 Post subject: Motor stucked
PostPosted: August 10th, 2015, 6:20
Does anyone has videos for platter swapping?
I have a Seagate with motor stucked and the only way to recover data is with a platter swap.
 Post subject: Re: Motor stucked
PostPosted: August 10th, 2015, 8:38
It's not easy to pull off with Seagates, not successfully anyway. I've even gone as far as changing the motor bearing using a high press rather than platter swapping.
 Post subject: Hard drive motor stuck
PostPosted: August 10th, 2015, 10:05
If that's a client's drive, I don't think it's a good idea to start with it.
Better outsource this recovery and practice on second-hand drives first.
Not much details about the job, but I believe we should be able to help if necessary.
 Post subject: Re: Hard drive motor stuck
PostPosted: August 11th, 2015, 11:11
Ditto. In UK
PostPosted: August 12th, 2015, 16:23
7200.10> with some tape and HDD surgery is a walk in the park.
PostPosted: August 13th, 2015, 8:39
I would like to know the parks where you walk , the one I know, have many thorns..... but if you can walk, very carefully
Users browsing this forum: No registered users and 45 guests
