 Post subject: Suspect: NVRAM Damage
PostPosted: July 1st, 2015, 7:53
I've a case HTS541010A9E680
Symptom: No spin up with patient PCB, but come to READY status. Only thing Can be read is NVRAM and ROM with SD Doctor.
Checked with DONOR PCB + PATIENT NVR - Same Symptom, No Spin up but READY.
Checked with DONOR PCB + DONOR NVR - Spin up
Can anyone see the existing condition of the NVR attached with the thread please
5410A9.rar [123.16 KiB]
Downloaded 464 times
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: Suspect: NVRAM Damage
PostPosted: July 1st, 2015, 8:21
Inside ROM there are 2 copies of NVRAM:
Copy1 address: from 0x2000h to 0x3000h
Copy2 address: from 0x3000h to 0x4000h
both copies are identical, this means that very likely NVRAM is OK.
My firmware database:
PostPosted: July 1st, 2015, 8:44
Hi
In hitachi Hard disk Drive, Nvram Damaged chances is very low in case of not spinup.
Mostly the ROM is damaged.
Find same micro code ROM , Add patient NVRAM to Donor ROM. Some time help full
Waqas Ali
PostPosted: July 1st, 2015, 11:43
I agree with Waqas :)
Users browsing this forum: No registered users and 38 guests
