 Post subject: WD10EZRX-OOL4HBO TrailXLS Error
PostPosted: July 10th, 2015, 6:05
I have a WD WD10EZRX-OOL4HBO TrailXLS with following errors
Any suggestions ?
Debug Stop Code......................... : HOST DEBUGSTOP RESET TIMEOUT
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 1
Cyl Count............................... : 256
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 208 538
SA regions address...................... : by default
SA Translator loading................... : Module ID 30 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
ROM Modules:
ROM version............................. : 01.3DG
ROM F/W version......................... : 0001003D
Overlay F/W version..................... : 01.3DG
Servo F/W version....................... : 22.34
Head Map Reading Error.................. : Head map check sum error
 Post subject: Re: WD10EZRX-OOL4HBO TrailXLS Error
PostPosted: July 10th, 2015, 6:59
TrailXLS not work in Safe mode.
Load LDR.
PostPosted: July 11th, 2015, 0:41
IN NORMAL MODE
Techno mode key
Techno mode key......................... : Ok
RAM:
Heads number............................ : 2
Drive is not ready
Zone allocation table................... : HDDs RAM reading error - Drive is not ready
ROM:
ROM Modules:
Overlay F/W version..................... : 01.3EG
Service area:
Permanent overlay....................... : Loaded
SA dir reading (ID)..................... : Drive is not ready
SA dir reading (ABA/CHS)................ : Module ID 30 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
SA Access............................... : NONE
Configuration reading................... : module 02 not found
PostPosted: July 11th, 2015, 1:58
Any suggestions ?
Shouldn't the number of heads be 2, and doesn't the checksum error indicate a problem with ROM module 0A?
Could you upload a copy of the ROM?
PostPosted: July 11th, 2015, 3:04
Here is copy of ROM for your reference "FZABKAR"
ROM_0001003D.rar [242.17 KiB]
Downloaded 688 times
PostPosted: July 11th, 2015, 5:19
Here is ROM module 0A:
00000000  52 4F 59 4C 04 00 1E 00 0A 00 01 00 6B 5E 6B 5C  ROYL........k^k\
00000010  30 30 30 32 30 30 30 30 01 1C 0E 00 00 00 30 0D  00020000......0.
00000020  04 02 02 00 00 00 7C 46 7C 41 5A 59 4E 47 59 47  ......|F|AZYNGYG
00000030  55 55 00 00 FF FF FF FF FF FF 00 00 B0 F5 03 00  UU..ÿÿÿÿÿÿ..°õ..
00000040  03 00 00 00 00 00 47 00 00 00 00 00 00 00        ......G.......
The 32-bit checksum of the entire module is 0x00000000.
The number of heads is 02 (offsets 21h/22h).
The head map is 03h (offsets 3Eh/40h).
The sum of bytes 1Eh - 3Bh is 0x0A50. If we now add the checksum word at offset 3Ah we have ...
    0x0A50 + 0xF5B0 = 0x10000
In short, I can't see anything wrong with the module.
PostPosted: July 11th, 2015, 7:37
IN NORMAL MODE
No utility in the normal mode, and the HDD.
With ROM all good.
Requires compatible load modules 5C and 11.
Then, the ROM will be read properly.
PostPosted: July 13th, 2015, 1:46
Thanks FZABKAR and TOMSET
Started with loader and written some error giving MODS.
Disk Started under imaging :D
Thanks for help and pointers
PostPosted: December 19th, 2015, 5:24
SIR I HAVE SAME PROBLEM.AFTER CHANGING DIR ADDRESS I CAN ACCESS SA.I CHECK ALL MODS.I FIND 2D,2E,12D,12E,22D,22E ARE SHOWING PROBLEM IN BOTH COPY.I REWRITE MOD FROM GOOD COPY.ONLY MOD 22E IS GIVEN HEADER ERR.THAN AGAIN CHANGING DIR MOD ADD TO ORIGINAL STATUS DRIVE BECOMES SAME STATUS.MOD 30 ERR AND HEADMAP CHECKSUM ERR.IF I DIRECTLY START UTILITY IT SHOWS ONLY ERR LED RED.THAN BY SELCTING FA,ILY DRIVE GIVES.
Techno mode key
RAM:
ROM:
Modules directory address............... : 208 640
ROM Modules:
ROM version............................. : 01.26G
ROM F/W version......................... : 00010026
Overlay F/W version..................... : 01.26G
Servo F/W version....................... : 12.22
PLS TELL ME WHERE I AM WRONG.
Users browsing this forum: No registered users and 278 guests
