 Post subject: What type of error is Offline_Uncorrectable tracking?
PostPosted: August 12th, 2015, 19:52
I'm trying to determine if a hard disk someone gave to me is reliable enough to use. It's a WDC WD4000F9YZ-09N20L0 (4TB Western Digital Enterprise). The drive originally had the following SMART stats:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   199   199   051    Pre-fail  Always       -       80
  3 Spin_Up_Time            0x0027   184   184   021    Pre-fail  Always       -       9766
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       92
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   084   084   000    Old_age   Always       -       11768
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       92
183 Runtime_Bad_Block       0x0032   095   095   000    Old_age   Always       -       5
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       64
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       27
194 Temperature_Celsius     0x0022   116   097   000    Old_age   Always       -       36
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       16
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       20
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       33
I decided the first thing I would do with it was run badblocks (linux) on it as an easy way to write the entire drive a couple times. If it's going to die, I wanted to kill it right away. After the first write pass (badblocks -svw) the SMART stats related to reallocation changed. Nothing changed during the second pass. Now it looks like this:
  1 Raw_Read_Error_Rate     0x002f   200   198   051    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0032   084   084   000    Old_age   Always       -       11795
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       28
194 Temperature_Celsius     0x0022   105   097   000    Old_age   Always       -       47
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
I understand how pending reallocation works., but I don't understand what Offline_Uncorrectable is indicating. So, I have a couple questions.
1) What exactly is Offline_Uncorrectable?
2) Is it possible for that value to decrease? Under what circumstances would this happen?
The only other thing noteworthy thing I've seen so far is that I have 2 of these disks and started running badblocks at exactly the same time. The above disk has been running slightly slower that the other. It's approximately 3% behind the other which is (very roughly) 15-20 minutes of work.
Any thoughts?
Ryan
P.S. I like your posting guidelines :-)
Users browsing this forum: Google [Bot], Pi0tR and 81 guests
