 Post subject: ST1000DM003 not detected
PostPosted: August 18th, 2015, 16:43
Greetings friends ,
i have this ST1000DM003 , no drops reported , no odd noise , drive gets RDY in DDI , but busy afterwards, PCB swapped by donner one , same results ..
terminal shows noting abnormal , exept if I didnt press ctrl +z at the drive startup , it will not allow ttl access ..
any Ideas ? ROM maybe ?
 Post subject: Re: ST1000DM003 not detected
PostPosted: August 18th, 2015, 21:33
upload the terminal log
PostPosted: August 19th, 2015, 8:01
Hello raven!
Power your hdd with shorting read channels.
You will see something like this:
(DOS) Table Read FAIL
DOS: MAGIC CONFIG NUMBER MISMATCH
No HOST FIS-ReadyStatusFlags 2002A185
Then here push ctrl+z
Test heads on level 7 with command X
To stop InitiateMarkPendingReallocateRequest on F3 :
F00A2,00,22
F01E4,00,22
F057C,043C,22
These are used to disable auto relocation
....then clear smart on level 1 with N1 command.
Good luck!
PostPosted: August 19th, 2015, 13:28
Hello again ,
terminal output is
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
ASCII Diag mode
F3 T>
yes clearing the smart is possible, as the NRG list has no records ..
PostPosted: August 24th, 2015, 6:17
Greetings again ,
well , confirmed , not a rom issue , but rather than smart list full because of many bad sectors ( and areas ) , clearing the smart did make the HDD detect , but now when imaging am facing huge issues , from 1% till 70% HDD images fine with really dead areas ( cant read a thing ) almost 100,000 - 150,000 LBAs sized , from 70%+ HDD not reading a single sector ....
NRG list was empty of any records before clearing SMART ...
do you think it's related to dead areas of the platters them selfs ?
Users browsing this forum: No registered users and 67 guests
