800018
ProcessRWError -Read- at LBA 00132216 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013221A Length=00000014
ProcessRWError -Read- at LBA 0013221A Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013221E Length=00000010
ProcessRWError -Read- at LBA 0013221E Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132222 Length=0000000C
ProcessRWError -Read- at LBA 00132222 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=00132226 Length=00000008
ProcessRWError -Read- at LBA 00132226 Sense Code=C4090082
RTL exceeded
Starting LBA of RW Request=0013222A Length=00000004
ProcessRWError -Read- at LBA 0013222A Sense Code=C4090082
RTL exceeded
No HOST FIS-ReadyStatusFlags 0002A185
After This process finished powerd off the hdd then connected with sata and power
the HDD DETECTED with full capacity and all DATA without loss anything.
This process worked for me in 4 hdd of same model and same problem.
Till now all these 4 hdds working Fine without any problems. I don't know what happended just shorting read channels only (NO commands issued)
Can Someone Explain this.
Thankyou
PostPosted: June 16th, 2015, 1:48
At starting Hdd is not detecting.....running without any noise......
than I try to short the Pin Points but giving the error....
PostPosted: June 16th, 2015, 3:23
Try to change PCB and swap rom chip
PostPosted: June 16th, 2015, 7:23
RECOV Servo Op=0155 Resp=0005x[0x0000B319][0x0000B319]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZ[0x0000B31A][0x0000B31A]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMdddddd [/quote]
einstein9 wrote:
Heads Issue, no DIY
I agree, this message means overlays and/or servo cant read which is usually heads in my experience.
PostPosted: June 16th, 2015, 8:01
The drive is definetely degraded, trying to reallocate bads and has firmware issues attempting so.
There is a fine line on this family between just bads + firmware issues and heads issue.
If fortunate, then just bads and firmware. If unfortunate (which is a frequent occurrence), then it is a head issue as well.
How to know for sure? Using proper advanced equipment, expertise in understanding tests that should be run and accurately interpreting test results. Then comes the solution(s) implementation part.
At this point, more testing is necessary.
PostPosted: June 20th, 2015, 15:45
Yes DIY. i recover it.
viewtopic.php?f=1&t=27549&p=218159#p218159
use short pins and you must do several attempt.
Users browsing this forum: No registered users and 123 guests
