 Post subject: WD My Passport Ultra 2TB problem :(
PostPosted: July 28th, 2015, 12:45
http://forum.hddguru.com/viewtopic.php?f=1&t=29500&p=220025#p220025
I have similar problem, like in link above...
WD My Passport Ultra 2TB,
HDD model inside WD20NMW-11AV3S2 and
PCB 2060-771961-001 REV A
One day it stopped working, no clicking noises, it spins starts moving head and after some time it stops spinning and starts again immediately again to spin... I suspected that it was head problem... So I ordered same disk, same specs and disassembled. Replaced heads and I got same problem on broken hard disk, and on new disk with old head I had no problems. It worked OK... After that I asked my friend to replace two BIOS IC, since I thought it is PCB problem... But after replacing BIOS IC's old disk was in slow mode as biggerpizza said. I could see size of disk and type of disk, but could not access disk files. So we decided to return BIOC IC's as they were originally. But then I have same problem and with the new disk, it is in slow read mode, and old one has same problems, stops spinning after some time. Interesting is that if I swap motherboards both of disks are spinning, I can hear head that is trying to read but never initializes... I don't see disk, I can see only My Passport 0820.
What to do now? Can you help me? Pleaseeeee :(
I will buy some beer to one who help me :beer:
 Post subject: Re: WD My Passport Ultra 2TB problem :(
PostPosted: July 28th, 2015, 13:00
You need the free assistance of user fzabkar - memberlist.php?mode=viewprofile&u=13702
PostPosted: July 28th, 2015, 16:04
Now it's time to realize you destroyed the drive along with any hopes of recovery, throw it in the trash, and move on. Should have never opened it.
PostPosted: July 28th, 2015, 17:41
Can you at least explain what I did wrong? Both of the disks with swapped heads worked as with their original heads, new one worked as before, old one same symptoms? Problems began when I swapped PCB Bios IC's...
PostPosted: July 30th, 2015, 12:32
I didn't say that data on this disk is not so important, is not worth of paying few hundred dollars for recovery, so I decided to play and learn. I did Head swap in pro clean room with no dust and other contaminant...
Users browsing this forum: No registered users and 125 guests
