 Post subject: ST3000DM001 SEAGATE HELP
PostPosted: August 8th, 2015, 12:44
hi Guru`s. Seagate ST3000DM001 after heads swap.
what do you think on this one?
heads compatible or not?
Boot 0x40M
Spin Up
FAIL Servo Op=0100 Resp=0007
0100 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 18C0 004F 03B4 4440 0008 0000 0000 0000 0D3E 0000 0000 0000 0000 0000 0000 0000 E7AC C3D2 FFFF 2000 DC88 0000 0000 4498 0000 4498 0000 2247 0000 0020 001A 0007 0010
FAIL Servo Op=0100 Resp=0003
ResponseFrame 2000 0051 03B4 4400 0008 0000 0000 0000 0D4A 0000 0000 0000 0000 0000 0000 0000 E7AC C3D2 FFFF 2000 DC88 0000 0000 4498 0000 4498 0000 007F 0004 0020 001A 0004 0000
Boot 0x40M
Spin Up
ResponseFrame 1A40 004F 03B4 4280 0008 0000 0000 0000 0D93 0000 0000 0000 0000 0000 0000 0000 E7AC C3D2 FFFF 2000 DC88 0000 0000 4498 0000 4498 0000 2247 0000 0020 001B 0007 0010
ResponseFrame 2140 0053 03B4 41C0 0008 0000 0000 0000 0DB7 0000 0000 0000 0000 0000 0000 0000 E7AC C3D2 FFFF 2000 DC88 0000 0000 4498 0000 4498 0000 007F 0004 0020 001B 0004 0000
Recuperacion De Datos Dominican Republic
 Post subject: Re: ST3000DM001 SEAGATE HELP
PostPosted: August 9th, 2015, 4:35
What is detail on sticker for patient and donor ?
RAID/Server Recovery
PostPosted: August 14th, 2015, 4:10
If heads work back in donor, they are probably incompatible, if not, surface is damaged.
There are methods to check basic compatibility criteria btw.
Users browsing this forum: No registered users and 91 guests
