 Post subject: Useles TVS changes in Seagate ST3000DM001
PostPosted: August 9th, 2015, 16:41
because of Wrong Adapter TVS diodes burn in ST3000DM001.
i repair it.
drive spins. head moves. after that suddenly stops.
I've never encountered such a problem.
Why it stops?
 Post subject: Re: Useles TVS changes in Seagate ST3000DM001
PostPosted: August 11th, 2015, 23:16
What exactly did the repair entail? If used adaptives swap on a donor PCB, then it is possible the solder is weak and ROM is not connecting well. If this is not the problem, then there could have been other subsequent issues along with the original TVS failure, such as motor winding failure, preamp failure, etc.
PostPosted: August 12th, 2015, 1:28
Dead preamp or more pcb damage.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: August 12th, 2015, 3:51
i only desolder burnt TVS diode.
no swap.
drive spins. mobo sees hdd and suddenly stops.
PostPosted: August 12th, 2015, 5:56
+1
RAID/Server Recovery
Users browsing this forum: No registered users and 216 guests
