 Post subject: ST3320418AS FW Revision: CC34 detected 0-Byte
PostPosted: July 23rd, 2015, 8:48
I have a seagate barracude 7200.12 which is detected with 0-bytes now although
hdparm shows 8 GB.
ATA device, with non-removable media
   Model Number:       ST3320418AS
   Serial Number:      9VM03024
   Firmware Revision:  CC34
Transport: Serial
Standards:
   Used: unknown (minor revision code 0x0029)
   Supported: 8 7 6 5
   Likely used: 8
Configuration:
   Logical      max   current
   cylinders   16383   16383
   heads      16   16
   sectors/track   63   63
   CHS current addressable sectors:   16514064
   LBA    user addressable sectors:          0
   LBA48  user addressable sectors:          0
   device size with M = 1024*1024:        8063 MBytes
   device size with M = 1000*1000:        8455 MBytes (8 GB)
Capabilities:
   LBA, IORDY(can be disabled)
   Queue depth: 32
   Standby timer values: spec'd by Standard, no device specific minimum
   R/W multiple sector transfer: Max = 16   Current = ?
   Recommended acoustic management value: 254, current value: 0
   DMA: mdma0 mdma1 *mdma2 udma0 udma1 udma2 udma3 udma4 udma5 udma6
        Cycle time: min=120ns recommended=120ns
   PIO: pio0 pio1 pio2 pio3 pio4
        Cycle time: no flow control=120ns  IORDY flow control=120ns
Commands/features:
   Enabled   Supported:
      *   SMART feature set
          Security Mode feature set
      *   Power Management feature set
      *   Write cache
      *   Look-ahead
      *   Host Protected Area feature set
      *   WRITE_BUFFER command
      *   READ_BUFFER command
      *   DOWNLOAD_MICROCODE
          Power-Up In Standby feature set
          SET_FEATURES required to spinup after power up
          SET_MAX security extension
      *   Automatic Acoustic Management feature set
      *   48-bit Address feature set
      *   Device Configuration Overlay feature set
      *   Mandatory FLUSH_CACHE
      *   FLUSH_CACHE_EXT
      *   SMART error logging
      *   SMART self-test
      *   General Purpose Logging feature set
      *   WRITE_{DMA|MULTIPLE}_FUA_EXT
      *   64-bit World wide name
          Write-Read-Verify feature set
      *   WRITE_UNCORRECTABLE command
      *   {READ,WRITE}_DMA_EXT_GPL commands
      *   Segmented DOWNLOAD_MICROCODE
      *   SATA-I signaling speed (1.5Gb/s)
      *   SATA-II signaling speed (3.0Gb/s)
      *   Native Command Queueing (NCQ)
      *   Phy event counters
          Device-initiated interface power management
      *   Software settings preservation
      *   SMART Command Transport (SCT) feature set
      *   SCT Long Sector Access (AC1)
      *   SCT LBA Segment Access (AC2)
      *   SCT Error Recovery Control (AC3)
      *   SCT Features Control (AC4)
      *   SCT Data Tables (AC5)
          unknown 206[12]
Security:
   Master password revision code = 65534
   not   supported
   not   enabled
   not   locked
      frozen
   not   expired: security count
   not   supported: enhanced erase
   2min for SECURITY ERASE UNIT.
Checksum: correct
At spinup it#s tickin slightly and it's getting pretty hot. What do you think, heads dead or FW issues?
best regards
 Post subject: Re: ST3320418AS FW Revision: CC34 detected 0-Byte
PostPosted: July 24th, 2015, 4:22
Recorded and uploaded sound at initialization, the first popping noise is from putting
the iphone mic on top cover of the disk:
https://itmb.co/jwefy
Sounds like it's the 11-clicks issue I read about here regarding some other 7200.12 drives.
Users browsing this forum: Bing [Bot] and 80 guests
