 Post subject: ST2000DM001 problem and hard drive repair
PostPosted: August 7th, 2015, 18:11
Hi guys, the issue with the firmware on Seagates ST2000DM001 and 3 Tb has solution yet?
Boot 0x40M
Spin Up
TCC-0020[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
ASCII
TCC-0020Diag mode
F3 T>
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt
MCMainPOR: MCMT SEC copy valid
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 01A5D0F4
[RSRS] 0744
ProcessRWError -Read- at LBA 000000000005E0CB Sense Code=40000087
ProcessRWError -Read- at LBA 000000000005E1BE Sense Code=40000087
ProcessRWError -Read- at LBA 000000000005E1C1 Sense Code=40000087
ProcessRWError -Read- at LBA 000000000005E1C3 Sense Code=40000087
ProcessRWError -Read- at LBA 000000000005E1E2 Sense Code=40000087
ProcessRWError -Read- at LBA 000000000005E1EA Sense Code=40000087
File comment: not possible for me to access the firmware with terminal
busy state seagate st2000dm01.txt [4.84 KiB]
Downloaded 730 times
Recuperacion De Datos Dominican Republic
Users browsing this forum: Phamthanhktv and 68 guests
