SSHD WD10S21X stopped to work while unpacking 7-zip archive
July 27th, 2015, 14:39
Disk is placed in my Lenovo Y70-70 notebook.
It is correctly recognized by BIOS but there is no partitions and free unallocated space on it.
Device cant be set as active disk in Windows 8.1.
My colegue told me that issue may be caused by unproperely filled 8GB flash memory and force cleaning it or changing firmware could help.
This is that same problem like here: http://community.wd.com/t5/Desktop-Mobile-Drives/WD-Black-1TB-WD10S21X-0MB-Capacity/td-p/885640
Any suggestions what to do?
Image Image
Re: SSHD WD10S21X stopped to work while unpacking 7-zip arch
July 27th, 2015, 15:53
Try to read the drive's firmware resources with SeDiv.
http://sediv2008.narod.ru/Easy3.9Passwo ... 567890.rar
http://sediv2008.narod.ru/Settings.rar
SeDiv WD Read ROM & Modules:
https://www.youtube.com/watch?v=9UgFfhkkAwY
July 27th, 2015, 16:30
The drive is in kernel mode, so reading the firmware is unlikely to succeed as you only have access to the PCB. Sorry to say this is not likely to be a DIY case.
July 27th, 2015, 16:35
data-medics wrote:The drive is in kernel mode, so reading the firmware is unlikely to succeed as you only have access to the PCB.
Where are the SMART data stored?
July 27th, 2015, 16:50
On the platters in the SA, but I tend to doubt it actually read it. I could be wrong, but in any event it's not likely to be DIY showing 0 capacity and being in kernel mode.
July 27th, 2015, 17:11
So, there is no chance to reanimate this drive?
Tbh i dont know what DIY word means ;).
July 27th, 2015, 17:20
Krzy5i3k wrote:So, there is no chance to reanimate this drive?
DIY = Do It Yourself
It can't hurt to try SeDiv.
July 27th, 2015, 17:28
I will try ofcourse.
This SeDiv its freeware soft right? I dont want to use any cracked software.
July 27th, 2015, 17:45
The SeDiv links are for a free demo version. It reads the firmware resources but won't write them. There are other free (not cracked) methods for writing the modules.
