Error window in R-studio!
August 6th, 2015, 3:06
Hi Guys,
Does any one encounter this error window in R-studio after make scan and then open the recovered partition?
after this window pop up the program automaticlly close!
How I can pass this error?
Re: Error window in R-studio!
August 6th, 2015, 3:27
IF and ONLY IF you paid for it, then better ask the support.
August 6th, 2015, 4:28
einstein9 wrote:IF and ONLY IF you paid for it, then better ask the support.
Unfortionatlly,, I doesn't have paid version :( , But I ask the forums memeber if face this problem before and solve it :)
August 6th, 2015, 7:01
the price for r-studio is fair enough, i think it is not justified to use crack software when you choose DR as a profession.
August 6th, 2015, 7:30
NO SUPPORT/ADVICE FOR PIRATE SOFTWARE HERE! :evil: :evil:
August 6th, 2015, 8:13
For $899 USD, I'll be happy to submit your question to the R-Studio tech team and will even pitch in a legal tech license.
August 6th, 2015, 10:04
lcoughey wrote:For $899 USD, I'll be happy to submit your question to the R-Studio tech team and will even pitch in a legal tech license.
August 6th, 2015, 10:43
If he bothered to search the forum, he may have seen that a representative from RTT is an active member, and maybe a dumb idea to post such a question...
would be ironic if the error was by design, a little friendly gift to piraters ;)
August 6th, 2015, 11:58
It's ram problem, use R-Studio x64 on 64 bit system with 6 GB ram or greater.
August 6th, 2015, 15:18
It could be a lot of problems, from file system damage, to linux related problems (if the volume you are extracting from is linux), to machine resources, etc.
Need more info. Simple load tests on the machine and tests with other tools can eliminate a lot of issues quickly.
August 7th, 2015, 11:36
Pcimage and HaQue I'm not cracked the program l'm use it as demo to try it, and I think this is legal and if the r-studio give me this right you shouldn't prevent me this right
Thank you for other member try to help me not to judge me.
August 7th, 2015, 12:36
eng.mas wrote:Pcimage and HaQue I'm not cracked the program l'm use it as demo to try it, and I think this is legal and if the r-studio give me this right you shouldn't prevent me this right
If that's the case, then I apologise.
I mis-interpreted your situation after "chinopk" mentioned "crack software" :oops:
August 7th, 2015, 19:16
Likewise. I am sure that RTT would like to know about it if the correct version is being used for the right OS, on at least the recommended PC Specs. Their support is listed prominently on their site and in the software.
also, there is a new version, try that
August 8th, 2015, 6:24
it is not logical to ask support for a demo version. :?:
also OP did not mentioned in 2nd post a demo version :?:
No offense.
sorry if i assume it other way.
August 8th, 2015, 6:44
The old myth that you can install whatever cracked program you want and demo it as long as you delete it within 24 hours is false.
Using a demo version, along with restrictions, is ok for terms of service, and you don't have to think it is right, you know it.
this screenshot is a demo version, while yours is not.
August 8th, 2015, 15:02
I asked questione and alot try acting like an angels
Thanx for every one tried help me to solve it
And for those who just says bla bla bla bla bla try be a gentelmen.
And the image which i posted i googled it
And i have another primry programs and tools cost me 10000$
Thats all thanx :)
